Old 07-19-2002, 03:07 AM   #1
Impreza94L
Member#: 20934
Default Subaru Ej20 2.0 Twin Turbo Engine
I have a 1994 Impreza L sedan, and I want to turbo it...and I came across a EJ20 2.0 TWIN TURBO ENGINE, its the whole engine itself, I dont think it comes with wiring harnesses, clutch, or tranny.... my question is..what is needed for the conversion? would i be able to use my stock clutch and tranny, i know i might get a new clutch, but wut about the tranny...isn't the EJ20 a 6-speed?
Thanks,
Impreza94L is offline   Reply With Quote
Old 07-19-2002, 03:19 AM   #2
Andrew
Member#: 1170
2005 STi
wont fit
Andrew is offline   Reply With Quote
Old 07-19-2002, 04:14 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
will not fit, it's out a B4...not gonna happen, and only the 2001 STi get's the RA 6 speed, all others recieve 5 speeds.
jeremy
Old 07-19-2002, 05:12 AM   #4
Impreza94L
Member#: 20934
so your saying just the tranny and clutch wont fit?....if i get the tranny and clutch for the engine...would the conversion be possible?
Old 07-19-2002, 05:15 AM   #5
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
oh god !!! they are saying your car will not like the engine in it because it WILL NOT FIT in the bay....i mean i'll go easy on u since its not in the faq but search a little atleast...there is one option to let it fit....lotsa money...but that is usually the answer to a lot of questions...you can go as fast as u want with enough money
akcel is offline   Reply With Quote
Old 07-19-2002, 08:38 AM   #6
omahasubaru
Member#: 1594
1995 WRX
2011 WRX
redo the turbo plumbing and make it a single turbo and it will fit.. as it being a twin-turbo it will not fit, unless you obtain a US spec right hand drive Legacy mail wagon.. The steering rack is in the way... and trust me the twin-turbo set-up is too complicated to re-work.
Jon
omahasubaru is offline   Reply With Quote
Old 07-19-2002, 10:57 AM   #7
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
4 negitive posts here is one positive
twin turbo engines are cheeper for the above reasons
but there was a WRX headder+uppipe onthe board for ~75 yesterday
for the cost differance you could easly match TT block and usdm WRX componets fro cheeper than most other ej20 packages
Old 07-19-2002, 12:28 PM   #8
Andrew
Member#: 1170
2005 STi
twin turbo engines are more expensive from my experiences. they sell JDM engines for 650 (single turbo) and the TT setup for 1150.
Old 07-19-2002, 01:02 PM   #9
RaceCarRiot
Member#: 6542
1997 Ver IV
a friend of mine has done this...you can re-plumb the turbo system to run on a single turbo, but you're going to want a better turbo and proper wastegate to go with it, since the single turbo will run at about 8psi. in that state of tune, flat out it wasn't much faster than my 1.8. plus it would promptly lose almost all power above 5500rpm, since there's supposed to be another turbo there to take over.
so unless you have a RHD legacy laying around, i wouldn't reccommend it.
-adam-
RaceCarRiot is offline   Reply With Quote
Old 07-19-2002, 03:10 PM   #10
Impreza94L
Member#: 20934
alright so basically a twin turbo wouldnt fit without modification, what about the EJ20DET, 220hp single turbo engine, would that fit perfect, and wut about, tranny and clutch again...do they have to be changed
Old 07-19-2002, 05:18 PM   #11
akcel
Member#: 10268
gc8 I ride ride 24s
ej20det ahaha snicker snicker.....no such motor code...but anyways..i believe kastle has a message for u...AT THE TOP OF THIS FORUM
Old 07-19-2002, 08:28 PM   #12
ac_gohan
Member#: 1903
2000 2.5 RS-T coupe
T3/04 Link'd 2 10 PSI
LOL -the DE my friend. But if you are looking into a usdm spec EJ20 look here www.i-speedusa.com mmm that would be nice a ej20 in a impreza L.
ac_gohan is offline   Reply With Quote
Old 07-19-2002, 11:21 PM   #13
Hondaslayer
Brain Stew
Member#: 4562
1998 Forester,lifted
1975 VW Westfalia tin top
If its a ej20det you probably looked at Nippon motors right. I wouldnt bother they dont know their heads from their @sse's tried to sell me a J-spec WRX motor with 240hp. turns out it was a legacy motor and most of it wasnt even there!
Oooooops forgot to put the "e" in heads
Old 07-20-2002, 12:38 AM   #14
Andrew
Member#: 1170
2005 STi
nippon motors is pretty good actually. they might not know what they have, but they do have some good engines. i believe Gery has bought about 10 motors from them and all have been great.
Old 07-20-2002, 12:52 PM   #15
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Buy a 2.2 liter engine from a 2000 Impreza L, It will fit and there seems to be less problems turbo'ing the 2.2 block versus the 2.5
Then add a Forced Air Technologies Twin Turbo kit
http://www.forcedairtech.com/FORCED-...TAGE4-KIT.html
BrysImpreza is offline   Reply With Quote
Old 07-21-2002, 02:42 PM   #16
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
um sorry your thinking of a 2.2l 91-94 turbo legacy block not a standard 2.2 block large differance
iirc that twin turbo setup had proublems with the two turbos fighting each other
twin turbo:
i shoudl have stated my point more clearly
remove twin turbo headders+turbos.. throw away
buy usdm headders+uppipe+turbo+downpipe+intercooler(all of which are cheep to come by)
Old 07-21-2002, 11:28 PM   #17
XT6Wagon
Member#: 524
04 STi
Actualy the EJ20TT header is 1/2 the same as the EJ20T one. The whole right side and center pipe is the same, its just the left collector and left uppipe are different.
XT6Wagon is offline   Reply With Quote
Old 07-22-2002, 03:08 PM   #18
Darby
Member#: 17175
2002 Outback Beaner
2 counts, right?
I thought of this as well and contacted Forced Air Technologies. They said the twin turbo Stage 4 kit is intended for the 2.5RS due to the larger displacement of the engine. They then recommended either the Stage 2 or Stage 3 turbo kits for the 2.2 liter engine.
Darby is offline   Reply With Quote
2.0 Twin Turbo Parts P914 Engine Management & Tuning 8 04-21-2012 07:07 PM
2.0 Twin turbo throttle body versus 2.2 NA throttle body reddevil Pre-2002 Factory Turbo Powertrain 3 06-23-2006 01:06 PM
2.0 twin turbo?? engine effect Factory 2.0L Turbo Powertrain 3 06-06-2006 12:49 AM
2.0 twin turbo for Subaru Legacy L???????? petusko Normally Aspirated with bolt-on Forced Induction Powertrain 4 03-17-2006 08:58 AM
2.0 Twin Turbo Boxer chello4life Subaru Conversions 4 11-22-2005 10:03 AM
Message Board Statistics All times are GMT -4. The time now is 06:54 PM.
