Old 04-22-2011, 06:34 PM   #1
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Default Road tune 2006 STI PTE 6776
Event: Road Tune
Ambient Temp: 65*
Elevation: 4500ft
Weather: Warm
Track and Conditions:flat road
Tires: 255/35 18 Nitto 555
Car: 2006 STI
Tuner: Me
Dyno Info: Airboy
Transmission: Stock 6 speed
Gear: 4th
Peak HP at RPM: 441WHP
Peak Torque at RPM: 384WTQ
Baseline hp/tq for a stock on same dyno: my sti: 216WHP/222 WTQ
Target Boost: 26 PSI
Target AFR: 11.3
Fuel: 91
I'm going to need a better fuel setup, My IDC are at 105%
Engine:
2.6 Liter Darton Sleeved Block
CP 102 mm Pistons
Manley Turbo Tuff Rods
JDM 12mm Oil Pump
ARP Head Studs, Main Block Bolts and Rod bolts
ACL Main and Rod Bearings
Covert Oil Pick up Line
Port and Polished head with bowl blends
BC 280 cams (already had them)
BC Springs and TI Retainers
Ported intake manifold
TGV Deletes
Battery Relocation to Trunk
Torque Solutions Pitch mount and billet motor mounts
Performance Mods:
PTE DBB 6776 Vband with .63 AR
Custom Intercooler and piping with 3.5" blow thru
GT Spec header with 3 bolt up pipe With 38mm tial EWG
Full TBE with Blitz Nur Spec CBE
Five O 1200 CC injectors
DW 300+ Fuel Pump
Pic of the car
renosubby is offline   Reply With Quote
Old 04-22-2011, 06:37 PM   #2
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Originally Posted by renosubby View Post
Event: Road Tune
Ambient Temp: 65*
Elevation: 4500ft
Weather: Warm
Car: 2006 STI
Tuner: Me
Dyno Info: Airboy
Gear: 4th
Target AFR: 11.3
Fuel: 91
Engine:
CP 102 mm Pistons
JDM 12mm Oil Pump
TGV Deletes
Performance Mods:
DW 300+ Fuel Pump
Pic of the car
Congrats man, thats a fast car. My car made 460 on race gas on the airboy and it was realllly fun. This should go 127mph in the 1/4 granted weight and driver.
STi Mikey is offline   Reply With Quote
Old 04-22-2011, 07:06 PM   #3
Jamaal
Member#: 135979
2006 STi
obp
Sounds like a mean setup. Are you running on straight pump gas? Also sent you a pm about the blowthrough setup. Just a few q's about tuning it as I'm working on dialing in my setup.
Nice work!
Jamaal is offline   Reply With Quote
Old 04-22-2011, 07:55 PM   #4
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Thanks man! It's fun!
Old 04-22-2011, 11:58 PM   #5
WhatTurboLag?
Member#: 243992
2006 WRX TR
this thing will be even better once that fuel is fixed!!! a lot of my friends run this on their supras. they make over 700 on race gas!
WhatTurboLag? is offline   Reply With Quote
Old 04-23-2011, 12:09 AM   #6
azn2nr
Member#: 35276
no meth?
azn2nr is offline   Reply With Quote
Old 04-23-2011, 12:37 AM   #7
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Originally Posted by azn2nr View Post
no meth?
No meth. Straight 91 oct
Old 04-23-2011, 01:38 AM   #8
azn2nr
Member#: 35276
wow. thats alot of power up top for a .63 housing and no meth.
Old 04-23-2011, 03:40 AM   #9
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Thanks man.
Old 04-23-2011, 05:46 AM   #10
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
That PTE really has a T3 .63 turbine housing??
Beetspeed is offline   Reply With Quote
Old 04-23-2011, 10:31 AM   #11
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
bump!
Irv Weissmanhowerton is offline   Reply With Quote
Old 04-23-2011, 01:19 PM   #12
az_sti_04
Member#: 239732
2004 Sti
how do you like the five O injectors? i was thinking of picking up the 1200s
az_sti_04 is offline   Reply With Quote
Old 04-23-2011, 01:34 PM   #13
CatfaceType-R
Member#: 81102
Looks nice, I wish more people had long term or any success at all with the stroked 2.5 though; displacement sure is nice.
CatfaceType-R is offline   Reply With Quote
Old 04-23-2011, 01:37 PM   #14
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
It doen't say stroked though. If I understand correctly, the extra displacement comes from the larger 102mm bore alone.
Old 04-23-2011, 10:02 PM   #15
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Love the 1200. Easy to tune. I did find a gasket had blown out so. I will be doing another pull after I fix it.
Old 04-25-2011, 04:40 PM   #16
Ohhey1
Member#: 260297
2006 STI White
HTA Green Methanol
I want your hood what is it?!
Ohhey1 is offline   Reply With Quote
Old 04-25-2011, 04:54 PM   #17
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Seibon, it was all CF but I had it painted
Old 04-28-2011, 01:24 PM   #18
rexblake
Member#: 178426
2010 S4
Gray
That's quick and should be a hell of a csr when you get your fuel system sorted. That's some serious power on straight 91 octane at altitude. That is one big ass turbo though, I am looking forward to you cranking the boost! Nice setup.
rexblake is offline   Reply With Quote
Old 04-28-2011, 06:35 PM   #19
OVeRBOOSTn
Member#: 192514
04 STi PTE6765
[email protected] / JR Tuned
350whp at 5k =/ turbo is too big for a street car imo esp on a .63 back housing
OVeRBOOSTn is offline   Reply With Quote
Old 04-28-2011, 06:40 PM   #20
OVeRBOOSTn
Member#: 192514
04 STi PTE6765
either way bad azz car man!
-Stu
Old 04-28-2011, 06:48 PM   #21
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Agree, Im going down to a Billet 6265 with a .82 AR
Old 04-29-2011, 03:40 AM   #22
OVeRBOOSTn
Member#: 192514
04 STi PTE6765
great turbo i loved my 6262!
Old 04-29-2011, 04:28 PM   #23
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
Very interesting build.
Im no expert, but I do have a few questions about your monster build.
Not sure why you're really wasting your time with 91 octane though. Put some ID2000s or FIC 2150s in there. Then throw some ethonol at that setup and you'll see those power numbers increase dramatically upwards of 900hp+ on a dynojet w/o meth. Only limitation that you're going to have on your current setup is the puny .63 on that turbo though. Not really sure why you chose that size. .82ar or 1.02ar would suite you a ton better. But it really all depends on what you plan to do with the car.
Reving uptop is going to be a problem with what mods you have on the car though. The JDM12mm pump will be your biggest issue getting those RPMs up high. Seen a lot of people blow their motors trying to rev with that pump. I might be wrong, but is it just the stock JDM 12mm? or do you have it pnp, spring changed and shimmed?
Another item you might want to replace sometime in the future is your BC 280 cams. BC makes garbage. The lobes on the BC280 cams are smaller than the Kelford/GSC 272 cams. Id go with a kelford 272 or GSC II. But once again, those cams wil shine if you have good valves in there. Are you running std valves? or oversized?
mtcs is offline   Reply With Quote
Old 04-29-2011, 05:44 PM   #24
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
When you run faster than this car: http://forums.nasioc.com/forums/show....php?t=2172377
Or have a faster car than Element Tuning record setting Time Attack race car: http://forums.nasioc.com/forums/show....php?t=2121068
You can spill all the nonsense you want
Old 04-29-2011, 05:50 PM   #25
CatfaceType-R
Member#: 81102
bc racing just got that horrible name from their "stroker" kits, but some worked...who know's, when machining is involved and multiple parties, it's hard to attest to, who came with the "crap"
the bc cams are proven to be good, while the $$$ cosworth's break in half ??? who knows?
The SHOP + JR TUNE 2006 STI + HTA86 [email protected] !!! Junior2JZ Proven Power Bragging 188 07-26-2012 10:56 PM
FS/FT : NJ Precision Built and Tuned. 2006 STi 20g JohnST2k6k Tri-State Area Private Classifieds 4 10-26-2010 02:20 PM
Road Tune:Mayhem Tuning 2006 STI ATP 3076 renosubby Proven Power Bragging 12 05-20-2010 11:54 AM
Epic Motorsports tuned 2006 STi, Blouch Dom4 XTR, AR Fabrication Short Block Epic Motorsports Proven Power Bragging 16 05-16-2010 08:29 PM
The SHOP + JR TUNE 2006 STI + HTA86 goes 10.43 @ 135.86 Junior2JZ Proven Power Bragging 210 10-31-2009 05:05 PM
