Old 07-18-2002, 11:38 PM   #1
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
Default CEL question
i got a CEL about 15 minutes ago. i had been driving for about 10 minutes, not hard driving just driving, and as im coasting through a parking lot at about 10mph with the clutch in and the engine idling, a CEL pops up. the car was before, and is now running like normal. no strange sounds or smells. i checked all fluid levels and the tightness of all my caps including gas cap, but nothing. i probably havent had my car over 4000 rpm since saturday night at the track, even then i only made 4 runs, 2 on nitrous, and it wasnt anything i havent done a million times before, so im completely dumbfounded as to what could be causing this.
so i wanna know if theres any way i can "get the code" without a diagnostic tool, and if anyone on here can check it for me?
jasona is offline   Reply With Quote
Old 07-19-2002, 12:20 PM   #2
Jademonkey
Member#: 9213
2000 RS
Red
Nope, you'll need a scan tool. Just take it to a dearership. On my old buick, I could just jump a few pins, and see how many time the light flashes. Depending on count, etc, you'd be able to tell what the CEL was on for. But with our cars....I don't think you can do that.
Jademonkey is offline   Reply With Quote
Old 07-19-2002, 12:46 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Doesnt kragen do free code checks?
Old 07-20-2002, 01:46 AM   #4
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
You can also take your car to Autozone, (if they have any by you) and they will get your code for you for free. Or, if you just happen to be planning a trip to Michigan I can pull the code for you
-Wes
RebelINS is offline   Reply With Quote
Old 07-20-2002, 03:20 AM   #5
jasona
Member#: 11786
2014 OB 2.5i 6MT
well i guess the car decided it was okay now cuz it turned the light off by itself
come to think of it, it came on right after i put my first couple gallons of 87 octane in about 3 months, and right after i put some more 91 in, it backfired like hell for a minute then smoothed out and turned off. perhaps the ecu was "used" to the higher octane, and when i ran those couple of gallons of low octane, it developed a little knock, setting off the light?
Old 07-20-2002, 06:31 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Even though the light is now out there is still a code stored in there and you should get it scanned to see for sure what caused it. When the light goes out it just means the problem that caused it to come on has not occured for three consecutive driving cycles.
Flashing cel question mikaust Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-24-2001 01:45 PM
CEL Question... Strafe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 12-14-2001 11:32 PM
CEL question? TurboSub Newbies & FAQs 5 11-23-2001 09:50 AM
exhaust/OBDII/CEL questions 2.0 guy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-03-2001 12:10 AM
