Old 04-20-2011, 12:34 AM   #1
JordanM9
Member#: 273214
2013 WRX Limited
CBP
Default Cobb Stage 1 +sf intake 93 octane concerns
I am worried about how my car is running. This is a third gear pull that I logged tonight. Hoping that it is not any major problem, but before the intake I didn't have any knock once I was getting higher into the rpm. Thanks for any help.
https://spreadsheets0.google.com/spr...WMRW50-w#gid=0
^this is now public for everyone to view
JordanM9 is offline   Reply With Quote
Old 04-20-2011, 08:53 AM   #2
xlsupreme
Member#: 120789
2005 USDM STi
you need to change the permissions on this file, we don't have access to it
xlsupreme is offline   Reply With Quote
Old 04-20-2011, 09:12 AM   #3
JordanM9
Member#: 273214
2013 WRX Limited
CBP
Thanks for catching that!!
Old 04-20-2011, 09:36 AM   #4
xlsupreme
Member#: 120789
2005 USDM STi
well, I'd say this makes sense. An intake should make your engine more volumetrically efficient, if designed well, and that tends to happen in the upper rpms from the dynos I've seen, so I'd wager you need to pull a bit of timing from 5500 up to 6500.
Or if you're not doing your own timing adjustments, then PM lance @ cobb, or just wait until they chime in. I'm sure they wouldn't mind helping you get your map straight. I'd say it does need attention though, as that high rpm knock in steady state conditions is generally unhealthy.
Old 04-20-2011, 09:39 AM   #5
JordanM9
Member#: 273214
2013 WRX Limited
CBP
Thanks, I may just flash to the 91 oct map to be safe.
Old 04-20-2011, 09:44 AM   #6
xlsupreme
Member#: 120789
2005 USDM STi
That's certainly a reasonable move. You may want to log another few pulls at different temps and see if it was related to that (i.e. morning, afternoon, etc...)
Old 04-20-2011, 11:07 AM   #7
JordanM9
Member#: 273214
2013 WRX Limited
CBP
Hoping the people at Cobb have a little insight
Old 04-20-2011, 11:58 AM   #8
Cobb Tuning
Member#: 4803
While not ideal, seeing minor learned corrections like that from time-to-time is not uncommon over time. Switching down to the 91 octane mapping may help eliminate those corrections and provide some peace-of-mind. Thanks for your questions and please let me know if I can be of assistance in any other way.
Best regards-
Lance
Old 04-20-2011, 12:00 PM   #9
JordanM9
Member#: 273214
2013 WRX Limited
CBP
Thanks I am going to get a few more logs in today and see if there is any change.
Help switching open source stage 2 to stock map!! Corpuz04 Mid Atlantic Impreza Club -- MAIC 61 04-23-2011 10:51 AM
How to Diagnose OBD-I CEL? Bad gas mileage on 93 Legacy icudruln Normally Aspirated Powertrain 3 04-20-2011 02:43 PM
Running STi pinks on the stage 2 map. iant333 AccessPort 3 04-20-2011 08:25 AM
Edited - Please Delete hieu1004 Proven Power Bragging 3 04-19-2011 08:36 PM
Stage I with just CBE CASubieFan Newbies & FAQs 18 04-19-2011 11:54 AM
