Old 07-19-2002, 12:29 AM   #1
180 Flip(Megatron)
Member#: 19039
02 EJ25
Midnight Blue
Default Nitrous engage question
Question,
How are all you nitrous injected guys using the system. I mean, do you engage it in 1st gear ever, above what rpm is it to late to use and exactly how much hp is a 50 shot. I have heard that it is not exactly 50, but a bit less? Lastly do you ever encounter knock after use , if so how do you handle that? All these questions are being asked because i am considering nitrous express, but leaning toward zex. Oh yea, for the zex guys at what rpm does it engage, and what kind of compitition(track, or street compitition) did it work in you favor for? I know that it only engages at open throttle.
Thank you
Megatron
180 Flip(Megatron) is offline   Reply With Quote
Old 07-19-2002, 07:13 PM   #2
tsfxRS
Member#: 8442
98 2.5 RS
blur of red
you answered your own question about what RPM the zex kit engages at. It engages at WOT so RPM for hte most part is irrelevant. I have heard that you should only have it engage above 3000 RPM in general. And if you go with the kit make sure you stay away from your fuel cutoff / rev limiter.
I have a 55 shot from teh zex kit running to my 98 RS. Ive used it on the street and will be using it next week at the track. I have it setup as normal to inject at WOT however the times that I have actually used it I use it from the launch in first and most times stop after my shift into 4th. I see no need in going that fast and it gives the other guy a chance to catch back up.
If you go with the notrous express kit you may want to go with a wet setup giving it fuel as well. The zex is a dry setup and takes into account fuel pressure somehow to try to assurre the appropriate mixture of nitrous and fuel. Im happy with my setup currently.
Fuel upgrades I did to make running it as safe as I could that you may want to consider:
High flow Fuel pump
Fuel Pressure riser
SAFC
2 stages cooler NGK plugs
EGT Gauge
Air Fuel Ratio Gauge
Upgraded fuel injectors (which should go in next week)
Any other questions lemme know via PM and i can see hwat i can do to help you out. If you get the zex kit My honest suggestion is to go through ebay its a ton cheaper. My friend has a shop and i got it for 60$ cheaper new than he could get it at his cost via someone on ebay I will give you their info if you contact me. (450$ ish I think)
tsfxRS is offline   Reply With Quote
Old 07-19-2002, 09:01 PM   #3
Ghomer1
Member#: 8091
2007 335i
Monaco Blue Metallic
What he said, but I have a bit more to add.
I don't have any of the fuel mods he has. From what Zex says about the system, the "brain" adjusts everything just fine. I did go one heat range colder on the plugs.
The system works, though. Kicks your butt in first and second gear. You can still feel a difference in third but not as noticeable. I think I'm gonna get rid of it and save for a WRX!!!!
Garret
Ghomer1 is offline   Reply With Quote
Old 07-19-2002, 11:55 PM   #4
tsfxRS
Member#: 8442
98 2.5 RS
blur of red
Ghomer exactly the car stock with a little cooler plug will accept the 55 shot find but I wanted to build it up to be on the safe side and also to run a little larger of a **** if I felt necessary
YOu have any 1/4 mile times? I have yet to run at the strip with the nos.
Old 07-20-2002, 12:29 AM   #5
Ghomer1
Member#: 8091
2007 335i
Yeah, I understand completely. I don't do the track...
Old 07-20-2002, 12:35 AM   #6
tsfxRS
Member#: 8442
98 2.5 RS
blur of red
IF I had the money....
@ 40$ a bottle i know where you can save some thats what im doing i havent had the nitrous hooked up in the car for a month or two at this point. Ive prolly saves 40$ a week at least hehe Just put it all back in today was going to run it but it rained.
Old 07-20-2002, 02:54 AM   #7
180 Flip(Megatron)
Member#: 19039
02 EJ25
Midnight Blue
Thank you all for the info, good information=informative decisions driving wise and purchasing wise. Thank you very much, and tsfxRS i will be in touch. Quick question, have any of you encountered knock after using nitrous, and if so is a little knock ok, or not. Is a knock sensor a good idea and or J&S?
Megatron
Old 07-20-2002, 10:13 AM   #8
tsfxRS
Member#: 8442
98 2.5 RS
blur of red
I personally dont believe I hae encountered any knock problems at all however that is one of my next purchases. Slow I dont know if ghomer has this same problem but in 3rd gear around 6200 RPM with the nitrous injecting I get a check engine light for Manifold Absolute Pressure Abuse.
Not a huge deal but annoying none the less
Old 07-20-2002, 10:15 AM   #9
Ghomer1
Member#: 8091
2007 335i
I've never seen any CELs with my car. No knock either. Just be sure to use 93+ octane fuel and one heat range cooler plugs.
She'll run smooth as a babys behind.
G
Old 07-20-2002, 10:18 AM   #10
tsfxRS
Member#: 8442
98 2.5 RS
blur of red
where are you injecting from exactly? how far away from the TB and is it a direct shot into the TB? That may be my issue. I shooting directly at the TB from the back of the stock airbox it has a direct line right in from about 6 inches away Maybe thats causing some pressure problems lol
Old 07-20-2002, 10:27 AM   #11
Ghomer1
Member#: 8091
2007 335i
Well, I have the AEM short ram and I know it says to be at least like 8 or so inches I think, but I'm honestly only about 4 away from the TB. It seems to work alright for me.
Garret
Nitrous install Questions Nettat Water/Methanol Injection, Nitrous & Intercooler Cooling 5 10-07-2009 09:24 AM
Clutch engagement question Lachlan Transmission (AT/MT) & Driveline 1 03-23-2009 03:26 PM
JDM STI nitrous setup questions. FederalAuditor Water/Methanol Injection, Nitrous & Intercooler Cooling 7 04-24-2005 01:47 AM
nitrous install question Nettat Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-22-2003 02:34 PM
Upgrade/Brake/Nitrous/Cheating Question JamesIV Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-13-2003 09:38 AM
