Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 01-09-2012, 05:53 PM   #1
nikiSTI
Member#: 146743
2005 STi Stg 2
Default Aircraft light mod
Im trying to figure out a way to run aircraft taxi lights for my driving lights. All I really need is 12vdc to 28vdc converter that is capable of running 450w light.
Any help is much appreciated
nikiSTI is offline   Reply With Quote
Old 01-09-2012, 07:24 PM   #2
leach0789
Member#: 210903
2013 MS3/Turbo Miata
Nitrous Rhodes
leach0789 is offline   Reply With Quote
Old 01-09-2012, 09:00 PM   #3
redsoxwin
Member#: 189313
'10 Tacoma
If only you had a long runway like driveway for top speed runs...
redsoxwin is offline   Reply With Quote
Old 01-09-2012, 10:08 PM   #4
Evil Homer
Member#: 175522
I hope an airplane crashes into you.
Evil Homer is offline   Reply With Quote
Old 01-10-2012, 12:28 AM   #5
TireIron
Member#: 218469
96 SVX
Green
28V 450W is a TON of power for lights. You're headlights and highbeams are only 12V 55W...
TireIron is offline   Reply With Quote
Old 01-10-2012, 06:56 AM   #6
89zxTO2.5rs
Member#: 232501
2001 Impreza 2.5RS
OBP(Black)
How did you even manage to get those lights? Either way, its really not worth the trouble doing something like this or running the risk of damaging your electrical system. Just run some Hella's.
89zxTO2.5rs is offline   Reply With Quote
Old 01-10-2012, 09:08 AM   #7
nperkins
Member#: 135812
90 Miata
04 Evo Rally Car
nperkins is offline   Reply With Quote
Old 01-10-2012, 09:22 AM   #8
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Are aircraft parts not sold to the public? I think this is well worth the trouble, could be a lot of fun for offroad adventures. But that much juice seems way outside the design of a car.
Snowphun is offline   Reply With Quote
Old 01-10-2012, 09:27 AM   #9
sexyyrex
Member#: 128022
2011 Infiniti G37x
Sedan
Any idea how much heat those give off? The more watts, the hotter it will run, considering is just a colored, glowing resistor. You'll met the housing after 5 seconds of powering them, not to mention blind everyone on the road.
sexyyrex is offline   Reply With Quote
Old 01-10-2012, 09:27 AM   #10
timeXlost
Member#: 113924
2005 STI....SOLD!
93 RX7...Not Broken
i got this light out of a lighthouse...
im thinking i want to mount it in my grill, can anyone tell me how to do it?
timeXlost is offline   Reply With Quote
Old 01-10-2012, 09:36 AM   #11
H-Dtech
Member#: 139430
08 FSXT 5mt
WRB 1 of 300
When I lived in AK, alot of guys would run aircraft landing lights. I'm not sure how they rigged them up to work, but i know for the most part they would stick with the 5" lights and mount them in those rubberized tractor light housings. the whole set up worked really well.
H-Dtech is offline   Reply With Quote
Old 01-10-2012, 09:54 AM   #12
jcoppah24
Member#: 217515
2006 WRX Stage 2
I have harnessed the power of the sun and would like to mount it on the back of my car for rear fog light... any thoughts... ?
jcoppah24 is offline   Reply With Quote
Old 01-10-2012, 09:59 AM   #13
nikiSTI
Member#: 146743
2005 STi Stg 2
I know how hot they get and I got the original housings for them. All I need is a converter that doesn't cost 2k.
If I got the parts why not do a little experiment to see if it can be done, who gives a **** if it might not be practical
Old 01-10-2012, 10:21 AM   #14
nperkins
Member#: 135812
90 Miata
04 Evo Rally Car
If you are serious, at 28v, 450 watts pulls about 17 amps of constant current, not including initial load...
Drop that to 12 volts, and you are at roughly 30-31 amps of constant load. The factory alternator puts out 90 amps... That's a fairly heft load...
You will need some major relays, and the convertor would not be easy to do, as to be able to upconvert from 12v to 28v, while maintaining a 20+ amp load is serious business...
Not to mention you will need to run an 8-10 gauge wire to each light & relay, and keep the distance from the battery less than say 4 feet, and will also need to upgrade the alternator/battery/ground cables to 1/0 gauge in order to keep the current where you need it without frying the electrical system...
Old 01-10-2012, 11:06 AM   #15
WhiteKnightSTi
Member#: 169250
2001 Schweizer 300CB
(wirlybird)
What the hell is a "taxi light"? Do you mean a landing light.
WhiteKnightSTi is offline   Reply With Quote
Old 01-10-2012, 03:09 PM   #16
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
I don't want to quote mistakes.
If this is 28V dc, then you need to draw 40A from your battery. You need a 16A output boost converter. This is essentially constant power with a switching supply (minus losses) so your input current is stepped up. So 450W/12V with efficiency is 40A CONSTANT CURRENT. Pretty close to what you need to start your car, but continuously pulled.
If you want to design one, I would recommend that you start right out with an interleaved boost design. Easiest way to do this is to just use a PFC interleaved part. You'll want to go continuous current for this kind of power because even with the interleaving, transition mode isn't going to be very good. Look up the datasheet, app notes and seminar topics for a Texas Instruments ucc28070. From a power designer perspective, it's pretty straight forward and the part is pretty mature at this point.
If any of this is unclear, you don't want to even do anything.
Wanna guess what I do for a living and for whom?
Old 01-10-2012, 03:11 PM   #17
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Taxi light is on the front landing gear, and is used during, well, taxi on the runway
North Ursalia is offline   Reply With Quote
Old 01-10-2012, 03:14 PM   #18
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
http://www.ti.com/tool/pmp2351
Here's the pre-cursor that my buddy Mike did before we had the 28070. This will also work.
Old 01-11-2012, 08:24 AM   #19
nperkins
Member#: 135812
90 Miata
04 Evo Rally Car
Apparently I have an oops in my calculations? I'm no EE, but I thought I was doing it right...
Old 01-11-2012, 10:01 AM   #20
jeepnut_nh
Member#: 261162
2000 Outback Sport
blue
really?
yup
im pretty sure the ground crew likes going home with no burns and eyesight intact
jeepnut_nh is offline   Reply With Quote
Old 01-11-2012, 10:19 AM   #21
scottyb0119
Member#: 277399
WR Blue
You dont need 8-10 gauge wire, and it can be much longer then 4 feet. Aircraft wiring is made to be light they only use ~14 gauge wire and I assure you its longer then 4 feet from the battery, realy, and contactor.
I don't know where the OP wants to put these lights concidering they're all sealed beam style lamps...
scottyb0119 is offline   Reply With Quote
Old 01-11-2012, 12:03 PM   #22
nperkins
Member#: 135812
90 Miata
04 Evo Rally Car
Are they using a different material other than copper or something?
http://www.rbeelectronics.com/wtable.htm
I was a little off on my distances, but if you look at that chart, at 12 volts, and 40 amps, the max recommended for 14ga wire is 7'.
Old 01-11-2012, 01:21 PM   #23
scottyb0119
Member#: 277399
WR Blue
Im just going by my personal experiance in the aviation industry, I see what that chart says but I know that the wires going to the wing landing lights are probably 25ft long at least.
I think the OP should look at other ideas for extreme lighting, something in HID or at least keep it in the 12v range.
Old 01-11-2012, 01:42 PM   #24
nperkins
Member#: 135812
90 Miata
04 Evo Rally Car
Oh I agree completely. On the rally car we have bumper pods & a hood pod, all with typical circular lights, all 6k HID, and on startup, if all 6 lights are enabled at once, it pulls like 28 amps of current (yes this was measured) and after all 6 warmed up, levelled off around 13 amps... That was running 8awg from battery to relay panel, 12awg across the relays, and then I believe I used 18awg from the relay panel to the hood & bumper, keeping grounds as short as possible.
Old 01-11-2012, 02:12 PM   #25
nikiSTI
Member#: 146743
2005 STi Stg 2
I appreciate all the input, I do have aircraft wiring that I can use. I'm an aircraft maintainer for a living that's how I have access to all that stuff. The difference between taxi and landing lights is that the landing light is a 1000w at least on the airframe that I work on.
The reason I even decided to mess with this is just boredom at work, and I figured it wouldnt be a bad idea as far as cost goes judging by how much the hid lights go for
Door Light Mod and map light mod What ya think? twofastsubaru Interior & Exterior Modification 14 01-20-2008 12:14 AM
04 cluter light mod same as 03 mods? NVSPRELUDE Electrical & Lighting 1 10-28-2007 08:52 PM
All my mods are for sale. (cross post :) ) + Head Light mod, if you haven't done it.. Keith Tri-State Area Forum 6 01-19-2002 09:22 AM
Fog light mod in mod section, MY00 RS please look? joostin420 Technical Forum Archive 5 08-25-2000 08:08 AM
