Old 02-16-2012, 01:21 AM   #601
WhatTurboLag?
Member#: 243992
2006 WRX TR
I've been disappointed with the ts options out there for the 2.5l cars. For a while I was dead set on doing a vf36/7 and being done but I didnt like the powerband or the power output. I looked at the upgraded stocj location ts turbos and they all were very disappointing.
WhatTurboLag? is offline   Reply With Quote
Old 02-16-2012, 01:59 AM   #602
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Originally Posted by MonkeyHermit View Post
Blouch/SC46 converted from a VF37 hotside on a 2.5L EFI Logics Stage 1 block. I was hoping for more power, but was told by Chris that the hotside is what's holding it back. The car feels nice, smooth, and responsive. It has power, but is slower than unclematt's setup by a couple hundred RPM's down low (when comparing our dyno runs on EFI's site).
What fuel?
LIQUIDSK8S is offline   Reply With Quote
Old 02-16-2012, 07:16 AM   #603
MonkeyHermit
Member#: 155242
2005 LGT
Originally Posted by Mortal2None View Post
Not bad #'s though for only 22-20 PSI. Looks like a sweet ride! The new Blouch hotsides are larger so there may be an upgrade path for you there but the SC46 billet wheel is happy in the 25-26PSI range I thought? Or did Chris feel that the housing was choking flow and could not turn the boost up any higher due to surging/creep?
Chris said the turbine housing is chocking flow and any attempt to increase boost resulted in knock. If I did get a larger housing, he said there might be another 20WHP or so. I think it might be difficult to get one of the new housings since they technically are for SC. I will probably keep it as is for now.
Originally Posted by LIQUIDSK8S View Post
What fuel?
93 Octane
MonkeyHermit is offline   Reply With Quote
Old 02-16-2012, 08:38 AM   #604
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
93 Octane
So this is on a legacy with the 2.5? What type of heads?
Old 02-16-2012, 08:59 AM   #605
MonkeyHermit
Member#: 155242
2005 LGT
Yup, on stock heads.
Old 02-16-2012, 10:14 AM   #606
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
I don't know much about the Legacy, what are the differences between it and the STi? I would assume a much less aggressive head/cam. In which case a STi would probably net another 20whp+.
Old 02-16-2012, 01:22 PM   #607
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
It looks pretty good for essentially a DOM 1.5XTR on 93 Fuel, especially at only 21 PSI. Seems odd that the car didn't like more boost, as it has a much larger Turbine than a Stock VF36/37.
Any plans for an E85 Tune later?
kayen is offline   Reply With Quote
Old 02-16-2012, 05:00 PM   #608
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
It's especially odd when you see the scoobynet guys pushing 24psi without issues. Still looks good for 93 octane and with TONS of power under the curve, it also holds well up to redline.
Old 02-16-2012, 08:28 PM   #609
MonkeyHermit
Member#: 155242
2005 LGT
I think the heads are different, but I'm not sure of the exact differences. It could be minor.
No plans for E85 anytime soon as there's no easy access near my area.
Old 02-16-2012, 10:10 PM   #610
Mortal2None
Member#: 190077
2006 Subaru LGT BP
Legacy engine has AVCS only on the intake valves. STi has dual AVCS and the STi manifold/TMIC setup. Otherwise the other differences are minor. (Not including the crappy stock LGT turbos)
Mortal2None is offline   Reply With Quote
Old 02-16-2012, 10:12 PM   #611
Mortal2None
Member#: 190077
2006 Subaru LGT BP
Probably more boost since the euro guys have 2.0's and not the USDM 2.5
Old 02-16-2012, 10:28 PM   #612
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
A couple of them are doing it with 2.5's
Old 03-02-2012, 10:37 AM   #613
juggers
Member#: 266120
Euros are all 2.5 the only 2.0l running these turbos are the JDM cars with stronger engines as standard.
juggers is offline   Reply With Quote
Old 03-02-2012, 02:36 PM   #614
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
The new ones are 2.5, but the ones before are all 2.0.
Old 03-12-2012, 07:17 PM   #615
Mortal2None
Member#: 190077
2006 Subaru LGT BP
Any updates? I might be the next one to take the plunge. I'm also going to try to test a Kinugawa 60-1 and Tomioka 20G both in T/S if funds allow and can get a break on the tuning/dyno costs.
Old 03-12-2012, 08:18 PM   #616
blakjak00
Member#: 225046
2000 2.5RS
Blue Ridge Pearl
Skip the tomioka, I have it.
blakjak00 is offline   Reply With Quote
Old 03-12-2012, 08:24 PM   #617
Mortal2None
Member#: 190077
2006 Subaru LGT BP
Is that the one with the late spool? Thanks for the heads up!
Has anyone else tried the 60-1/TD-06SL2 Kinugawa yet?
Old 03-12-2012, 09:12 PM   #618
blakjak00
Member#: 225046
2000 2.5RS
Blue Ridge Pearl
Not late spool, just low on power. My tuner has done a couple of them, he explained why it was low but it was over my head. Still put up 348 on the blacktop but should have made about 30 more. On this dyno, that is.
Old 03-12-2012, 10:45 PM   #619
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
350whp seems pretty reasonable for a 20G if you're running straight pump gas... Did you have meth or E85 or something else like that?
Old 03-13-2012, 09:26 AM   #620
MonkeyHermit
Member#: 155242
2005 LGT
I'll be going back to EFI for the larger Blouch hot side on the SC46 at the end of this month. Hopefully it will show some nice gains without sacrificing much down low.
Old 03-13-2012, 10:24 AM   #621
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Are you referring to the new Blouch Twin Scroll Hotside, that Scooby Clinic recently has been testing?
Old 03-13-2012, 10:31 AM   #622
MonkeyHermit
Member#: 155242
2005 LGT
The hotsides are made by Blouch. Whether they are the same as the ones SC are testing, I cannot confirm because I don't know. All I know is it is a slightly larger twinscroll hotside that I'll be getting.
Old 03-13-2012, 10:36 AM   #623
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
That's cool. I am going to assume it's the same Hotside as SC. Good to know someone can call Blouch and get the new Hotside and not have to send their own P25 housing to them.
Old 03-13-2012, 10:43 AM   #624
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Double post
Old 03-13-2012, 11:34 AM   #625
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Depending on how well the new hot side does compared to the old housings.......I may consider sending mine in for a update. It would need to be a big enough difference, but not a high price.
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco SCIC Private Classifieds 11 10-22-2010 01:09 AM
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco Engine/Power/Exhaust 9 10-02-2009 01:04 PM
twin scroll turbo with dual ball bearing options pjhe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 12-14-2006 09:40 PM
DP options for twin scroll turbo? John2.5RS Subaru Conversions 7 08-24-2006 12:14 AM
Anyone running a stock evo twin scroll turbo on a wrx? mcu81 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-09-2006 11:29 PM
