#1 |
Member#: 15144
Vehicle:93 impreza orange |
what is intaled in getting getting a heltech e6 to run with a wrx engine ?
I need to know what i need to run with a haltech, like for ignition and if i need to have some make a cps for it. if any body went with this system give me a hand thanks
#2 |
Member#: 7113
TXIC
Vehicle:2008 Spec B DGM |
I can answer some. What kind of ignition does the WRX engine run? Also does it still use cam angle and crank trigger for timing? I know the Haltech doesn't work with the fine-tooth crank trigger on some Subarus. It's the odd 6-tooth one that I have that works just fine with the Subaru ignition set-up in the programming. The real bear is getting idle control working properly
![]() ~Garrett |
#3 |
Moderator Member#: 922
Vehicle:04 FXT Red |
Is it an E6, E6S, E6K....? The E6K will use a Subaru crank trigger as is, but the rest will need a CPS setup fabricated for it.
| Thread Tools | |
| Display Modes | |
| Haltech e6k | Audipwr1 | Normally Aspirated Powertrain | 2 | 09-11-2001 08:20 AM |
| Haltech e6k | Audipwr1 | Normally Aspirated with bolt-on Forced Induction Powertrain | 6 | 09-10-2001 04:28 PM |
| haltech - haltuner- anyone using this air fuel monitor | Tex-WReX | Factory 2.0L Turbo Powertrain | 2 | 07-17-2001 01:56 PM |
| Haltech installation//tech | Turbo | Factory 2.0L Turbo Powertrain | 5 | 04-25-2001 09:17 AM |
| Haltech and Wolf engine management Q's... who has one? | rao | Normally Aspirated Powertrain | 4 | 11-22-2000 12:52 AM |
