Welcome to the North American Subaru Impreza Owners Club Wednesday December 17, 2014
Old 04-21-2011, 07:44 PM   #1
Ericfoust
Member#: 262352
2011 STi
Default Dyno Tune: 2011 STi 2.5L Stock Turbo and TMIC makes 296whp
Sorry I originally posted on my phone tryin to fill in info from memory right now.
Event: dyno pull
Ambient Temp: Unknown
Elevation: Unknown
Weather: Rainy
Track and Conditions: NA
Tires: Dunlap Stock STI 245/45/18
Car: 2011, STi sedan
Tuner: Mitch
Dyno Info: Mustang
Transmission: 6spd stock gearset
Gear: 3rd
Peak HP at RPM: 296 @5200
Peak Torque at RPM: 359 @5200
Baseline hp/tq for a stock on same dyno: Unknown
Target Boost: 20.5PSI
Target AFR: 11:1:1 I think Sorry Drawing Blank
Fuel: 93 unleaded
Engine/Power Modifications: Perrin Intake, Inlet, Headers, Uppipe, Downpipe, Catback, EBCS
Driveline Modifications: Perrin Differential Lock Down
Suspension Modifications: Perrin Strut Brace, SubFrames lockdown, Hard Front and Rear Sways and Endlinks, Whiteline Rear Sway Braces, H&R Sport Springs, Cusco Engine and Tranny mounts. Perrin LW Crank Pulley
Other Modifications: O.C. Allggerritta HLT's, Perrin Shifter Bushing. Samco Radiator hoses. Cusco Radiator Caps. JDM r205 Side Ornements
Dyno PDF
Http://dies.markleyent.com/.Dyno.pdf
Hope the change is better.
Ericfoust is offline   Reply With Quote
Old 04-21-2011, 08:14 PM   #2
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
hard to read.. is that 296/359?
FCmaniac is offline   Reply With Quote
Old 04-21-2011, 10:43 PM   #3
Ericfoust
Member#: 262352
2011 STi
yea sorry I could have scanned it better. or had them send it to me....
Old 04-22-2011, 01:27 AM   #4
pearljam11
Member#: 113335
13 WRB BRZ Limited
05 STi AgileTuned 320/352
ibmodasksyoutoreformat
pearljam11 is offline   Reply With Quote
Old 04-22-2011, 10:51 AM   #5
Scooby921
Merci Buckets
Member#: 88606
2011 GMC Sierra
'13 JCW
You win!
OP, please read this thread and update your 1st post with the required format. Thanks.
http://forums.nasioc.com/forums/show....php?t=1858764
Scooby921 is offline   Reply With Quote
Old 04-22-2011, 11:17 PM   #6
Ericfoust
Member#: 262352
2011 STi
Hope the update looks better
Old 04-24-2011, 08:59 AM   #7
JimmyOOOOO
Member#: 12647
2011 STi
Obsidian Black Swirl
300 WHP on Stock Fuel Pump and Injectors?
If so, thos bad boys gotta be static!
JimmyOOOOO is offline   Reply With Quote
Old 04-25-2011, 01:10 AM   #8
KrazyislanderSti
Member#: 277551
2004 Subaru STI
Java Black
Wow that's awesome with a stock turbo and injectors!
KrazyislanderSti is offline   Reply With Quote
Old 05-05-2011, 05:33 PM   #9
CoreyRED02
Member#: 19588
Nice numbers Eric. I think I see similar mods in my future... What are the injector DC's looking like?
Corey
CoreyRED02 is offline   Reply With Quote
Old 05-05-2011, 06:11 PM   #10
Speed
Member#: 67371
05 BUILT 2.4L STI
Originally Posted by Ericfoust View Post
Peak HP at RPM: 296 @3500
More like 5,240 RPM by looking at the graph. Nice results nonetheless.
Speed is offline   Reply With Quote
Old 05-05-2011, 06:18 PM   #11
WRXCJS
Member#: 142059
2010 STi
Would like to know IDCs if you can get them
Good numbers anyhoo!
WRXCJS is offline   Reply With Quote
Old 05-05-2011, 09:03 PM   #12
Ericfoust
Member#: 262352
2011 STi
Sorry I cant type on my iphone. I will look at my AP tomorrow at IDCs.
Old 05-05-2011, 09:33 PM   #13
Boxer4u
Member#: 115149
07 STI
Murdered & Loud
yes please look at the IDC's. probably over 95%. That is some huge power for a mustang dyno. Unless there was some huge change with the 2011 sti motor or turbo, or the CF is crazy high that is some insane torque.
Good numbers none the less.
Good luck with the car!
Boxer4u is offline   Reply With Quote
Old 05-06-2011, 09:53 AM   #14
cdoliver
Member#: 34084
2002 wrx
Numbers look about right. I made 296hp 354tq on my 2011 with an aem intake and tbe on a mustang dyno. Good job.
cdoliver is offline   Reply With Quote
Old 05-06-2011, 05:35 PM   #15
Ericfoust
Member#: 262352
2011 STi
They went to 100%
Old 05-07-2011, 09:34 AM   #16
slava from goshen
Member#: 152176
2001 2xImpreza 2.5RS
BRP/SRP
why not 4th gear? 3rd would make it read somewhat high.
slava from goshen is offline   Reply With Quote
Old 05-07-2011, 10:58 PM   #17
Ericfoust
Member#: 262352
2011 STi
Ya know it might have been 4th I didn't really ask I was super busy with work over my phone when they did the tune. I really didn't pay to much attention to them when they did it...... really just sat in the waiting room and trusted them....
Old 05-10-2011, 10:09 AM   #18
10046252
Member#: 242289
2010 WRX
LR. Stage 3
Great numbers. Dyno vid?
I just put the 2011 STI wing on my 2010 WRX. Love the look of the 11' STI sedans.
10046252 is offline   Reply With Quote
Old 06-06-2011, 01:29 AM   #19
cowboybebop521
Member#: 265741
2011 STi
out of curiosity, with numbers like those on stock turbo and injectors and ic are you running more duty cycles? and if so doesnt that put a lot of stress onto the engine as far as heat soaking.
edit, saw someone ask about the IDC. I thought running anything over 80% is a area likely for detonation.
cowboybebop521 is offline   Reply With Quote
Old 06-06-2011, 04:08 PM   #20
SVT_WRX
Member#: 164830
G61 III OVE 58e
Yep, 100% IDC's at your power level sounds about right.
I just tuned an 2010 STI same boost as you, intake, exhaust and IDC's where already at 95% at 11.3-11.4.
We made 275 304 on the Mustang using 91 octane.
EDIT: The torque was wrong. It made 304.
SVT_WRX is offline   Reply With Quote
FS : Invidia Subaru WRX Sedan 2008-2011 / STI Sedan 2011 sabruns02 Engine/Power/Exhaust 15 06-17-2012 06:14 PM
2011 STI Sedan Alignment ok? Pic inside ILSMKU2 Brakes, Steering & Suspension 4 04-24-2011 10:30 PM
Comparing 2011 STi Sedan to 2011 WRX Sedan DasWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-21-2010 08:09 AM
RallySportDirect 2011 STi Sedan. Photoshoot Part 2. Interior! RallySport Direct Member's Car Gallery 16 12-02-2010 02:39 PM
new with a question about 2011 STI sedan vs. previous STI sedans tommygsubie Newbies & FAQs 37 11-02-2010 01:16 PM
