Old 09-21-2011, 07:51 AM   #301
Member#: 99778
Originally Posted by blakjak00 View Post
From what I see the LM450 keeps pace in spool up with the VF37, but it just keeps on going. Very nice to see!
The Billet LM400 matches the VF lowdown and then parts company quite early on.
The Billet LM450 isn't quite as good lowdown.
IMO the Billet LM450 is an outstanding turbo that doesn't lose that much down low to the VF, but still manages to give you 450bhp.
For a 2ltr this is pretty outstanding.
If you want to read something for a few hours (lol), have a look at all the documented work done on the car so far: http://bbs.scoobynet.com/projects-40...a-hawkeye.html
Shaun@ScoobyNet is offline   Reply With Quote
Old 09-22-2011, 07:40 AM   #302
666stars
Member#: 221364
2002 Wrx EJ207 Ver 8
Wrb Dccd 5 speed now!
That lm450 billet looks like the dream twinscroll . Such workmanship .
666stars is offline   Reply With Quote
Old 09-22-2011, 09:36 PM   #303
BigRigger
Member#: 129969
2005 Sti
Silver/Black
Great stuff, still waiting on USDM 2.5 numbers.
BigRigger is offline   Reply With Quote
Old 09-26-2011, 12:34 AM   #304
Pinned
Member#: 152707
Same here. I've got a VF37 now, and need to resolve a few small issues with my setup. If the blouch 2.5 twin scroll will provide a pretty big gain I may think about sending my turbo out, but I'd want to see back to back WHP graphs on a 2.5 rather than the BHP graphs on the 2.0.
Pinned is offline   Reply With Quote
Old 09-26-2011, 12:41 AM   #305
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
My vf36 is on the way out too, I'm not sure I want something bigger or just get a vf34 and swap my housings onto it.
decision time.....
JDwhiteWRX is offline   Reply With Quote
Old 09-26-2011, 10:55 AM   #306
Member#: 99778
Torque should dramatically increase on a 2.5. BHP should also increase for the same level of boost from a 2ltr to 2.5ltr. My figures for the LM450 Billet are based on a boost level of 1.6bar at peak power on a totally standard JDM 2ltr.
Old 09-26-2011, 11:27 AM   #307
Member#: 99778
Old 09-26-2011, 06:40 PM   #308
Rez1138
Member#: 211569
03 WRX Wagon VF36
WRB Blobeye conversion
decision time.....
didn't know you could just swap housings, that would make for a cost friendly refurbish.
Rez1138 is offline   Reply With Quote
Old 09-26-2011, 08:42 PM   #309
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Not sure if this will work or even be worth the hassle.
LIQUIDSK8S is offline   Reply With Quote
Old 09-26-2011, 10:05 PM   #310
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
I'm not sure exactly whats involved but the guy who tunes my car told me to do this and has like 30 years experience building suby motors and runs vf36 on his rally car.
Old 09-26-2011, 10:09 PM   #311
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
I think for the cost, you'll be better of sending it to Blouch. I dunno about using a VF34 in a VF36 housing, I'd ask someone who has worked with them.
Old 09-26-2011, 11:06 PM   #312
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
My understanding is the ball bearing vf series turbos are not rebuildable but the rear housings are interchangeable. A vf34 is basically the same as a vf36 with the exception of the twin scroll rear housing (P25). You can put a P20 or P18 housing on a vf36 in 5 minutes by removing the v-band, no reason why you cant swap the P25 housing onto the vf34 and have a vf36.
Also Blouch is a long way from Australia.
Old 09-27-2011, 07:45 AM   #313
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
I believe that they're interchangeable, but I don't believe that once the swap is done, the resulting hybrid is a VF36.
However, I did read that people ran this kind of swaps with no problems and I also believe that the actual differences between misc. VF series are small, in terms of flow and spool.
There is a lot of bad information on the net about the VF series, Especially that VF list of turbos, that was copied and pasted accross the planet on the internet, with IHI never bothering to at least set things straight.
Old 09-27-2011, 05:02 PM   #314
Deraj_53
Member#: 115139
Chapter/Region: HIIC
1998 2.5 RS
EJ207 Version 8 swapped
Gonna be sending in my vf37 hotside to Blouch in a few days. For the 2.5 XT-R TS
Tune date is set in late November. We'll see how it goes.
Deraj_53 is offline   Reply With Quote
Old 09-27-2011, 05:34 PM   #315
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Plus the VF36 is a titanium wheel.
Old 09-27-2011, 06:18 PM   #316
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
I plan on checking what the wheel is made of in my dead vf36, I have equipment at work to do this. Actually it would be good to find a dead vf34 and compare the two.
Old 09-27-2011, 07:15 PM   #317
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
If it's a VF36 it's titanium.
Old 09-27-2011, 07:31 PM   #318
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Please post your findings.
I've looked at the VF series description and I found:
"VF36, the compressor is titanium"... nonsense. This would make it heavier than the alloy it is.
"VF36, the turbine is titanium". I think, if anything, the turbine wheel and shaft are both a Titanium Aluminide.
Hyper has said that the VF36 is not Ti Al, that only the VF42 is.
I've looked at the photos of the VF42 turbine blades, it seems that the oxyde on those is a bit more red than usually on the (I think) Inconel normal aloy.
The VF36 also seems to me to have red-ish turbine blades.
I've asked the question to Forced Performance, they seemed to aggree that Ti Al oxydates a bit more red-ish.
Old 09-27-2011, 07:40 PM   #319
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
I can only measure down to around 0.1 wt% and some alloys do contain trace amounts of certain elements but it should give a good idea of the alloy used.
Old 09-27-2011, 08:02 PM   #320
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Subaru's website says the VF36 uses a titanium turbine wheel.
Old 09-28-2011, 01:39 AM   #321
Mortal2None
Member#: 190077
2006 Subaru LGT BP
I have a VF34 lying around for the sole purpose as a "swap" candidate if my VF36 ever blows. I can say for a fact that the VF52 compressor cover will swap on a VF36 or 37. I'll take my spare VF37 turbine housing and swap it onto my VF34 and let you know the results but from what I have seen, only the center cartridges vary in size. (BB cartridges are smaller than the JB ones) The wheels are for the most part the same. (With the main exceptions being the VF22/40/42 and 46) You can also easily turn a VF52 or VF43 into a VF37. I was talking to someone on here a while back that already did the VF37 turbine housing on a VF39.
Mortal2None is offline   Reply With Quote
Old 09-28-2011, 01:48 AM   #322
Mortal2None
Member#: 190077
2006 Subaru LGT BP
My next crazy though is this. Can't you overbore the VF37 turbine housing and weld in an inconnel "sleeve" so you could fit a 3076 CHRA in there instead of a 3071. hmmmmm.
(3071 is the largest you can fit in the stock housing)
Vlad,
You mentioned the aftermarket T/S housing you bought was larger? Was there more material around the turbine housing that could be machined over what the stock housing offers?
Old 09-28-2011, 07:41 AM   #323
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Yes, there is more material.
As far as Subaru's site writing about VF36, do you mean Subaru of Japan, back in the days of the GD upto 2007?
Old 09-28-2011, 08:08 AM   #324
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
I have done this twice, actually its very common, and the design of the compressor wheel changes over the years which I believe increases flow, but not the actual size
seanathanq83 is offline   Reply With Quote
Old 09-28-2011, 08:33 AM   #325
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Yes Subaru of Japan. It was in all of their pr booklets for the Spec C.
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco SCIC Private Classifieds 11 10-22-2010 01:09 AM
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco Engine/Power/Exhaust 9 10-02-2009 01:04 PM
twin scroll turbo with dual ball bearing options pjhe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 12-14-2006 09:40 PM
DP options for twin scroll turbo? John2.5RS Subaru Conversions 7 08-24-2006 12:14 AM
Anyone running a stock evo twin scroll turbo on a wrx? mcu81 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-09-2006 11:29 PM
