Old 03-25-2012, 01:00 PM   #126
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
more likely lifted the heads if he only torqued them to 80ft lbs. thats what you torque stock head bolts to lol.
what studs did you use?
NW2TONE is offline   Reply With Quote
Old 03-25-2012, 02:32 PM   #127
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
i tq'd my arp to 90#'s...let them sit overnight and retq'd them to 90 the next day.
maxpowr is offline   Reply With Quote
Old 03-25-2012, 02:50 PM   #128
Matt_H
Member#: 107000
2015 BMW X1
Originally Posted by TAPOUT View Post
The Mach V tune was unacceptable to drive. They did a tremendous job building the car, but the the tune was no where near the way it should have been. When I picked the car up from them last week, they had slightly detuned the car from the first tune, (Pulled a degree or two of timing), but on my way home in rush hour traffic, I had to restart the car over 100 times to make it home (28 miles). Every time I came to a stop, the car stalled. I did not drive the car again until I was able to take it down and have a second set of eyes look at the car. Mach V spent nearly two full days with my car on the dyno in the first go around to try to tune it. After all of the time they spent, the car wasn't right. They gave it to me, and it was pretty smooth to drive when you were balls to the wall, but it was not driveable with stalling issues that were corrected by upping the idle speed. I took delivery of the car with the first tune which was tuned to 28psi, and was the dyno chart I posted a couple pages back. I drove the car for about 500 miles pretty easy until one night I had a buddy in the car. He said he wanted to feel the power, and I launched the car from a stop sign, grabbed second and third only to see coolant squirting on my hood. We were only about 3 blocks from my house, so we drove it home and opened the hood. There was coolant all over the engine originating from the overflow container.
I went inside, and I started reading every thing that I could find relating to the problem, and it led me to believe that the head gasket was cooked. I drove the car around the block two times the next day and it appeared that the coolant would only get pushed out when the car was under boost. I took the car back to Mach V and they pulled the engine and sent it back to the machine shop. Jim Justice pulled the motor back apart after confirming the torque values of the head bolts (80 ft lbs) and he went through and checked everything. I called him and his initial conversation with me said that the head gaskets had indeed been compromised and that he suspected that there was too much temperature in the cylinders and that had caused the head gasket to go. The only times that the car was really under strain long enough for the car to get hot would have been on the dyno. The small amount of driving I had done to get to 500 miles included a nice long highway trip which was about 420 miles round trip and never really pushing the car since I had the wife and kids with me. Upon further inspection at the machine shop, Jim found that two of the wrist pins were not straight, and had to be replaced, and the heads were warped to hell and he had to take off nearly 2 thousandths to get the heads flat again. I am still up in the air as to what happened with the car to cause these problems. I have a really hard time believing that the brand new Cosworth heads would be warped out of the box. When I took the car to get a second opinion on the tune, Hybooststi was able to determine that the fuel trims were way off, and the timing was far too advanced. He downloaded the Stock ECU figures, and the injectors were set to 1250, and on the UTEC the stock injector size was set to 999 as was the injector size. Hybooststi changed the injector values to 550 and 1000 as they should have been, and the car began to idle perfectly. This is something that has not been right since the very first build 4 years ago when I bought an FP Green and had the car tuned at Turbo XS. Since then, the car has not had a sweet steady idle, and Hybooststi fixed my car's idle issues and had the car running 100 times better in less than 15 minutes from when I showed up. Immediately after fixing the injector values, he began to look at the timing values of the tune, and found it to be advanced 5-10 degrees too much. The Mach V tune had timing advanced 17-20 degrees at redline! According to the person that tuned it this go around, he feels that the tune was the cause of all of my issues. He feels the tune caused the temperature to get so hot that it warped the head from all of the dyno pulls and that Mach V was lucky it didn't blow up there, and that it waited until the first time I really pushed it to fail. That being said, I'm not sure where all the blame lies, but I know who paid for it.
With the new tune, we are running ~30 psi on pump gas. with much less timing and it just pulls and pulls. If we get some good weather tomorrow, I am going to try to get some video footage.
I'd love to have some feedback thoughts as to why a set of Cometic head gaskets that were machined to fit would fail at 500 miles with my brand new heads being warped. It was determined that the head gasket failure was on the head side, and not the block side.
Yikes! I've seen what KC can do from his Evo, and have heard about a few Subarus running his tunes.
Matt_H is offline   Reply With Quote
Old 03-25-2012, 05:34 PM   #129
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
Studs are all ARP. Jim at Justice racing torqued them. Not sure what the exact value is, but he just made sure they had at least 80 before tearing it down.
TAPOUT is offline   Reply With Quote
Old 03-25-2012, 09:34 PM   #130
Dr. octagon
Member#: 171127
2015 Subaru
his evo raped mach v's dyno.............He knows how to tune, my **** has always been good to go......but this ant about me.
Dr. octagon is offline   Reply With Quote
Old 03-26-2012, 11:55 AM   #131
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
i had almost this same issue happen with a build and tune a while back. after an engine build and tune, the car was great at full throttle, but would stall at every clutch-in stop or downshift. it was almost unbearable to drive the 3hr drive home. i actually called a friend to see if he could come and get me and the family because driving it was becoming a chore in any kind of traffic (and the wife was really starting to get pissed that this is the tune we got for $700 ...nothing like being worried and frustrated and then having a nagging wife and screaming kids on top of that ). i had a local speed shop that had done some subies in the past do my engine build, and then got my tune done at awdtuning. shortly after the tune, i pushed my headgasket (had the same explosion of coolant every time i would get on it). upon teardown, i found the arp's only torqued to 75ftlbs, and the timing in the tune was WAY over-advanced (like e85 type timing while running 92oct)...all this while targeting 26psi of boost on a 9.7:1CR motor. now, the arp headbolts are torqued to 90ftlbs, boost is targeting 28psi, timing is almost the same as it was on the 92oct tune, but now i am running E85 (you know...the proper fuel for that timing ). everything seems to be holding strong so far with about 8000miles on the setup.
...so hopefully for you, everything works out the same. i definitely can sympathize with your situation...
i have been following this thread from day 1 so...i really hope everything works out so i can actually see some decent results from this thing
amalgrover is offline   Reply With Quote
Old 04-03-2012, 08:23 AM   #132
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
Old 04-03-2012, 08:30 AM   #133
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Is that your cruise light flashing?
Abnormal is offline   Reply With Quote
Old 04-03-2012, 08:49 AM   #134
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
Yeah, I had an O2 sensor go bad a couple weeks ago. Started flashing right before we tuned it. Probably from being too rich for a while. I'll get around to replacing it in a week or so.
Old 04-03-2012, 08:55 AM   #135
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Aha. I was going to say, after all that talk of stalling and CELs and all that...
PS: Amazon.com for the O2. That's where I buy them.
Old 04-03-2012, 09:03 AM   #136
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
The car idles so nice now...hasn't stalled once since KC got to it. I also have over 50K miles on these O2 sensors. Plenty of racegas and other stuff has been through this thing.
Old 04-03-2012, 10:25 AM   #137
Clark Turner
Member#: 178047
02 WRX STI Spec C
Yes. These cars seem to idle nicely in limp mode.
C
Clark Turner is offline   Reply With Quote
Old 04-03-2012, 10:51 AM   #138
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
C
Your car would probably look like it was idling if we ran.
Old 04-03-2012, 10:54 AM   #139
Matt_H
Member#: 107000
2015 BMW X1
Old 04-03-2012, 10:56 AM   #140
Clark Turner
Member#: 178047
02 WRX STI Spec C
Funny post of the day!
C
Old 04-03-2012, 11:27 AM   #141
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
C
My other comment about "limp mode" would have probably resulted in a ban!
Old 04-03-2012, 11:51 AM   #142
Clark Turner
Member#: 178047
02 WRX STI Spec C
Yes. Being a prick on the forums does get you banned
C
Old 04-03-2012, 11:51 AM   #143
Dr. octagon
Member#: 171127
2015 Subaru
C
I must say........you act and "seem" like you know what you are talking about and doing.....but for someone who i would believe holds that characteristic...........you hate like a mother****er.
WHY?
Old 04-03-2012, 12:16 PM   #144
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
WHY?
He's suffering from "limp mode" envy.
Old 04-03-2012, 01:55 PM   #145
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
LOL why he so >
spoolinsti05 is offline   Reply With Quote
Old 04-03-2012, 04:47 PM   #146
05bluesti
Member#: 251804
05 WRB STi
C
Then how are you still here???
Every single post you make is bashing another tuner in some way, every person I know who has gotten a "tune" from you has nothing but bad things to say
Id rather be in "limp mode" in more than one way than ever have you touch my car
dont be a dick or **** and GTFO
/rant
sorry TAPOUT for ranting in your thread, thats a one time thing
05bluesti is offline   Reply With Quote
Old 04-03-2012, 04:57 PM   #147
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
No worries, I think we hijacked this thread from YtDiamond05 a bit anyways...
Old 04-04-2012, 02:21 PM   #148
Clark Turner
Member#: 178047
02 WRX STI Spec C
WHY?
Sorry. I was on the dyno all day yesterday. No hating. The guy posted his 02 sensor is not working and he his Check engine light is on. Limp mode turns the maf sensor off and will idle nicely.
Old 04-04-2012, 02:25 PM   #149
Clark Turner
Member#: 178047
02 WRX STI Spec C
Stop talking &$&$ on the forums and trying to slander. If you have a problem with me come see me. ]
My customers are happy with me and my Review scores show it.
/rant
Old 04-04-2012, 02:55 PM   #150
05bluesti
Member#: 251804
05 WRB STi
I already said I would never let you touch my car why would I waste time coming to see someone I have desire to speak with?
Come out to the eastside meet some time if you really wanna speak with me, won't be there this week, but should be next week
Or do you know several people that come out regularly have issues with you?
BTW, if you weren't such a blatant outright ******* I'd consider you for a tune
FP HTA gt3076r sburck Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 54 07-10-2010 10:31 PM
FP HTA GT35 Turbo kato4276 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 06-30-2009 12:41 PM
FS: Feeler: PA , FP HTA Green 3" Anti-Surge 8cm^2 EWG Turbo < 500 miles Merp Engine/Power/Exhaust 26 05-13-2009 07:51 PM
FP HTA Green tested. AZScoobie Proven Power Bragging 216 11-10-2008 02:00 PM
FS: PA - FP HTA Green 3" inlet Mycues1982 Engine/Power/Exhaust 32 09-24-2008 03:41 PM
