Old 06-02-2011, 08:05 AM   #101
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Originally Posted by jdeford View Post
Impressive listing of the choices out there. We are running a 2.0L JDM V7 motor (2002MY) with a VF42 turbo (internal wastegate.) Two wheel drive conversion car. Rear wheel torque at 21 psi on pump gas is 310 lb ft at 4000 rpm. Curve then trails to 240 lb ft at 7000 rpm redline. My tuner tells me that we need a larger turbo but I need to have one with exhaust inlet and outlets that exaxtly match the stock locations on the VF42.
Car is road race application so our primary goal is throttle response with mid range grunt. That actually trumps overall horsepower hence the smaller turbo selection so far and the twin scroll set up. If there is something larger out there that would not compromise rapid spool up, I am very interested. Thanks for any ideas that you might have.
If you looked at all the information from the OP first post and looked closely at all of the Dyno Graphs listed as well. Then I would have to say an SC46 is your turbo of choice. However there is quite a gap in the other Twin Scrolls from ScoobyClinic, as there just hasn't been anyone testing them. Those being the SC38 and SC40 TS variants.
If you have a donor VF36/37 and you could use your VF42 as well to send into Blouch and have them build you an SC46.
Another great choice is the Litchfield Turbo's and the it seems the LM450-S60 is a great setup as well and would similar to the SC46.
I myself am quite interested in the SC40 TS (Blouch 20G-XT TS). One it's a bit cheaper, don't have to destroy my VF36 to get a SC46 and should make approximately the same Power. Only downfall is it should spool a little bit slower with the Journal Bearing center cartridge.
kayen is offline   Reply With Quote
Old 06-02-2011, 10:42 AM   #102
02 Scoob-TN
Member#: 176010
2005 WRX sdn ver8'ed
Phat-Tuned RIP Bugeye
http://www.kamakdynamics.com/catalog...TALOG_2011.pdf
they will build you whatever you want and are decently priced.. AKA kinugawa. Remove Moore from your list, thats not stock location at all, and would not be a good option if you already have the JDM setup.....
02 Scoob-TN is offline   Reply With Quote
Old 06-02-2011, 11:36 AM   #103
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Pretty interesting, I wonder how good they are. I know that some people have tested the Single Scroll stuff with success. Makes me wonder if the Hotside for their TS is the same is what Blouch uses. However I wonder if they are using the lighter billet wheels that blouch offers too... I kind of doubt they do.
Old 06-02-2011, 12:32 PM   #104
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
Default none
Yeah I agree the Moore Performance set up is not an option to us...lets keep this thread on topic....I too am patiently awaiting for viable option for 400whp utilizing the stock JDM headers and uppipe.......
murrdogg24 is offline   Reply With Quote
Old 06-02-2011, 03:48 PM   #105
02 Scoob-TN
Member#: 176010
Lightbulb
They actually make their own copy vf37 hot-sides if you need a replacement they are cheap. May be able to get a specialty setup like HTA assist,I know they have a Garret cartridge option. But I doubt they will be on the same level of the billet blouch. Just another good inexpensive option that someone in the US needs to disprove the nasayers with. Im happy with my current setup, but Im sure that will change. So I plan to change to an upgraded twinscroll turbo of some sort and flip to E85 as my next stage..Ive actually got something in the works with Kinugawa/kamak but we will see if that pans out. Sup to my Club ej207 brethren..
Old 06-02-2011, 03:59 PM   #106
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
So is it possible to buy a replica VF37 (P25) Hotside off Kamak and use that to send into Blouch to have them build an SC46? Because Blouch can't use their custom TS housings that they have molded to do create their 18G, 20G variant TS turbo's.
Also if this was possible, why doesn't Blouch/ScoobyClinic buy housings off of Kamak for the Hotside?
Old 06-02-2011, 04:17 PM   #107
02 Scoob-TN
Member#: 176010
Most likley because their produced in Taiwan and all the haters would be like Im not paying top blouch dollars for Taiwanese stuff. But they do have them readily available.
Old 06-02-2011, 05:04 PM   #108
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Did Kamak give you a price just for a VF37 hotside perhaps?
Old 06-02-2011, 05:45 PM   #109
02 Scoob-TN
Member#: 176010
No Ive only talked complete turbos with them. One cool thing is that they are wanting to use old stock standard flange stainless 3 inch USDM downpipes they've sourced and use their VF36/37 neck to reconfigure them for us in the US and they will be cheap, cheap. Also, ive suggested to them to include 3 bungs 2 for the stock 02's and an additional one for your wideband if needed. They loved that idea. Im telling you these guys are very smart, I mean look at how they even came up with the idea to offer the whole neck instead of just a flange.made it so easy to make my own downpipe.
Old 06-02-2011, 05:47 PM   #110
02 Scoob-TN
Member#: 176010
http://myworld.ebay.com/ebaymotors/a...id=p4340.l2559
kayen-Contact this vendor and ask them if they will get you just the housing..
Old 06-02-2011, 07:41 PM   #111
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Well I just sent them an email, so we'll see what they have to say. If they can sell them independently, then I would probably have to verify with Blouch if they can actually use it to create an SC46. Don't want to waste money on a housing that ends up worthless haha.
Old 06-02-2011, 09:07 PM   #112
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
i'd be down if they sold the whole jdm flanged downpipe ready for bolt on for cheap...like under 200 bones
scoobystas is offline   Reply With Quote
Old 06-03-2011, 08:41 AM   #113
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Moore does have a "stock location" turbo option, granted it requires a new up-pipe. I feel it is worth keeping it up there on this basis.
LIQUIDSK8S is offline   Reply With Quote
Old 06-03-2011, 08:56 AM   #114
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
I think most people are griping at Moore is because they would need the UP-pipe, downpipe, intake and maybe even a new Intercooler to make it work. Versus just a different Turbo and bolting it in.
However I am not opposed to Moore's option and look forward to it's results. As Liquid said above I agree that the Moore option should be further discussed in this thread. Being that Liquid is the OP he has all rights to keep new information about Moore's setup being discussed. Also Liquid posted information in regards to the Moore setup in his OP as well.
Old 06-05-2011, 07:50 PM   #115
blakjak00
Member#: 225046
2000 2.5RS
Blue Ridge Pearl
Edit saw this in OP
blakjak00 is offline   Reply With Quote
Old 06-06-2011, 12:14 PM   #116
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
New results over at scoobynet for a SC46. I'm still awaiting details on if it is a twin scroll or single scroll version. But from what we have seen the peak power is similar between the two (both are billet) while spool is better on the twin scroll.
Here are the small details we do have. It is a 2.0, but not sure if STi or WRX (assuming STi) running STi ver2 heads (crap compared to ver8) on 100RON (96-97 octane). Given that this is a 2.0 on those meh heads, I'm pretty impressed with the results, couldn't imagine this on a full ver8 EJ207, tq would have held much better up top. They also said it had room for more power but they held it back for safety. Target boost was 1.8 bar (26psi). Also note that these are not AVCS heads (correct me if I'm wrong) which explains the lower tq down low, and it may also be a single scroll unit. If this is the case, the twin scroll with AVCS would be much stronger down low, so this graph is more about showing the potential of the SC46.
UPDATE this is a single scroll
True it is a little more work, but a lot less than some of the other rotated twin scroll kits requiring ewg, piping etc, not to mention those are all much larger turbos.
I think those of us in this thread are primarily interested in medium size turbos that spool like stock will achieving around 400whp. But I agree that Moore should limit their discussions in here to the stock location turbos and not the rotated, even though I love hearing about the results .
Old 06-06-2011, 01:27 PM   #117
blakjak00
Member#: 225046
2000 2.5RS
Blue Ridge Pearl
Still looks like one hell of a torque curve lol
Old 06-06-2011, 03:32 PM   #118
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
if I ever get those damm AN fittings to replace the broken avcs/turbo line, we will all find out what twin scroll sc46 does on 2.12 JDM V9 Spec C...
Hyper is online now   Reply With Quote
Old 06-06-2011, 03:39 PM   #119
blakjak00
Member#: 225046
2000 2.5RS
Blue Ridge Pearl
2.12? That's new, got a build thread I could read up on?
Old 06-06-2011, 03:51 PM   #120
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
SC46 twin scroll + EJ207 + JDM 6spd + E85 = win
x2
Old 06-06-2011, 04:09 PM   #121
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
Yeah an SC46 TS seems like the way to go. I just wish they were easier to obtain, then having to send in my perfectly working VF36.
Old 06-06-2011, 04:39 PM   #122
fellstar
Member#: 205280
2012 Jeep Wrangler
Bright Silver
If I had an extra 1600 laying around I'd toss it on my V8 setup.
fellstar is offline   Reply With Quote
Old 06-06-2011, 07:42 PM   #123
blakjak00
Member#: 225046
2000 2.5RS
Blue Ridge Pearl
$200 more and you wouldn't have to
Old 06-06-2011, 07:54 PM   #124
fellstar
Member#: 205280
2012 Jeep Wrangler
Bright Silver
Por que?
Old 06-06-2011, 07:57 PM   #125
blakjak00
Member#: 225046
2000 2.5RS
Blue Ridge Pearl
Originally Posted by fellstar
Por que?
Scooby clinic will supply the housing for another $200. Blouch won't though
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco SCIC Private Classifieds 11 10-22-2010 01:09 AM
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco Engine/Power/Exhaust 9 10-02-2009 01:04 PM
twin scroll turbo with dual ball bearing options pjhe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 12-14-2006 09:40 PM
DP options for twin scroll turbo? John2.5RS Subaru Conversions 7 08-24-2006 12:14 AM
Anyone running a stock evo twin scroll turbo on a wrx? mcu81 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-09-2006 11:29 PM
