Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 07-19-2002, 09:38 AM   #1
redmeanie
Member#: 15702
2001 2.5 RS-T LINK'D
911verion2.0TT (soon)
Question Skywalker
Quick ? on connections for the TIAL Wastegate when running boost control....perhaps you know....Bottom line goes to preesure side of turbo i.e. charge pipe...Top goes to manual or (when we get it working) electric boost controller which is connected also to the pressure side of the turbo also?
Thanks,
Chuck
redmeanie is offline   Reply With Quote
Old 07-19-2002, 01:56 PM   #2
Delicious Tuning
Member#: 1990
If you were running NO boost control the bottom feed goes to the Intake Manifold or the Pressure Side of the Turbo, as you stated.
So if you are using the top feed you will want to use an external wastegate boost solenoid, you will want to keep the bottom port set as stated above. Then you will want to run another vacuum line from the Intake Manifold or pressure side of the Turbo to the boost solenoid and then run a vacuum line from the boost solenoid to the top feed on the wastegate.
It all depends on what boost solenoid you are using. If you use the boost solenoid sold from Link ($260 solenoid) then you will want to hook it up as stated above.
If youare using the cheaper boost solenoid ($80 solenoid) from AMR you want to connect one vaccum line from the Pressure Side of the Turbo to the boost solenoid and then attach a vaccum line from the boost solenoid to the bottom (side) feed on the wastegate.
Hope that helps.
Delicious Tuning is offline   Reply With Quote
Old 07-19-2002, 03:20 PM   #3
redmeanie
Member#: 15702
Thumbs up Thanks...
Thats all man thanks...Andrew called me this morning and we cleared that up....I had already posted this though.....
Thanks Again,
Chuck
Atten: Skywalker EddyRS Bay Area Impreza Club Forum -- BAIC 10 06-13-2001 02:41 PM
Skywalker, WRX, & WRXRA @ LSIR Race School 1-13-01 Delicious Tuning Bay Area Impreza Club Forum -- BAIC 4 01-15-2001 11:04 PM
Laguna Seca: good luck young skywalker SFsube Bay Area Impreza Club Forum -- BAIC 2 01-12-2001 08:21 PM
attn Skywalker josh Bay Area Impreza Club Forum -- BAIC 0 09-26-2000 01:29 PM
attn: skywalker josh Bay Area Impreza Club Forum -- BAIC 0 09-05-2000 08:06 PM
