Old 07-18-2002, 06:05 PM   #1
danci1973
Member#: 19018
1995 Legacy Wagon
Default Code 11 - Crank Angle Sensor
I have a constant problem with the crank angle sensor.
After I get the car to operating temp. and stop for 15-20 minutes, it won't start again. Using the 'memory read' connectors I got the code 11 - crank angle sensor.
If I leave the engine to really cool down or if I start it while it is still hot, it starts OK.
If I touch (or knock upon) the sensor (with my hand or a tool) and try to start the car again, it usually starts (sometimes I had to 'knock' it a bit more), which leads me to bellieve it's just a bad contact.
I've checked the connector and cable, I even took it apart, cleaned it up, re-soldered it, but the problem persists.
Now a have a couple of Qs:
1. How much should this sensor cost (approx.)?
2. Could I possibly use some non-OEM sensor and which?
3. Is it possible to take the sensor apart without destroying it? I suspect a bad soldering job somewhere inside the sensor.
Thanks, D.
danci1973 is offline   Reply With Quote
Are all EJ Crank angle sensors the same? electricpork Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-10-2006 01:09 AM
EA82T code 11 crank angle sensor help please!!! iluvdrt Pre-2002 Factory Turbo Powertrain 4 11-02-2005 05:25 PM
WTB: MAF sensor and crank angle sensor CMJ Private 'Wanted' Classifieds 2 04-06-2005 01:16 AM
Crank Angle Sensor and Cam sensor DonkeyPunch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-02-2005 09:59 PM
Part number - crank angle sensor danci1973 Legacy Forum 2 10-22-2002 03:04 AM
