Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 07-18-2002, 05:34 PM   #1
Member#: 1101
04 STi
like theres a choice BLUE
Default 5th gear pops out and reverse feels like its binding??
Anyone encounter this before? Is it a bad 5th gear synchro? if so does anyone have any idea what the cost of repair is going to be, wish had some more warranty left.
Boom is offline   Reply With Quote
Old 07-18-2002, 05:50 PM   #2
Member#: 8273
2006 WRX Wagon
Default Main Shaft Nut
Sounds like another 'Main Shaft Nut' case.
Do a search on the above. You should find a weath of info on it.
I had the same problem. Warrant took care of it.
If you are out of warrant, there is a chance your dealer may do it 'goodwill' because it is a well documented problem.
If not, then you are looking at some fairly serious labor costs. They need to remove the transmission, split the case and replace the nut. The funny part is the nut only costs a couple bucks, labor will be much more than that!
As for the reverse binding... I'm not sure.
goobie is offline   Reply With Quote
5th gear popping out... DyeOwnsMe Normally Aspirated Powertrain 3 02-09-2005 06:30 PM
5th Gear Popping Out Problem North Ursalia New England Impreza Club Forum -- NESIC 12 02-09-2005 04:54 PM
5th Gear Pops Out Santo Domingo 2.5 RS Transmission (AT/MT) & Driveline 3 05-05-2004 01:44 AM
Need help finding the 5th Gear Pop Out TSB lamron Transmission (AT/MT) & Driveline 9 06-05-2002 08:36 PM
5th gear popping out at cruising speeds.. WRC666 Normally Aspirated Powertrain 18 08-29-2001 06:59 AM
