Old 03-28-2013, 09:28 PM   #1
neo8222
Member#: 311321
2002 WRX STI
Default Final tune complete
Well, I got my final tune done to my bugeye TD06 20G, 27PSI, twin 250CC methanol nozzles, 25*+ of timing, 386 AWHP Smoothing level 5, Daily driver. Oh yeah... Here's the graph.
neo8222 is offline   Reply With Quote
Old 03-28-2013, 09:56 PM   #3
MrSlowbaru
Member#: 129231
2005 wrx
cgm
Nice 2.0l numbers
MrSlowbaru is offline   Reply With Quote
Old 03-29-2013, 07:48 AM   #4
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
What's the motor?
Old 03-29-2013, 10:49 AM   #5
Dr. octagon
Member#: 171127
2015 Subaru
Tell drunk man to find that terminator and rematch, props to the ex woodbridge native.
Old 03-29-2013, 05:29 PM   #6
neo8222
Member#: 311321
2002 WRX STI
Originally Posted by Zee Biker View Post
What's the motor?
That would be a stock EJ207 with AVCS enabled.
haha, yeah his car is stupidly fast now, drunkmans actually moving to south florida in a few month too, He got a job at gulf coast motorsports as a AWD pro-tuner.
Old 04-01-2013, 11:07 AM   #7
insaneimpreza
Member#: 83291
1998 RSTi
IAG Stg4 Extreme S366SXE
I had a similar build going, ran really strong for a long time despite the looming bearing issues. Keep the oil fresh as possible and it'll last awhile! I must've put 75+ passes on my setup at just under your power level before finally spinning a rod bearing.
insaneimpreza is offline   Reply With Quote
Old 04-01-2013, 04:52 PM   #8
bjohnson_55
Member#: 216580
more like 24psi
bjohnson_55 is offline   Reply With Quote
Old 04-01-2013, 05:06 PM   #9
Kdiethrich
Member#: 291212
Nice numbers
Kdiethrich is offline   Reply With Quote
Old 04-01-2013, 06:39 PM   #10
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Looks good and holds the power nicely. Nice boost spike to get the torque up and then a safe taper towards redline is perfect. This is last u awhile
Old 04-03-2013, 08:18 AM   #11
neo8222
Member#: 311321
2002 WRX STI
Yeah I'm thinking I'm at my perfect level for daily drivable and fun. After other projects and all are completed I may build a even stronger motor and go with a rotated setup, but that would be a while down the road.
Originally Posted by bjohnson_55 View Post
more like 24psi
ECU can only see 24PSI cause I haven't done the MAP sensor upgrade. We were using 2 external boost gauges to monitor the boost.
Old 04-04-2013, 02:32 PM   #12
Dirtyhobo010
Member#: 144170
02 ej207|6 speed
What brand of turbo is this? I have been looking at 20g's for my V8ej207.
Dirtyhobo010 is offline   Reply With Quote
Old 04-04-2013, 09:32 PM   #13
neo8222
Member#: 311321
2002 WRX STI
I have a factory location deadbolt TD06 20G with a 44 lbs/min compressor wheel. I also have a clipped turbine on it.
Later when I get another car to be a daily driver and I can "play" with the Subaru I plan on a large rotated turbo with a hybrid 2.5 build most likely running some form of race gas.
Old 04-05-2013, 12:45 PM   #14
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
We have a required format for posting results in PPB, mostly to get all of these engine and build questions out of the way. Please read this thread and update your 1st post with the required format at your earliest convenience. Thanks.
http://forums.nasioc.com/forums/show....php?t=1858764
Scooby921 is offline   Reply With Quote
