Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 04-21-2011, 12:08 AM   #1
subasurf
Member#: 192883
1995 E36
Red
Default Clutch noise/squeak
Hey guys, got a 2001 SF Forester with a squeaky clutch and it's doing my head in.
I changed the clutch about 18 months ago after wrecking it offroad. New clutch kit and bearings. Clutch works a treat but for quite some time now I've had this squeaking noise coming from the clutch. It's most noticeable when I'm idling and it goes away when I start to apply pressure to the clutch pedal.
The sound is just like this: *note this is not my video and the video gives no details as to what caused the problem*
Is this a common thing that can occur if a clutch is poorly installed? Too much play in the fork?
Gotta do timing belt in a week or so and I'm considering just pulling the motor, doing the belt and while it's out sorting out this annoying noise.
Don't mind pulling the motor as I've done it a few times and got it down to an art
subasurf is offline   Reply With Quote
Old 05-05-2011, 10:37 PM   #2
jts749
Member#: 281293
2006 WRX CGM
1993 Saturn SC2 turbo
Anyone know if this is normal or not, I have an '06 wrx that makes the exact same noise as in that video.
jts749 is offline   Reply With Quote
Old 05-06-2011, 11:13 AM   #3
ScoobiePower
Member#: 144147
Sounds to me like a bad pilot/ throw out bearing, when you push the clutch in it goes away that is a sign that it is the bearing.
ScoobiePower is offline   Reply With Quote
Clutch pedal squeak file_id Transmission (AT/MT) & Driveline 2 06-11-2003 03:02 PM
Annoying Clutch Pedal Squeak balrog Transmission (AT/MT) & Driveline 8 02-17-2003 10:55 AM
How do you get rid of clutch pedal squeak FatCatTurbo Transmission (AT/MT) & Driveline 6 12-11-2001 10:45 AM
('93-'01) Anyone have a clutch that squeakes SubaruEJ25 Impreza Forum 6 09-23-2001 08:00 AM
Clutch pedal squeak Texas25RS Texas Impreza Club Forum -- TXIC 2 08-14-2001 10:30 AM
