Old 04-20-2011, 11:59 AM   #1
YtDiamond05
Member#: 148191
2008 F350
Default Fp Hta Gt3794r
Anybody running this turbo? Thinking of using it on my setup and want to see what numbers people are putting up with this and how the driveability is. I see tons of evo's running it, but no subies.
YtDiamond05 is offline   Reply With Quote
Old 04-20-2011, 03:43 PM   #2
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
because to make use of this turbo you will have to rev to at least 8500.Look at the dyno sheet on fp's sight with awd's evo they are running it out to 8800.
john 1badSTI is offline   Reply With Quote
Old 04-20-2011, 05:02 PM   #3
hybooststi
Member#: 83843
STI/EVO
There are Not tons of evos running this turbo. Its considered a straight "drag" turbo, on a subie that only revs to 7500, it will be pointless.
Its a very well designed turbo for the straight line guy, imo I rev my evo to 9500 and havent even considered it probably because theres not enough open road around pwc without worrying about 5-0
It will make 900 whp if your motor is set up for it. AWD Motorsports went 8.80's with it in a street car. You could compare it to a pte 6765 but its a little bigger.
hybooststi is offline   Reply With Quote
Old 04-20-2011, 09:19 PM   #4
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
500lbs @ 5000rpms? Thats on a 2.4L evo.
On a short runner manifold this thing would work very well on a properly setup car. ER was reporting 250rpm later spool over the HTA3586.
project_skyline is offline   Reply With Quote
Old 04-20-2011, 10:18 PM   #5
Skully
Member#: 48990
98 Impreza RS
RBP
****... this is little girls stuff... i say run it! that turbo will make full power on a efficient subaru engine around 5800rpm. and i mean that is whatever boost pressure your wanting to run at 18+ psi. I ran a 67mm turbo on my 2.5RS when i had it and absolutely loved it. I spun 8000rpm out of the engine and had full boost before 6k. Made for great street setup.
Skully is offline   Reply With Quote
Old 04-21-2011, 09:23 AM   #6
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Maybe on a evo - on a subie the hta3586 comes on 4k
Visconti is offline   Reply With Quote
Old 04-21-2011, 09:46 AM   #7
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
if you catch 30psi at 5000rpm and redline at 8000rpm that is 3000rpm of peak power, and if you catch 30psi at 4000rpm and redline at 7000rpm that is 3000rpm of peak power...whats the difference...its pretty easy to get the 2.5 to run out to 8000rpm, and its not like there won't be any power before 5000rpm. no it won't be an awesome autocross turbo or anything like that, but different strokes for different folks...it all depends on your driving style, habits, and goals for the car...
amalgrover is offline   Reply With Quote
Old 04-21-2011, 09:53 AM   #8
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
there are tons of people driveing around on bigger turbos as dailys and are perfectly happy, i say go for it and let us know how you like it
seanathanq83 is offline   Reply With Quote
Old 04-21-2011, 10:57 AM   #9
amalgrover
Member#: 183480
2009 Forester XT
i agree...i had so many people tell me that the fpred 8cm was going to be too much lag for a daily driver, and man am i glad i didn't listen to them. i honestly love it and wouldn't have it any other way, and if i would have listened to everyone else, i would already be looking to upgrade to something bigger only 1 year later. really, once you learn your powerband and what gears put you in it at what mph, it drives just like any other turbo car...just takes a little getting used to and then you are good to go...
Old 04-21-2011, 11:17 AM   #10
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
^ on a car that AVCS you can make large turbos come on very fast.
I'd like to see a Subie with a 3794 - we have at least one at our shop that will be running one in the near future
Old 04-21-2011, 11:32 AM   #11
javid
Member#: 54304
04 STi
TopSpeed-dAng!
How do these connect to the uppipe? I have a full v-band setup now with tial hotside. Would this be plug and play or will I need a new hotside. Or would my 35r frame tial hotside fit on the 3794?
javid is offline   Reply With Quote
Old 04-21-2011, 12:00 PM   #12
em1bugeye
Member#: 208462
2002 GD2 WRX
Sedona RED Pearl
^^^^ If im correct, since this turbo is in a 35r frame, I dont see what the issue would be since your tial hotside is mated to the frame of your garret turbo now so I would go ahead and bet that it would fit no problem.
em1bugeye is offline   Reply With Quote
Old 04-21-2011, 01:48 PM   #13
evokiller89
Member#: 190916
2005 HTA sti
CGM
i think it will be a waste on a street subaru, been looking at this turbo for awhile for my evo and its just not worth it on a street/strip car. if you read ER post on evom its not just about spool. its also about how much boost you have to run before you make this turbo happy, he said that at 25psi it made 50whp LESS than his hta86 setup. and its even less attractive on a subaru because of the revs. you can pull an evo to 9500 with just a basic engine set-up 8500 on a subaru is pushing it without major head/oiling work from what ive heard. just doent seem worth it considering even ballz out its only good for 80-100whp over an 86 most setups wont even see 50whp over an 86 setup
evokiller89 is offline   Reply With Quote
Old 04-21-2011, 04:31 PM   #14
john 1badSTI
Member#: 77470
^^^^I agree ,I run the hta3586 and would be hesiatant to run anything bigger for street /strip use.
Old 04-21-2011, 06:00 PM   #15
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Don't be such a girl lol
Hrmm 3794
Old 04-21-2011, 08:15 PM   #16
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
What do you mean by comes on?
No offense but that 2.4 only gets revved to 8500, well within the limits of a good built suby motor. So its got plenty of power band. Ya its an evo but you suby guys do have 2.5l motors. The turbo is worth more then 80-100whp balls out. Awdmotorsports made 901whp @ 46 psi with very mild cosworth cams on stock ecu. Granted I'm throwing evo references out. But the OP didn't even list what his supporting mods were. For all you know its a sleeved 2.7 stroker that can handle more then 30 psi of boost.
The above thinking is usually while subaru guys are number 2 in most instances.
On a non-rotated setup aka front mount this turbo would perform insanely well. Far better then any 40r and most 42r setups.
Old 04-21-2011, 08:41 PM   #17
paikman
Member#: 43002
1990 BNR32 GTR &
2015 Evo X Final Edition
this car is far from a street suby, best believe
paikman is online now   Reply With Quote
Old 04-21-2011, 08:48 PM   #18
amalgrover
Member#: 183480
2009 Forester XT
im running my fpred at 30psi and 30* timing at redline on my daily driver without sleeves with no problems. with sleeves you shouldn't have any problems running close to 40psi as long as you don't go crazy with the bore. i think that this turbo can't be much worse, if any, than a 40 or 42R, and there are people that run those on street cars without issues or complaints. also, if it is a 2.3L destroked setup with built heads, there are guys running out to 9000rpm daily on those things...AND...if it is a 2.7L with built heads, you may be able to spool this thing sooner and you would still be able to run out to 8000rpm. lastly, if either one of these setups are run with decent cylinder wall thickness (sleeves) and headbolts, there is no reason you couldn't run it out well into the 30's daily, and i find it hard to believe that you wouldn't see quite a bit more than a 35R with this kind of setup.
Old 04-21-2011, 08:50 PM   #19
john 1badSTI
Member#: 77470
Hrmm 3794
OMG guido I cannot believe you of all people called me a girl.If you think it will work that well big money why don't you buy one,put it on your car and prove me wrong.lol
Old 04-21-2011, 08:59 PM   #20
YtDiamond05
Member#: 148191
2008 F350
Well, I'm ordering the turbo. We'll see how it works out. Motor is done and the trans is still being assembled. Motor is a hybrid, 2.5l block with 2.0l heads, cams, the usual things. Hopefully the car will make some power!
Old 04-21-2011, 09:02 PM   #21
john 1badSTI
Member#: 77470
well good luck and keep us posted of results.
Old 04-21-2011, 09:09 PM   #22
amalgrover
Member#: 183480
2009 Forester XT
any headwork besides the cams. the 2.0L heads may have a hard time flowing that much cfm in stock form...they will do it, but you will be limited in power gains without some headwork...
...either way, good luck and definitely post up results...
Old 04-21-2011, 09:53 PM   #23
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
I'm thinking about it !!
Old 04-21-2011, 09:59 PM   #24
john 1badSTI
Member#: 77470
well get on it brother and help with the r&d of whether or not this big 90lb/min turbo will work on a suby.
Old 04-21-2011, 10:04 PM   #25
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
about time someone is looking at this turbo. i have thought about getting it also, but no one running it to compare. im in decision between this and hta86. keep us posted.
i agree with john. need the shop to buy one and give us some numbers/info....
spoolinred is offline   Reply With Quote
FP HTA gt3076r sburck Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 54 07-10-2010 10:31 PM
FP HTA GT35 Turbo kato4276 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 06-30-2009 12:41 PM
FS: Feeler: PA , FP HTA Green 3" Anti-Surge 8cm^2 EWG Turbo < 500 miles Merp Engine/Power/Exhaust 26 05-13-2009 07:51 PM
FP HTA Green tested. AZScoobie Proven Power Bragging 216 11-10-2008 02:00 PM
FS: PA - FP HTA Green 3" inlet Mycues1982 Engine/Power/Exhaust 32 09-24-2008 03:41 PM
