Welcome to the North American Subaru Impreza Owners Club Friday September 4, 2015
Old 04-24-2011, 02:33 PM   #1
Ryguy32789
Member#: 214559
2005 WRX
Default Installed My Morimoto Mini H1 Projectors
Hey everybody, just thought I would share some of my experience installing the Mini H1 projector kit I got from The Retrofit Source (well, my girlfriend bought them for me for my birthday from them, but I digress...), and this was my first time ever retrofitting headlights.
I used this thread to learn how to open up my headlights. I'm not going to lie, it was nerve racking baking the headlights in the oven and ever so gently trying to pry them apart.
I ran into a problem when I went to mount the projectors. The blobeye H1 halogen bulb holder is a separate piece from the reflector. It's also the exact same size as the nut that holds the projector in, so it could not be modified and had to go.
As you can see, the nut and bracket are the exact same diameter.
So unsurprisingly, the nut was too small for the hole.
The kit comes with washer-like adapters for H4 or H7 housings. The blobeye is H1. I did not want to go hacking up my housings to get a plain large washer to lay flat against the back of the reflector bowl, so I got creative with one of the included adapters (I don't know if it was the H4 or H7 as I dont know which is which. All I can say is that it was the smaller adapter).
Took a grinding wheel to it and came up with this:
Which now fits perfectly here:
And as an added bonus, with the slightest of trimming, the tab on top of the adapter even slides into the little notch on the top of the hole in the back of the reflector. This means that the cutoff is locked into a level position. I dont know if it is a design similarity to the H4 or H7 bulb or just plain amazing luck, but it worked out perfectly.
All in all, it took about a day from start to completely finished. I'll be sure to post up pics of how it looks and some night shots tonight.
Ryguy32789 is offline   Reply With Quote
Old 04-24-2011, 02:35 PM   #2
Ryguy32789
Member#: 214559
2005 WRX
Heres an output shot. I'm still trying to dial in the aim.
And some daytime pics. I agonized over whether or not to clear my headlights and even test fit them without the reflectors, but decided I wanted to keep them for now.
Old 04-24-2011, 06:27 PM   #3
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
+2 for output shots!
Old 04-25-2011, 09:05 AM   #4
Ryguy32789
Member#: 214559
2005 WRX
Updated with an output shot. I can't believe the range of vertical adjustment in the stock bowls, it gives you like 45 degrees of adjustment.
Old 04-25-2011, 11:27 AM   #5
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
Good work! That looks 100x easier than my fx35 bi-xenon retro. I had to hack everything under the sun to make those fit.
skingfreak is offline   Reply With Quote
Old 04-29-2011, 02:14 PM   #6
technine
Member#: 219993
I'm getting these now for sure. Nice easy mod to get them to fit.
technine is offline   Reply With Quote
Old 09-20-2011, 01:29 PM   #7
wumfpirate
Member#: 179656
2005 Impreza
San Remo red
Hi Ryguy,
Is that the mini gatling shroud or the standard gatling shroud?
wumfpirate is offline   Reply With Quote
Old 09-20-2011, 02:04 PM   #8
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
Thank You Thank You Thank You!!!
I have been searching for well over a year on a good how to of what it takes to install the Mini H1's into a blobeye!
subaru_steve is offline   Reply With Quote
Old 09-20-2011, 04:54 PM   #9
Ryguy32789
Member#: 214559
2005 WRX
Originally Posted by wumfpirate View Post
Hi Ryguy,
It's the standard shroud that comes with the Stage III kit from TRS. They have it listed as the Mini Gatling Shroud.
Old 09-20-2011, 11:11 PM   #10
turboed13b
Member#: 294289
If you remove the washers between the top two post of the bowl and lens holder it will fix the bowing in the cutoff.
turboed13b is offline   Reply With Quote
Old 09-20-2011, 11:40 PM   #11
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
^I tried that with my Generation 3 (before the 4.1s came out) H1 projectors and it made the cutoff very yellow.
I added an extra washer on each bolt (2 on each, total of 8 on each projector) and it made the color VERY sharp and purple.
The other projector is still a little yellow and only a little blue/purple. I think there's a bulb seating issue. I bet if I had only 1 washer on the top bolts it wouldn't bow.
Turboed13b, are you on HIDPlanet.com? I think I've seen your username?
Smoke is offline   Reply With Quote
Old 09-20-2011, 11:51 PM   #12
Ryguy32789
Member#: 214559
2005 WRX
I've wondered about that, but it doesn't bother me nearly enough to open the headlights back up. The output is still great for driving at night, and they have an awesome rainbow color flicker
Also, that shot is with the car very close to the garage. Farther away the cutoff looks better.
Old 09-21-2011, 12:04 AM   #13
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Did you just get the kit with the newly released H1 projectors?
I've seen those modded how 13b said and it straightens out the cutoff and adds more color.
Not in my case though.
Old 09-21-2011, 12:23 AM   #14
Ryguy32789
Member#: 214559
2005 WRX
I got them back in March, installed em in April. I think they are the newest version, they're the ones with the screw-in shrouds instead of the snap on ones.
Old 09-21-2011, 01:10 AM   #15
turboed13b
Member#: 294289
Yep I am on there but it is turbo13b instead.
Old 09-21-2011, 07:47 AM   #16
RSXNTN
Member#: 287358
2006 2.5i
Regal Blue Pearl
Looks great. I am one of those A$$H***$ who put an HID kit into my non HID projectors (06 2.5i). I had no idea I wasnt getting the full benefit of HID nor did I realize I was still blinding people. I was finally "schooled" when I joined NASIOC. I have gone back to halogen until I can afford these. Gonna wait and do the Bi-Xenon and Blazer fogs all at once.
RSXNTN is offline   Reply With Quote
Old 09-21-2011, 11:51 AM   #17
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Okay, I am Pudding Cup.
Old 09-21-2011, 04:05 PM   #18
Ryguy32789
Member#: 214559
2005 WRX
Oh, and just one more thing to add about the install on these, I was not able to use the really fat rubber washer that came with the kit, but I did use the thinner rubber washer between the oem reflector and the projector and it's still working beautifully.
Old 09-21-2011, 04:30 PM   #19
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
Thanks for taking them out, its nice not to fight with someone over this
Let me know if you get the blazer fogs and how they do, I have an '04 WRX and was looking at those, but idk.
Old 09-26-2011, 05:56 AM   #20
T-Johnson16
Member#: 241971
2009 Spec.b
Quartz Silver
Sorry first couple pics were phone pics but love the outcome of these projectors.
T-Johnson16 is offline   Reply With Quote
Old 09-26-2011, 05:58 AM   #21
T-Johnson16
Member#: 241971
2009 Spec.b
Quartz Silver
Same thing with me That's when I picked up the morimoto's
Old 09-26-2011, 11:11 AM   #22
lllarrolll
Member#: 271569
2010 Impreza 2.5i 4D
Spark Silver
And same with me also! Lol, picking up mine next month! Can't wait.
lllarrolll is offline   Reply With Quote
Old 09-26-2011, 11:52 AM   #23
Ryguy32789
Member#: 214559
2005 WRX
Did you black out your oem reflector bowls? If you did can you get a better daytime pic of that?
Old 09-26-2011, 04:44 PM   #24
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Good job! How are the high beams?
Old 09-26-2011, 08:19 PM   #25
T-Johnson16
Member#: 241971
2009 Spec.b
Quartz Silver
Awesome upgrade, not very expensive either but great results.
Yeah blacked out reflector bowl because it looked so much cleaner. I only have a pic reassembled, All I did though was made sure I didn't miss and you put a couple coats and turned out pretty badass. Hope this helps.....
The bixenon is the one thing that isn't hooked up right now, Buddy back home is going to help me wire that up soon though. But now completing this I kind of want to do a quad retrofit because it looks so damn sexy lol
Need Advice: Moromoto Mini H1 Into Blobeye Ryguy32789 Electrical & Lighting 4 03-29-2011 05:00 PM
FS : Brand New Morimoto H1 Projectors Felginator Tri-State Area Private Classifieds 1 03-04-2011 08:55 AM
FS : Brand New Morimoto H1 Projectors Felginator Exterior/Styling 1 03-04-2011 08:54 AM
Mini H1 HID Projector headlights review with pictures done by LIGHTWERKZ.net billy boi Member's Car Gallery 7 09-08-2010 05:16 AM
who can either do or help me install my tsx projectors in my 04wrx blckrex Southern California Impreza Club Forum -- SCIC 30 02-20-2007 11:12 PM
