Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 07-18-2002, 11:42 PM   #1
2.5RSimpreza
Member#: 21082
2000 2.5 RS
blue ridge pearl
Angry ECU reset, Exhaust and new Chip
I put on a new exhaust system on my 2.5 today and i decided to reset my ecu. The only way i knew of doing it was to disconnect my battery terminal. so i do that and when i reconnect it. my ECU seemed to be making a clicking noise like a selinoid was ticking. Im not sure if it was the ECU but it was under the dash. My stock cd player and turn signals and brake lights where flashing even with the car off, it eventually stopped and is running great but has anyone had the same thing happen to them, and in the future how should i reset the ECU?
I also wanted to know something about my exhaust, it is custom made 3 inch pipe about. with a flowmaster muffler, is this too big of an exhaust to run, and i would also like to know what kind of ECU or chip upgrade should i go with and what is it going to do for me?
2.5RSimpreza is offline   Reply With Quote
Old 07-19-2002, 12:49 AM   #2
nukeyfish
Member#: 7447
2001 RS
BRP
If you wanna reset ECU, disconnect negative terminal from battery and let it leave it 30 minutes or so.
Flashing light stuff is your keyless entry wants signal. Simply hit remote(lock/unlock) and it will go away.
Someone correct me if I am saying something stupid.
nukeyfish is offline   Reply With Quote
Old 07-19-2002, 12:19 PM   #3
Jademonkey
Member#: 9213
2000 RS
Red
Yeah, what he said...twice!
Jademonkey is offline   Reply With Quote
Old 07-19-2002, 05:23 PM   #4
Imprezive2002
Member#: 18872
2002 Impreza
Lightbulb aaaaaaaaaa ok
when exhaust or intake is added and you reset the ecu you will notice a difference?
Imprezive2002 is offline   Reply With Quote
Old 07-19-2002, 05:37 PM   #5
nukeyfish
Member#: 7447
2001 RS
BRP
You WILL notice engine is smoother,but you do not know if it comes from new intake/exhaust or just ECU reset or both. You don't really have to disconnect battery to change intake, I think.
Jademonkey, I am trying to be a "scooby specialist", so every time, I post same thing twice. j/k
Deleted
Old 07-19-2002, 11:18 PM   #6
meebs
Member#: 3251
2009 WRX Hatch
Question
noob question here... does reseting your ECU reset your clocks too? Does that little one in the dash run off that battery or does it have it's own?
I've been thinking of doing a reset... when i start up for the day engine will initially be at it's normla 1.5k warmup rpm, but then 3 seconds later drop to near death and then correct itself to 2k. Infact I have had it die once. Maybe because my parking lot has a slight incline back? hmm.
meebs is offline   Reply With Quote
Old 07-20-2002, 11:39 AM   #7
Jademonkey
Member#: 9213
2000 RS
Red
Deleted
Roger that good buddy!
Keyless entry- reset after ECU reset? sir_aspen_white Electrical & Lighting 1 04-22-2003 08:24 PM
('93-'01) Does an ECU reset change the way an auto tranny shifts? subymamma Impreza Forum 14 05-18-2001 11:44 AM
('93-'01) ECU reset? littleblue Impreza Forum 3 05-04-2001 01:00 AM
('93-'01) ECU reset causing me to run RICH ? bigbird Impreza Forum 5 04-10-2001 10:53 PM
ECU reset for '99 Liberty Andy_T Legacy Forum 0 01-23-2000 06:29 PM
