Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC > NESIC Private Classifieds
Old 04-17-2011, 06:24 PM   #1
2.0Tawd
Member Sales Rating: (10)
Member#: 92415
2011 OBP WRX
Default CT: 2002 WRB Hybrid
Up for sale is my 2002 WRX Hybrid. I bought this car in July of 2009 and when I purchased it, it had spun a rod bearing. Instead of putting in another 2.0 shortblock I opted to go with a hybrid setup. I built the motor myself and all parts were brand new unless otherwise noted below (I have all the receipts to prove it). The motor now has 33K on it and other than a clogged fuel pressure regulator which I swapped out in December of 2009, the car has had zero issues. All I have had to do is change the oil, clean the air filter and that's it. Just get in and drive! I will truly miss this car, but now that my STi is on the road, I can't afford to keep both despite how much I would like to.
As for the mileage - the chassis has 184xxx on it. However, so much has been replaced, that that number is a little misleading.
The tranny was swapped purely to get rid of the higher mileage one. I swapped the tranny last January because my friend with an 04 wrx had a rod let go after he installed an fp hta 68 on it and opted to do a full 04 sti swap. I took the opportunity to swap the the tranny as I found someone almost simultaneously to buy mine. It literally cost me 4 hours of my own time and 4 quarts of gear oil to do the swap (obviously a no-brainer). That said the tranny now has close to 90k on it. There are no grinds, noises or anything else that suggests its not healthy. And while everyone will say they have never launched their car, I swear on my life that it has never once been launched. The car has never been to a drag strip, road course, autocross event, etc.
For the suspension, originally I put 04 sti takeoffs on the car, but the clunking was unbearable so I took them off and put on stock wrx struts that my friend had sitting in his basement from his bugeye. So in total the suspension has approx 50k miles on it.
The exterior is the cleanest of all the subies I have owned - now 4 in total. I am the 3rd owner, it has never been in an accident, there are two SMALL dents on the rear passenger door, and that's it. There are no scratches, dings, nicks etc anywhere else on the car. When I bought the car from the second owner, he had his brother who owned a body shop respray the front bumper, hood, side skirts and rear bumper so its not rock chipped to hell. I get compliments all the time for how clean it is and no one has ever asked if its been resprayed, the match is perfect! The only other flaw is a small rust bubble on the passenger fender. It has been there since I bought the car, never gotten worse and it is easily fixed by replacing a fender hence it didn't prevent me from buying the car. That said, I am anal about my cars and never once has this flaw bothered me enough to even spend $150 to replace it.
The interior is in equally awesome shape. The seats are perfect, there are no signs of wear anywhere. The the dash, carpet, steering wheel, shift boot etc are all mint. The only flaw is the driver side rear door card has 3 scuffs in it. Hopefully you can sense my attention to detail.
I can't think of anything else in which mileage and/or age would be a concern, but if you can, don't hesitate to ask. If you want to setup a time to meet up/see the car etc, just let me know. I have nothing to hide about this car and will answer any questions you may have.
Price - $11,000 (This includes all stock parts I have for the car)
Engine Modifications:
ej257 short block (internals all stock)
08 sti 11mm oil pump
sti oil pan
arp head studs
tgv deletes
Turboxs fmic
Turboxs short ram intake
HKS SSQV BOV
DEI Reflecta Gold Heat Wrap on charge piping
IHI VF-22 Turbo
grimmspeed ebc
Modded N/A forester injectors - flow approx 725cc
Walbro 255lph fuel pump
No-name red silicone inlet hose
Invidia bellmouth catless downpipe - with wideband bung
APS 3" single tip catback
Invidia catless uppipe
One-step colder NGK Iridium plugs
05 sti radiator
04 sti headers - tapped for egt gauge
rebuilt and decked stock wrx heads
Amsoil 5w30 (have changed every 3500 since break-in)
re-flashed using open-ecu by justboosted02
Transmission Modifications:
04 wrx transmission (replaced only because I was able to swap it for the cost of tranny fluid and my time and had half the miles that my original tranny did)
Oem short shifter
Amsoil Severe Gear tranny fluid
Exedy stage 1 organic clutch
Suspension/Handling Modifications:
Stock WRX struts with 30K on them
04 sti springs, tophats
scooby921 spacers
05 wrx steering rack
whiteline steering rack bushings
Wheels/Brake Modifications
17x8 Rota Boosts in Bronze - wrapped in 235/40/17 lm-25 Kuhmo Ecstas ASX - Ultra high-performance all-seasons
Kics r40 open end extended lug nuts
rolled rear fenders - no rubbing issues
07 wrx front 4pots
h6 rear brake upgrade (bracket and rotors)
hawk hps pads front and rear
goodridge stainless steel brake lines
super blue racing brake fluid
Exterior/Lighting Modifications:
Genuine jdm sti foglight covers
Genuine jdm sti wagon black chrome hid-projector headlights (complete with headlight leveling motors, leveling switch) - Powered by ballasts taken a 350z and all connected via plug and pay harnesses that I made myself
Painted stock side skirts
2.0Tawd is offline   Reply With Quote
Old 04-22-2011, 02:38 PM   #2
2.0Tawd
Member#: 92415
2011 OBP WRX
Friday Bump!!!
Old 04-23-2011, 01:47 PM   #3
N8WRX
Member Sales Rating: (13)
Member#: 99395
2015 Impreza WRX
World Rally Blue
ill buy those fog covers off you if you want to make some moola send me a PM if your interested. I could even swap + cash on my end if you want i have faux carbon fiber ones look identical to yours i just want blue.
N8WRX is offline   Reply With Quote
Old 04-24-2011, 10:15 PM   #4
2.0Tawd
Member#: 92415
2011 OBP WRX
Thanks for bump and offer, but they are staying with the car....they took a long time to find used and I bought them the second they were posted. Good luck with your search!
Old 05-11-2011, 09:26 PM   #5
2.0Tawd
Member#: 92415
2011 OBP WRX
Sold!!!
Old 05-11-2011, 09:41 PM   #6
eastcoastbumps
Member Sales Rating: (12)
Member#: 29201
BMW M3
Honda S2000x2
You can buy those fog covers new at the dealer. You'd just have to get them painted WRB, since the 2.5RS never came that color.
eastcoastbumps is offline   Reply With Quote
Old 05-23-2011, 09:07 AM   #7
Donzo
Member Sales Rating: (62)
Member#: 95337
2012 Jeep Overland
Pics?
Donzo is offline   Reply With Quote
Old 05-23-2011, 09:12 AM   #8
Donzo
Member#: 95337
2012 Jeep Overland
Never mind, they're blocked at work but I pulled them up on my phone.
FS : CT: 2002 WRB Hybrid 2.0Tawd Private Vehicle 'For Sale' Classifieds 12 05-11-2011 09:25 PM
FS : FL : 2002 WRB Hybrid Wrx!!! vinth Private Vehicle 'For Sale' Classifieds 6 04-13-2011 05:01 PM
NJ: FS/FT 2002 WRB WRX hybrid $11000 02scoobydoo Private Vehicle 'For Sale' Classifieds 36 10-15-2009 04:07 PM
Ct: 2002 Wrb Sedan - Low Miles - Nice Mods WMAWRX Private Vehicle 'For Sale' Classifieds 13 08-28-2007 01:04 AM
F/S CT: 2002 WRB WRX sedan - $13.5k iwanbo Private Vehicle 'For Sale' Classifieds 7 09-16-2006 01:06 PM
