Old 04-22-2011, 11:15 AM   #1
Rokkit
Member#: 84181
NASA #530 GTS2
Default Roll Center/Bump vs. Sways
So my conundrum for the day is trying to class in PTC for NASA's Hyperfest... my issue is I need to get 3 points back to slot into the class without problem.
Sway Bar Modification = 2 points
Bump Steer Kit = 2 Points
Roll Center Kit = 2 Points
Weight = +15 lbs = 1 point gain
So my thought is...
1) go back to stock sways - offset with spring rate
2) Delete bump/Roll and take off 15 lbs from competition weight.
3) Delete bump OR roll and add 15 lbs to weight.
Thoughts?
Info on the car; 2000 RS - 2600 lbs competition weight, ~190-200 wheel power, running 245 Hoosire R6's... uh leme know if you need more hah.
Rokkit is offline   Reply With Quote
Old 04-22-2011, 07:46 PM   #2
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
I like your thought. Keep the bump/roll
rjrutzky is offline   Reply With Quote
Old 04-23-2011, 03:42 AM   #3
scubtuner
Member#: 97066
option 3, you won't notice the weight change and you can use it in a needed to spot to help correct corner balance and the roll can be corrected by adding more camber. Just sharing.
scubtuner is offline   Reply With Quote
Old 04-23-2011, 11:21 AM   #4
68Cadillac
Member#: 95901
These two.
You'll need to raise the ride height to make up for the Roll Center Kit removal and add the 15 lb when you corner balance it. Low and inside the tire 'rectangle'. You need the sways to balance the rear to match the front.
68Cadillac is offline   Reply With Quote
FS : Whiteline KCA 313- Roll center/bump steer kit Cutler MAIC Private Classifieds 5 03-06-2011 01:59 AM
FS : Whiteline Roll Center Adjuster/Bump Steer Kit lundgren Suspension/Brakes/Handling 5 11-01-2010 12:56 AM
FS : Whiteline Roll-Center & Bump-Steer Kit (BNIB) chrisc75 Suspension/Brakes/Handling 13 08-30-2010 11:22 PM
FS/FT : Whiteline Roll-Center & Bump-Steer Kit (BNIB) chrisc75 Tri-State Area Private Classifieds 9 08-19-2010 11:08 PM
FS- Whiteline Roll-center & bump steer kit (NIB) 0010 Suspension/Brakes/Handling 0 05-15-2010 04:38 PM
