Welcome to the North American Subaru Impreza Owners Club Sunday January 25, 2015
Old 07-23-2012, 10:03 PM   #801
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Originally Posted by Fierysun
Wasn't that the one where you have to ship Moore's your VF37 for them to gut out and change the center? Or was it some other? Do you have a link?
You're thinking of the Blouch setup. The Moore setup is what you're thinking of, and it uses EVO turbos which are proven.
LIQUIDSK8S is online now   Reply With Quote
Old 07-24-2012, 01:37 PM   #802
Moore Performance
Member#: 231489
Originally Posted by SUBARIFFIC View Post
I'm talking about headers & downpipe maybe rotated and will a 06 wrx need to switch the oil cooler since Subaru changed it for some asinine reason.smh
If I'm correct, I cannot post pricing in this thread but please email or pm us for more pricing and complete kit information and specs.
06 wrx oil cooler will need changed to work with our header (and i'm sure all other EL headers of similar design). We have many customers that delete their oil cooler setup completely so we put together a small kit that allows you to do so, if that is an option you're looking into.
Moore Performance is offline   Reply With Quote
Old 07-24-2012, 02:11 PM   #803
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
If that's the case, pm me the price and I'll include it with the OP.
Old 07-24-2012, 08:02 PM   #804
SUBARIFFIC
Member#: 183647
06 WRX
WR Blue
^^^ Yea click that private message link and some price quotes shipped to 28215 for a stock location and a (T4 Rotated I'm still on the fence for a 7064 EFR.) Since I lowered my compression I need to get my off boost responsiveness back.
SUBARIFFIC is online now   Reply With Quote
Old 08-09-2012, 11:43 AM   #805
jimbo228
Member#: 71600
2010 STI
Sorry everyone.... I have been too busy enjoying my TS 2.5xtr to right up a post Response is fantastic.... the twinscroll seems to help out considerably with low speed driveability. Boost builds steady from 2000 on up. I am only running on a 15psi WG 91 octane break in map, but the car feel phenomenal!! From a stop it feels like an NA V6 and then boost begins to build very linearly!!! great power all over... totally different experience then my vf 48... more to come!!
jimbo228 is offline   Reply With Quote
Old 08-12-2012, 04:27 PM   #806
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
is it stock location TS^ i want to upgrade but can not decide if i should just go ahead and skip stock location type TS and go t3 TS instead since there are so many options out there.
let us know when its done and the final numbers/info!
WhiteBgeye02 is offline   Reply With Quote
Old 08-13-2012, 10:08 PM   #807
jura11
Member#: 255146
2001 2002 WRX Wagon
WR BLUE
Here is next competitor to the LM,SC(Blouch in USA),MD(Lateral Performance) and others
Its Owen Development Twin scroll turbo,still is under testing,but looking like good option
This is on the 2.1 with JDM STi AVCS heads and Chevron TMIC
457 BHP @ 6500rpm, 465 LbFt @ 3750rpm on V-Power 99RON + 20% meth(blue line)
405BHP @ 6500rpm 420lbft at 3750rpm on V-Power 99RON(red line)
This turbo still is under testing,but looking will make more power in final stages
Jura
jura11 is offline   Reply With Quote
Old 08-14-2012, 12:46 PM   #808
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
so bhp as in crank? looks very interesting since its spooling to 25psi about by 3500rpms. any specs on compressor or turbine sizes? lb/min flow? price? i would like to buy a turbo very soon but if a new option is coming out i can wait and see how it does.
Old 08-14-2012, 04:04 PM   #809
azscooby
Member#: 115297
2002 ej207 vf34
How are these guys making so much power so soon?
I haven't seen any US guys with TS making this type of power this soon (even if it is crank hp)
azscooby is offline   Reply With Quote
Old 08-14-2012, 04:19 PM   #810
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
This is a 2.1L Stroker, that can easily attribute why it made power as quickly as it did.
kayen is online now   Reply With Quote
Old 08-14-2012, 08:38 PM   #811
jura11
Member#: 255146
2001 2002 WRX Wagon
WR BLUE
Yes is crank(Flywheel bhp figure),as i said is still under development and still fettling more and more this turbo, I'm afraid don't know exactly lb/min flow and price
On road this turbo spools faster than on Rolling road
Jura
Hi there
He running Chevron TMIC,which is probably best TMIC which is available on the market
Plus he running 2.1L with JDM big port heads,but still similar turbos spools slower than this
Here are Delta Dash results including Air Charge temperature
http://bbs.scoobynet.com/showpost.ph...8&postcount=66
http://bbs.scoobynet.com/showpost.ph...7&postcount=81
http://bbs.scoobynet.com/showpost.ph...3&postcount=87
Hope this help
Jura
Old 08-14-2012, 09:31 PM   #812
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
What gear was this? and was it a 6 speed transmission?
The links don't work, btw.
Old 08-14-2012, 09:34 PM   #813
jura11
Member#: 255146
2001 2002 WRX Wagon
WR BLUE
In 4th gear and links will work,but seems Scoobynet server is again down,please check later on
Links are correct there and i've tested them before i've posted them
You can check the Scoobynet forum,if Scoobynet forum working,should those links work too
http://bbs.scoobynet.com/forum.php
Jura
Old 08-14-2012, 09:36 PM   #814
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
This appears to be an issue with scoobynet, and not the links.
Edit: oops, beat to the punch.
Concillian is offline   Reply With Quote
Old 08-14-2012, 10:34 PM   #815
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
4th out of 5 gears or 6?
Edit: The links work now, the site is up.
Ok, it's a 6 speed, high compression engine.
Wow, Ecutek sells injectors these days?
Old 08-15-2012, 02:14 PM   #816
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
well hopefully they hurry up lol! just looking at some of there other prices they seem pretty damn high so not sure if this will be an option for me either way.
Old 08-19-2012, 01:48 PM   #817
johnfelstead
Member#: 856
2005 JDM STi
Jura
Hi Guys,
This is my car/engine setup.
I've been doing some development work with Owen Developments and Chevron Motorsport to come up with something that will give me the same spool as my Stock VF37 turbo, but produce more torque and power, i think we are there now.
The turbo is a proper twin scroll, with roller bearing core, Garrett serge port equipped compressor housing with billet compressor wheel, inconel waste gates and Owen spec turbine wheel.
Currently it is mapped to 1.85 BAR and 135,000 rpm on the road, which is limited because of the OEM MAP sensor in use. I now have a Perrin 4 BAR map sensor which will allow us to take the boost up to 2.0BAR, we will run a peak turbo speed of 145,000 rpm. On the Rolling Road it was a very hot day with 24 degrees Ambient, so it only pulled 1.75BAR and 132,000rpm, the engine is road mapped. Charge temps were also higher on the rollers than i see on the road.
For those saying it's the 2.1 that is the reason for the fast spool, below is a DeltaDash Road Dyno comparison of this engine with the stock VF37 turbo installed running a 33% mix of VP Q16 race fuel, 66% 99 RON pump fuel, compared to the current setup on a 20% mix of methanol and the spool is identical, the current setup actually spools 100rpm faster on plain 99RON fuel.
At the moment we have a Samco turbo inlet pipe that is collapsing under load, so top end is being strangled a little too. Once we have a new inlet pipe fitted and have done another mapping session i'll update the thread.
Any questions ask away, some of you may remember me from the motorsport forum many moons ago, i'm not a newby, just been a tad busy the last few years.
cheers
john
johnfelstead is offline   Reply With Quote
Old 08-19-2012, 02:01 PM   #818
johnfelstead
Member#: 856
2005 JDM STi
And this is what the turbo looks like, the electrical lead/connector is the Garrett turbo speed sensor we are using to gather data during mapping, we are well inside the turbo eficiency speed range at the moment.
Old 08-19-2012, 02:23 PM   #819
johnfelstead
Member#: 856
2005 JDM STi
Here is my engine bay, no heat shielding in use yet.
Old 10-06-2012, 02:14 PM   #820
Shaun@ScoobyNet
Member#: 99778
Latest runs from my MY06 2ltr JDM:
Standard OEM engine
Billet LM450
800cc EcuTEK injectors
OEM ECU
BRD Inlet
3" Decat
Hybrid FMIC
Shell VPower + 20% Methanol
Dyno run in 4th. Figures show flywheel. Car was also run on a hub dyno and it showed 410bhp @ hubs.
Red line is VPower+20% Meth
Blue line is VPower
Shaun@ScoobyNet is offline   Reply With Quote
Old 10-06-2012, 02:20 PM   #821
johnfelstead
Member#: 856
2005 JDM STi
Nice results Shaun.
My new more rigid Inlet pipe was fitted today, Perrin 4BAR MAP Sensor is here ready to install, so all ready for it's mapping session to see what the engine will produce with the turbo optimised.
Engine is being Mapped on Wednesday, should be interesting.
Old 10-07-2012, 12:03 AM   #822
jura11
Member#: 255146
2001 2002 WRX Wagon
WR BLUE
Awesome guys results,congratulation
Jura
Old 10-07-2012, 07:13 AM   #823
Shaun@ScoobyNet
Member#: 99778
Looking forward to your results John. Looks like the options from UK manufacturers are certainly mixing it up! I think it would be interesting to see our cars ran on US dynos as well.
Old 10-07-2012, 04:15 PM   #824
johnfelstead
Member#: 856
2005 JDM STi
Just add 20% to our figures, thats traditionally the difference between US and UK ponies.
Just finished installing my Spec C water spray tank too, so have IC sprays back in action again.
Old 10-07-2012, 05:24 PM   #825
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
I can assure you that the US horses are quite muscular...
I remember my dissapointment when my Alfa Romeo listed in US with 3 less HP than it had in EU, in PS..
I was still trying to come up with a reason for which it has less power for export, when it dawned on me to find the equivalence formula..
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco SCIC Private Classifieds 11 10-22-2010 02:09 AM
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco Engine/Power/Exhaust 9 10-02-2009 02:04 PM
twin scroll turbo with dual ball bearing options pjhe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 12-14-2006 10:40 PM
DP options for twin scroll turbo? John2.5RS Subaru Conversions 7 08-24-2006 01:14 AM
Anyone running a stock evo twin scroll turbo on a wrx? mcu81 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-10-2006 12:29 AM
