Old 08-21-2011, 02:44 AM   #26
RoidRage
Member#: 272471
2010 WRX FlareObody
Red
Just wanted to add that I am quite happy with this kit on my 2010 Wrx, I'm a tuning/driving noob, but it seemed to improve the grip up front and reduce under-steer, making it easier to rotate the back.
Ride is noticeably stiffer though, and I am running the soft setting for both.
All in all I highly recommend, great quality, and great price.
RoidRage is offline   Reply With Quote
Old 09-27-2011, 12:31 PM   #27
@NT
Member#: 207366
2009 WRX Sedan
I just installed mine this weekend. I get a squeaking/creaking noise from the rear when I go through bumps, dips, and driveways at an angle. More lube?
@NT is offline   Reply With Quote
Old 09-27-2011, 12:39 PM   #28
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Try tightening the endlinks.
phenryiv1 is offline   Reply With Quote
Old 10-05-2011, 08:59 PM   #29
ping
Member#: 67176
2011 WRX
creaking means more lube needed in the back
ping is offline   Reply With Quote
Old 10-06-2011, 07:14 PM   #30
catinthehat
Member#: 271408
2011 WRX
Sorry if this has been posted somewhere, but does this upgrade also stiffen up the suspension during hard braking? Or is this something left to coilovers...
Reason I ask is because a few nights ago I was driving home on the freeway at night and got cut off by a much slower moving car in the right lane. I think he must have been tired and just not paying attention to his rearview mirror. Anyway, I braked very hard (but not enough to activate abs), and the car was not planted during this deceleration. Car was rocking back and forth like a boat. I've done this in past performance cars I've owned/own in the past and the suspension does not go nuts under hard braking like this car...
catinthehat is offline   Reply With Quote
Old 10-06-2011, 08:03 PM   #31
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
I was a little unclear- did you experience a "pitching" forward, or a lateral rocking? These would help with rocking side-to-side, but won't do anything for nosedive under braking.
Old 10-06-2011, 08:36 PM   #32
catinthehat
Member#: 271408
2011 WRX
Sorry for not clarifying. But you are correct, side to side. So the sway bars do help with the lateral rocking under hard braking?
Old 10-07-2011, 12:50 PM   #33
2011OBPWRX
Member#: 296791
2011 wrx
It was this thread that made me order a set of eibach bars and the whiteline braces for a 2011wrx.
I guess it's a coincidence that you're a max.org vet, lol.
Great thread, thanks.
2011OBPWRX is offline   Reply With Quote
Old 10-07-2011, 02:24 PM   #34
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
They add lateral rigidity, which should help with your issue. Swaying under braking is due to some sort of force being applied unequally and off-axis, which creates an imbalance.
Old 10-07-2011, 03:01 PM   #35
Longarm
Member#: 132140
'11 WRX Hatch
SSM
Is an alignment required after install ?
Longarm is offline   Reply With Quote
Old 10-07-2011, 03:07 PM   #36
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
No. Only if you remove or monkey with the struts, tie rods, etc.
These bolt on using facroty point and do not require re-alignment.
Just be sure to do the install with the suspension LOADED. I used low-profile ramps. It was a pain to lay under the car, but you'd have to do that on ramps or jackstands.
Old 10-07-2011, 03:09 PM   #37
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
The benefit to not using anything about my vehicle in my username is that I can then use the same name on every forum. It is amazing how many people I see on a lot of different forums. The org was my first love, despite it falling downhill these days.
Old 10-07-2011, 03:15 PM   #38
jcarlson546
Member#: 209906
2011 wrx
dgm
From spirited driving, I can tell you that the stock brakes were very easy to over drive. I had a family medical emergency a few weeks back (thankfully resolved) and had to rush to the aid of a family member because I could get there 10 minutes faster than police or fire/ambulance, and I found 2-3 places where the brakes just seemed inadequate to slow the car from speeds that it could attain all too easily. Oddly enough, the handling (before installing the swaybars) was not nearly the limiting factor that the brakes were.
I could not beat the Eibach setup for the price. If there are better bars out there, they don't seem to offer the bang for the buck that these provide.
I could not agreee more with you about the brakes!!! They are (at least to me) the only real dissapointment Ive had so far.
Is there any particular reason you didnt consider the perrin sway bars?? Im going to be purchasing a set of something coming up but am far from making a decision. And nice write up by the way
jcarlson546 is offline   Reply With Quote
Old 10-07-2011, 04:23 PM   #39
2011OBPWRX
Member#: 296791
2011 wrx
Agreed. Have barely visited the place in the last 2 years. 2004 up until maybe 2008 it was a very bearable place. Once kev and jane sold the place, it started falling hard.
Old 10-07-2011, 08:05 PM   #40
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
I considered a lot of brands. Perrin were in there, but the ones receing the most serious consideration (other than the Eibachs) were Whiteline (price and the irregular rust rumors cut them out), then RalliTek (a very close second). The Eibach won out on price and reputation, plus it LOOKED LIKE they came with endlinks. Even without them, the Eibach price was too good to pass up. Sometime you strike out when you try something new. This was not one of those times.
Old 10-07-2011, 08:49 PM   #41
jcarlson546
Member#: 209906
2011 wrx
dgm
fair enough. Im going to be doing some more research before making a purchase but youre write up was definitely helpful and put another option on the table for me. Thanks!
Old 12-14-2012, 07:43 PM   #42
cjbigcog
Member#: 297020
Just curious which end links anyone has used with the Eibach sway's. Also...any end link alignment issues?
cjbigcog is offline   Reply With Quote
Old 12-14-2012, 07:45 PM   #43
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
I have Kartboy. My choice was that or RalliTek, but rallitek were out of stock.
Old 12-14-2012, 08:48 PM   #44
cjbigcog
Member#: 297020
phenryiv1...Thanks. I have been reading a lot today about the dreaded sway bar "clunk". It seems that under torqued end link bolts are always the cause. Is yours quiet?
Old 12-14-2012, 09:04 PM   #45
BernR6
Member#: 233987
2012 WRX 4-door
Do you think aftermarket endlinks are necessary? I've seen a lot of threads where people suggest that stock ones may break with a thicker bar. I wouldn't mind saving some money if I could (I agree you do have to pay to play). I have '12 wrx 4 dr, and it will probably never see the track.
BernR6 is offline   Reply With Quote
Old 12-15-2012, 07:21 PM   #46
Lrn2Corner
Member#: 246224
2012 WRX Sedan
12 Rav4 V6
Take it with a grain of salt but from everything I have seen the endlinks are what complete the setup. Going with a set of tried and true kartboy endlinks will give you that comfort of knowing you wont have a failure.
You dont want to have an incident in the middle of autox or spirited dring and having to limp home when one of the skinny stock endlinks goes.
Lrn2Corner is offline   Reply With Quote
Old 12-17-2012, 11:39 PM   #47
Hextro
Member#: 276823
2010 WRX
I have these on my 2010 hatch and love them too. I recently got the whiteline rear braces but canít break through the 17mm bolt to get them on, and Iíve tried hard too.
I've done 1 track day with the car 100% stock and two with the bars on (brake pad and fluid upgrade too). Daily driving is noticeable enough, but man on the track these bars are huge. My limiting factors on 100% stock were brakes at times and the body roll on the turn heavy track I was on. Once these bars were put in my tires where chirping much much more, which meant the next weak link was tire traction and not my fear of flipping
With these bars on for over a year now and getting more comfortable on the track I upgraded the endlinks too. The Subie shop said I was wearing out the OEM links. Rallitek up front and whiteline adjustable in the back. The car does feel tighter again with them on. All 4 of my bushings are split at the top though and replacements arenít as simple as going to Eibach's site. Working on buying some soon but itís a $20-30 maintenance purchase.
The front bar doesnít come with a lateral lock/stop like the back has, thus I can move my bar about 2" by hand in the front. I'm still not sure how much movement is acceptable or even matters because the bars are designed for vertical movement. Wonder if anyone has run across this?
I agree with Lrn2 that the links complete the set, but you can for sure get started without them, enjoy the huge improvements of daily driving with these bars and save up for some endlinks (unless you plan to go straight to the track, but then you have a few other things to upgrade too).
Hextro is offline   Reply With Quote
Old 12-19-2012, 02:03 PM   #48
meelaud
Member#: 262244
2011 WRX hatch
WR Blue
so i ordered this set for my 2011 wrx wagon. the back one would not fit. at all. i have an aftermarket exhaust on there, which made it a little more of a hassle to work under the car. after removing the stock rear bar, i put it on top of the new eibach bar (with the hump up). i noticed that there is an additional 1/2" in length on the ends of bar. when i snakethe eibach bar under the car, I hit the bushing bracket on the car on either side. i am able to line up the bushings on both sides without any issue, but once i try to rotate the bar to get to the endlinks, one side will go in, while the other gets hung up by 1/2" on the bushing bracket. i've had a mechanic look at it too and they couldn't get it to fit either. i called both eibach and the place i ordered it from and they couldn't figure out why it wasn't working. of note though, the eibach logo (with the hump up) is right side up now.
i put the stock bar back on without any issue while i figure out what to do.
***UPDATE***
So the problem ended up being the way I was jacking up the car. After letting the rear wheels droop down, rather than using ramps, i had the clearance I needed to install the bars. The front was a breeze too.
The car is completely different now. Turn in is immediate and the body barely leans at all...and i'm on the soft setting for both bars!
meelaud is offline   Reply With Quote
Old 12-30-2012, 11:53 AM   #49
NotSoStock11
Member#: 262735
2012 STI Limited
Oddly, the printing (part number, Eibach branding) on the rear bar was upside down when the bar was installed properly. Eibach tech support confirmed that the "hump" in the rear bar should face up, and when installed that way, the writing was upside down. I had not paid attentio to how I removed the stock bar, so when I installed the new one with writing right-side up, it hit the exhaust. I called tech support and they got me squared away.
I just installed my Eibach sway bars (front & rear) on my 2011 wrx. I matched the rear bar to the stock setup with the hump up. The Eibach label and part number were showing correctly (legible). Maybe they fixed it or yours was just misprinted...I'm going to give it a test drive today because it was raining/snowing yday. Cant wait!
NotSoStock11 is offline   Reply With Quote
Old 12-30-2012, 01:10 PM   #50
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
They fixed it after I called and reported it. They had a whole run that was upside down, but that was about 2 years ago.
FS : Eibach swaybars for bugeye wrx Pauly HVS Suspension/Brakes/Handling 11 04-25-2011 06:52 AM
Looking for swaybar for 2011 wrx sedan mesarec Brakes, Steering & Suspension 2 03-28-2011 09:10 PM
09 Eibach Prokits for 2011 Wrx Sedan golfnut84 Brakes, Steering & Suspension 2 02-15-2011 11:33 PM
2011 WRX Hatch First Impressions carcassxd Newbies & FAQs 30 12-28-2010 04:23 PM
Rear swaybar for 2011 WRX Hatch hisdigness Brakes, Steering & Suspension 4 10-16-2010 04:15 AM
