Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2015
Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 11-20-2011, 11:42 PM   #76
scooba scooby
Member#: 301611
Good luck with the build man!
scooba scooby is offline   Reply With Quote
Old 11-20-2011, 11:54 PM   #77
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Yeah, trying to get some pics sorted out from the weekend's work. Expect an update tomorrow
Old 12-14-2011, 12:00 PM   #78
xloyaltyx
Member#: 300639
good luck on the project nice car
xloyaltyx is offline   Reply With Quote
Old 12-14-2011, 04:34 PM   #79
Homemade WRX
Member#: 33782
96 bastard child
expect updates this weekend as I'll finally be in town
Old 12-16-2011, 11:12 AM   #80
Murilo08wrx
Member#: 303505
nice car! classic subie
Murilo08wrx is offline   Reply With Quote
Old 12-22-2011, 02:09 PM   #81
biodude
Member#: 271720
biodude is offline   Reply With Quote
Old 12-22-2011, 02:52 PM   #82
Homemade WRX
Member#: 33782
96 bastard child
yeah, well I had time to work on the car but not host pics I'll bring the SD card to work tomorrow and load them up.
Suspension is back under it and the Ver 3 RA trans is back together.
Old 12-22-2011, 03:08 PM   #83
biodude
Member#: 271720
at least you took pics. I think I've snapped all of 4 pics of my progress(or lack thereof) over the past 8 mos.
Old 12-23-2011, 09:44 AM   #84
Homemade WRX
Member#: 33782
96 bastard child
Well I didn't take many pics either. There really isn't much to show
However I just learned that my laptop at work has a non-working SD card drive...awesome.
Leaving straight from work to head home to Virginia Beach...so expect them tomorrow
Old 12-24-2011, 06:35 AM   #85
pitman boosted
Member#: 302967
nice ride. i need to find a cheap wrx like this.
pitman boosted is offline   Reply With Quote
Old 12-24-2011, 05:30 PM   #86
Homemade WRX
Member#: 33782
96 bastard child
Lots bushing pushing
Lumpy (highway patrol) ready for surgery on a rusty lateral link bolt.
once pushed through the lower control arm rear mount...you will have to remove the inner sleeve. It is a pain and the MSI aluminum housing for this will save LOTS of time...and be uber billet pretty
Inner liner of the front control arm mount, mentioned above. Here you can see the chisel that was carefully used to split it. Between this and center punches, we walked the sleeve off of the housing wall and split it with the chisel. Eventually you get far enough that you can twist it with vise grips and rip it out...or in this case, split it the whole length.
Old 12-24-2011, 05:32 PM   #87
Homemade WRX
Member#: 33782
96 bastard child
Diff Carrier bushings
stock washer
stock bushing
The upper bushing on washer and a little grease on it to help it stick in place.
now going into place
lower inner bushing in...a little grease or something of a similar natural will help it stick in place while working under the car.
lower outer going on. It does require a little manipulating to get it to pull around the 'ridges' on the stock bushing.
Old 12-24-2011, 05:44 PM   #88
Homemade WRX
Member#: 33782
96 bastard child
Back to bushings
note cell phone pics as the dslr battery died :sadbana: and appologies.
The way to press out the rear trailing arm bushing without having to tear down the rear upright.
As the tip of the puller was pointed and near the side of the bolt hole, we used a nickle (which was eaten through) and then a quarter (greased up and used with the nickel) to keep the puller tip from digging into the stock sleeve or from damaging the tool.
new bushings are in and ready for install
Old 12-24-2011, 05:47 PM   #89
Homemade WRX
Member#: 33782
96 bastard child
Rear Crossmember 'touch up'
I didn't want to go too crazy as this is just a street car but put some torsion on the crossmember and saw points where it pulled. You'll see some of the points below, cleaned up and ready for welding. There is more work to be done for a race car for instance but I figured a few little spots to help, with minimal work, is fine for this.
This corner got tapped flat with a ball-peen hammer and the corner was welded down.
This corner received 'hammer love' too...though not shown.
Old 12-24-2011, 05:53 PM   #90
Homemade WRX
Member#: 33782
96 bastard child
R180 diff, mustache bar and axles.
The bushings are very simple and straight forward. Simply press and replace. The fitement into the rear xmember was quite snug, so I put a little grease to coax the bar into place. Also with the diff hanging off, once bolted in, you could tell how much stiffer these are. I look forward to not hearing the 'clunk' anymore.
4.44 R180 sitting in it's new home.
DSS R180 conversion axles...had these sitting around from an old build. On a budget, a 'JDM' R160 4.44 (or in several USDM cars as well but without LSD) and it's inner stubs can easily be swapped over to your GD bar and out cv's.
R160, meet your replacement, R180.
Another, just for size comparison.
Ver. 3 RA Trans, back together and waiting for it's turn.
Old 12-24-2011, 06:01 PM   #91
Homemade WRX
Member#: 33782
96 bastard child
FCAR pics are yet to come as well...dead camera = no pics but it is straight forward for bushing install as mentioned above (inner sleeve that has to be removed).
Old 12-25-2011, 12:25 AM   #92
biodude
Member#: 271720
this is why i like you. (no homo!)
I hadn't put any thought into reinforcing the x-member. Its on the "to do" list now.
Old 12-26-2011, 01:14 AM   #93
Homemade WRX
Member#: 33782
96 bastard child
If I really cared a great deal about improving the rear x-member I'd have added some material to crossemember and dimple die punched other areas...but it's a DD that I'll probably wrap up the project, play with until about April/May time frame. Then onto the next project car...
This will probably, though regrettably, be going up for sale to put money down on BRZ/FRS.
Old 12-26-2011, 10:06 PM   #94
eduSti
Member#: 136503
08 STI
ohhh man i can just see your other project taking a back seat to a brz......hahaha........well if thats the case Ill put my name on the list of buyers, and you know im not talking about the bugeye
eduSti is offline   Reply With Quote
Old 01-03-2012, 09:26 PM   #95
Homemade WRX
Member#: 33782
96 bastard child
yeah, I having a feeling the BRZ/FRS will be a good thing.
As for my projects, I just got back into town tomorrow, so back on track now.
Old 01-06-2012, 04:25 PM   #96
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Hey Micah, have you done any calcs to see if any of the EZ motors would benefit from a long rod setup? I know they aren't cheap and plentiful and don't have much aftermarket support. I just keep thinking about it and like the idea of 2 extra cylinders/more displacement.
geronimo81 is online now   Reply With Quote
Old 01-06-2012, 05:27 PM   #97
Homemade WRX
Member#: 33782
96 bastard child
I'd looked into the EZ engines, not nearly like I did on the EJ's. I did some quick off the cough calcs.
Not really much room for doing a long rod, however stroking an EZ30 or destroking an EZ36 are both options too.
Old 01-13-2012, 04:39 PM   #98
jollyblue84
Member#: 292300
01 GC8
blue
Very interesting.
jollyblue84 is offline   Reply With Quote
Old 01-13-2012, 06:15 PM   #99
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Hahahahaha how did I know you had already looked into this. I meant to include destroking/stroking in my original question.
Hmmm destroked EZ36.....you don't say
Who am I kidding, it will be a very long time before I can afford such a project. Will probably settle on something more common/cheaper/easier by the time I start to see the costs add up.
Old 01-13-2012, 11:20 PM   #100
YZ86
Member#: 188705
GD Widebody STI
Lexus Pearl White
Looks good man, One day I will going to replace all my x member bushing too!
YZ86 is offline   Reply With Quote
who says a dollar can't buy anything wrxtuner02 Off-Topic 11 03-25-2005 11:51 PM
FS kick a$$ speakers Giova New England Impreza Club Forum -- NESIC 0 05-23-2001 07:54 AM
Who says wagons can't play in the mud?! RandyF Legacy Forum 4 08-02-2000 09:00 AM
Who says the US can't build a rally car! Opie General Forum Archive 11 05-25-2000 09:35 PM
