Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Exterior/Styling
Closed Thread
Old 04-20-2011, 01:36 PM   #1
Z1 Performance
Vendor Sales Rating: (43)
Member#: 9327
Default APR, Carbign Craft and INGS Aero Bits - Avoid the Pending Price Increase Sale!
APR and Carbign Craft have announced pricing changes effective May 1, so from now till end of April, we're doing a sale to help you avoid paying more!
APR products are made in the US, and are designed to be stylish and effective, without breaking the bank
Front Splitter
Their Front Splitter is a popular option for those who want to keep a stock bumper, but add a bit of flair to it. To combat the effects of front end lift, APR Front Wind Splitters are utilized to give extra traction and control in the front of a car. By creating a high pressure area on top of the wind splitter, high pressure air flow is restricted to flow underneath a car. With low pressure below the car, the effect of lift is reduced and a driver can gain from the extra traction and control.
Features:
■Carbon Fiber Reinforcement
All APR Front Wind Splitters are reinforced with sheets of carbon fiber.
■Fully Functional Undertray
Our Front Wind Splitters are not just add on cosmetic pieces. Every APR Front Wind Splitter completely covers the entire area below a cars front bumper. This allows for smoother air flow below the front bumper, creating more efficient downforce.
■Support Rods Included
Supporting every APR Front Wind Splitters are stainless steel Support Rods
These are available for all WRX and STi's, from 2002-2010. If you have an aftermarket bumper, APR can custom design a splitter for you. Contact us for details.
2002-2005 WRX and STi - $415 SHIPPED in the 48 states
2006-2010 WRX and STi - $435 SHIPPED in the 48 states
APR also offers a great looking carbon front lip for the 2006-2010 WRX and STi. Underbody components such as front air dams, undertrays, and rear diffusers are essential for maximizing aerodynamic performance. The APR Performance Front Air Dam integrates with the factory front bumper to:
- Reduce lift.
- Increase front-end stability.
- Improve high-speed cornering grip
This Front Air Dam also utilizes a built-in aerodynamic splitter design that creates a high-pressure region of air atop the protruding surface, further reducing lift and increasing net downforce. Uses factory mounting holes!
2006-2007 STi - $645 SHIPPED in the 48 states
2008-2010 STi - $660 SHIPPED in the 48 states
Brake Cooling Ducts
■Factory-like fitment
This vehicle-specific component is designed to match the contours of the vehicle's body, for a factory-like fitment.
■Carbon Fiber Construction
This component is formed in the autoclave at high temperatures using pre-pregnated carbon fiber manufacturing processes, for high strength and low weight.
■UV Resistant Coating
Each Air Duct is finished with UV-resistant clear-coat paint for resistance against various environmental conditions (take care of this as you would take care of your vehicle's paint finish - polish then coat with good-quality wax or synthetic protectant).
■Mounting Hardware Included
Screws, nuts and bolts are all included to allow you to install the APR Air Ducts to your vehicle.
Available for 2008-2010 STi - $325 shipped per pair
Formula GT Carbon Mirrors
Features:
All APR Formula GT3 Mirror housings are reinforced with layers of carbon fiber sheets for weight reduction and added strength.
■Wide Range of Adjustment
Every Formula GT3 Mirror include a left to right pivot arm at the mirror housing with an adjustable ball stub rod to allow a wide range of adjustment.
■Aerodynamic Shape to Reduce Drag
These carbon fiber mirrors are compact and aerodynamically shaped for a low drag coefficient.
■Billet Aluminum Bases for Easy Installation
Lightweight & durable billet aluminum mounting bases are specifically designed to factory specifications for easy installation and clean fit and finish.
■5.5" Wide Angle Convex Mirror Lens
Convex lenses are used on both driver and passenger sides mirrors to eliminate blind spots. Blue anti-glare mirror lenses are included to reduce reflections from headlight glare during nighttime driving. Please note: Blue anti-glare mirror lenses found only on 5.5" wide APR Formula GT3 Mirror housings.
All screws, bolts and mounting gaskets are all included to allow you to install the APR Formula GT3 Mirrors to your car.
Available for 2002-2007 WRX/STi - $280 Shipped per pair
Carbon Radiator Cooling Panel
This is the best fitting one we've come across to date!
Available for 2002-2005 WRX/STi - $132 Shipped
Rear Diffuser
One of the most popular pieces by APR. These rear diffusers are offered in both carbon or fiberglass, and really dress up the back end of your Scooby. Diffusers work in conjunction with other aerodynamic components of a car to help produce downforce. Because a car displaces air as it moves forward, the air molecules in the rear of the car get disrupted causing a vacuum of low pressure air.
To help channel the high speed air flow coming from underneath the car, diffusers redirects the high speed air flow to transition smoothly transition into the low pressure vacuum in the rear. This encourages a smoother flowing air flow underneath the car and allows better performance from other aerodynamic components such as aerodynamic wings
Available for 2002-2007 WRX/STi - Carbon - $724 Shipped in the 48 states; Fiberglass = $589 Shipped in the 48 states
Rear GT Adjustable Spoilers
Gurney Flaps, risers, and wing angle indicators are also available as options for the GTC 300 and GTC 500
Each GTC Series airfoil is composed of lightweight and durable carbon fiber reinforced polymer (CFRP) or fiber reinforced polymer (FRP) composite materials. CFRP models contain pre-pregnated woven carbon fiber sheets for superior strength and low weight. FRP models contain woven pre-pregnated glass fiber sheets for high strength at reasonable weight. All CFRP and FRP airfoils are made using pre-pregnated composite manufacturing processes (i.e. high-temperature autoclave and vacuum bagging) in high-quality aluminum molds.
Supporting the airfoils are 10mm "aircraft grade" 6061 billet aluminum pedestals that come in a flat black powder coat finish.
GTC 300 (13 inches tall, available in 61" or 67" wingspan) - Carbon = $1390 Shipped; FRP = $995 Shipped
GTC 500 (13.5 inches tall, 70" wingspan) - Carbon - $1483 Shipped
GTC 200 (10 inches tall, 59" wingspan) - Carbon - $785 Shipped
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Garage Sale on Lots of Parts!
- check out the blog!
Z1 Performance is offline
Old 04-20-2011, 01:46 PM   #2
Z1 Performance
Member#: 9327
Carbign Craft is also based in the US, and makes carbon accessories for your WRX/STi
Carbon Alternator Cover
$112 shipped - available for 2002-2007, and 2008+ WRX/STi
Carbon License Plate Backing Panel
Available for 2002-2007 WRX/STi - $134 shipped
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Old 04-20-2011, 01:49 PM   #3
Z1 Performance
Member#: 9327
INGS Aero for WRX/STi
Contact us for individual component, or full kit pricing on INGS. For orders outside of the 48 states, please include your full, complete address
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Old 04-28-2011, 09:16 AM   #4
Z1 Performance
Member#: 9327
up top
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Closed Thread
Nationwide Lowest Prices: Seibon Carbon, Craft Square, APR, Carbign Craft & More!! CVR Motorsports Exterior/Styling 458 10-05-2010 06:21 PM
NEW RELEASE! C-West Kit for 08+ STi & APR/Carbign Craft/Seibon On Special!! Fizz Autosports Exterior/Styling 102 07-05-2010 10:46 AM
APR/Carbign Craft/Seibon On Special!! Fizz Autosports Exterior/Styling 19 01-28-2010 10:13 AM
Carbon Fiber Sale! Seibon, APR, Carbign Craft, and more! WorldOne Exterior/Styling 17 11-18-2008 02:18 AM
USED APR/Carbign Craft CF Rear License Plate Trim jason.g Exterior/Styling 12 07-15-2007 11:02 PM
