Old 06-27-2012, 09:56 PM   #751
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
Originally Posted by blakjak00 View Post
I second this, and echo the age-old saying "you get what you pay for."
yes but for some that 50hp increase over the vf37 is a larger jump than they might have ever made and will keep them happy for a long time. the 1700 dollars Blouch wants for the dom1.5xtr is a bit steep and out of most peoples range.
WhiteBgeye02 is offline   Reply With Quote
Old 06-27-2012, 10:40 PM   #752
blakjak00
Member#: 225046
2000 2.5RS
Blue Ridge Pearl
Double post
blakjak00 is offline   Reply With Quote
Old 06-27-2012, 10:44 PM   #753
blakjak00
Member#: 225046
2000 2.5RS
Blue Ridge Pearl
PNP your stock VF37 and add meth.
Old 06-28-2012, 11:02 AM   #754
mikeesingh
Member#: 30183
1996 GC8 WRX
[email protected], Blouch GT35
i have a used 1.5XTR / SC42 Billet Twin Scroll Turbo for sale at $1350 shipped
and also have a used 16g XTR twinscroll with new cast housing also available
only selling as new car is is a 2.5 engine and will be upgrading to a dom2.5
mikeesingh is offline   Reply With Quote
Old 06-28-2012, 08:28 PM   #755
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
Dam where the hell were you two months ago
murrdogg24 is online now   Reply With Quote
Old 06-28-2012, 08:45 PM   #756
ppayer38
Member#: 234407
04 Self-tooned
STi
I want the 16g XTR haha
Now could you take some measurment on the hotside for me?
Need the bolt spacing for the uppipe to see if the setup I'm looking at will work...
ppayer38 is offline   Reply With Quote
Old 06-29-2012, 06:54 AM   #757
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
So the old car was a 2.0 and you ran the 16g twinscroll XTR on it?
Would you mind sharing some info, as far as how soon did it spool and what kind of numbers it made?
Edit:
You posted that you did 317 WHP/403 CHP, in third gear, with 93RON+ Meth, which has to be a bit better than 93 US pump (AKI), since you were running 25PSI.
You did this in February, with intake temperature being 45F (7C) and had it fully spooled by 3700, according to your graph. You probably made something like 350 WFtlb of torque, judging by your crank dyno output sheet, on a dynamics dyno.
At 60F, which I consider the reference intake temp (my choice, nobody is obligated to accept it), I think you would have spooled 100 RPM later.
So, in a twinscroll, this 16g XTR TS with standard conditions (gear, intake temp, US pump fuel) is probably spooled at 3800 RPM, it does 340-350 Wftlb and probably 315-320 WHP.
Not bad, and very similar with my journal bearing 16g twinscroll.
I'm going to try to overlay the graphs with mine, to look at the boost threshold/progress, which is where the ballbearing really shows its advantage.
Old 06-29-2012, 09:07 AM   #758
tintnsound
Member#: 301593
2002 WRX EJ207 V8
Here's the updated numbers from my Version 8 EJ207 with PNP Blouch twin scroll 1.5XT-R 10 cm, 2.4" intake - track tune. 365 WHP 328 WTQ 93 octane
KS Tech 73 mm CAI
TMIC
Stock headers
Perrin intake hoses
DW850
Powerdyne
Blue is without AVCS at 17lbs of boost
RED is with AVCS and 20lbs of boost
tintnsound is offline   Reply With Quote
Old 06-29-2012, 05:33 PM   #759
mikeesingh
Member#: 30183
1996 GC8 WRX
Edit:
Yes 2.0, my 16gxtr was with bigger turbine but still hit 1 bar at 2600rpm and full boost by 3000rpm. Preferred it to the bigger 1.5xtr
Old 06-29-2012, 05:36 PM   #760
mikeesingh
Member#: 30183
1996 GC8 WRX
Will measure tomorrow and pm you
Old 06-30-2012, 04:06 AM   #761
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
We had a club dyno day today so I thought I'd share my graph, the blue line is a power run I did when the car was completely stock, red line is with my VF36 and supporting mods, fuel is Aussie pump 98.
The 2.0L motor is a fair bit different to what you guys get, it has AVCS, big port heads, very similar pistons to spec c, im running 20psi. Its a pretty low reading dyno too but you can see the difference over the old TD04. I ran a 12.7 @ 107mph in this car.
JDwhiteWRX is offline   Reply With Quote
Old 06-30-2012, 10:05 AM   #762
SUBARIFFIC
Member#: 183647
06 WRX
WR Blue
KS Tech 73 mm CAI
TMIC
Stock headers
Perrin intake hoses
DW850
Powerdyne
That's pretty good for a 2.0 liter I wonder what this thing would do on a 2.5
SUBARIFFIC is offline   Reply With Quote
Old 07-10-2012, 11:20 PM   #763
nativo
Member#: 157
1998 JDM STIv8 6sp
Rally Blue Pearl
Well tintsound, unless anyone else comes with a better looking dynograph I think that Bouch PNP Twinscroll 1.5XT-R 10cm will be part of our Santa's list.
Anyone have a Blouch 2.0 on an STI v8?
Thanks,
nativo is offline   Reply With Quote
Old 07-11-2012, 08:16 PM   #764
gordonbisby
Member#: 325858
Man, too expensive.
gordonbisby is offline   Reply With Quote
Old 07-12-2012, 07:05 AM   #765
SUBARIFFIC
Member#: 183647
06 WRX
WR Blue
Originally Posted by gordonbisby
Man, too expensive.
Hey you can always get a Kinugawa for $800 bucks that is a option just won't be able to have ball bearings and a billet wheel.
Old 07-12-2012, 07:44 AM   #766
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Kinugawa/kamak has started to have a billet option.
They also offer with it a turbine with reduced number of blades, like the VF42. Not made from TiAl though.
This model is a bit more expensive though.
Old 07-12-2012, 03:28 PM   #767
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
link? this sounds interesting. the blouch 1.5xtr is so tempting though.
as far as the guy that ran 12.7 @ 107mph in the 1/4. what kinda trans/drivetrain setup was that on? i ran that with my td04 on e85 and ej205 engine. 150k miles. 5mt ppg trans w/ launch control. I was looking to go like low 12's with the vf37 ej207 setup w/ same trans... think its possible? i am pretty decent drive and with speed density NLTS plus agressive LC and torsen front diff going into the ppg trans this weekend it should help hook up front better and decrease my 60' by .15 sec atleast
Old 07-12-2012, 06:59 PM   #768
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
Stock trans/drivetrain which is open front diff in a standard 5MT with VLSD rear diff and no launch control. My 60' was 1.79 for that run and it was my 2nd time at the drags, the car is mainly set up for time attack I just went along to see what kind of mph it run since I don't really trust dyno figures.
I think you could do it for sure with that setup.
Old 07-12-2012, 10:34 PM   #769
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Old 07-12-2012, 11:04 PM   #770
SUBARIFFIC
Member#: 183647
06 WRX
WR Blue
That KAMAK would me nice for a 2.0 but 300-400 crank is a little soft for a 2.5... Especially mine being built and all. What we need is a 50lb or 52lb twin scroll stock location
Old 07-19-2012, 10:35 AM   #771
Moore Performance
Member#: 231489
Here's an update on the stock location products were ready to release. Here's a pic of the final production design for our V2 header and stock location TS uppipe (one of 6 uppipe options). It fits perfect with the JDM TS bracket and the downpipe is a pre-production model. The first was our prototype, but this one will be more representative of what we'll have to offer, except it will be cnc mandrel bent in one piece. We also have custom gaskets that allow for a truly divided dp flange like you see here. We will also offer both a catted and a plumb back option for the 2" wastegate dump tube. This setup sounds amazing though and it's even more intriguing b/c it was just installed on a forester.
Moore Performance is offline   Reply With Quote
Old 07-19-2012, 10:46 AM   #772
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
I just finished putting my new motor together, was running 2.12 with SC46 and now I am on a closed deck 257 w/207 heads and SC46
still breaking in the motor and have to fix slipping clutch but all I can say is WOW.... the car is ALWAYS in power, no matter what gear or RPM you are in
as soon as I fix the clutch I will put it on the dyno, I expect a heck of a torque curve
some teasers
Hyper is offline   Reply With Quote
Old 07-19-2012, 11:06 AM   #773
bugeye sti
Member#: 186691
2011 sti
I know this is the 2.0L section but how well would this work on on the 2.5L?
bugeye sti is offline   Reply With Quote
Old 07-19-2012, 11:25 AM   #774
Moore Performance
Member#: 231489
Well, the Forester is a single avcs 2.5 liter running an sti top mount so we'll have that answer for you shortly. I'll post results after we get the car on the dyno.
Old 07-19-2012, 12:14 PM   #775
SUBARIFFIC
Member#: 183647
06 WRX
WR Blue
What are the 6 different Uppie options so we as customers can get an idea what turbos we can mount up to this bad boy
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco SCIC Private Classifieds 11 10-22-2010 01:09 AM
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco Engine/Power/Exhaust 9 10-02-2009 01:04 PM
twin scroll turbo with dual ball bearing options pjhe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 12-14-2006 09:40 PM
DP options for twin scroll turbo? John2.5RS Subaru Conversions 7 08-24-2006 12:14 AM
Anyone running a stock evo twin scroll turbo on a wrx? mcu81 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-09-2006 11:29 PM
