Old 04-24-2011, 07:26 PM   #1
dan1587wrx
Member#: 132107
2006 WRX Stage 3
340WHP 340WTQ WRB
Default 06 WRX Stalls Out When Clutch is Depressed
I have an 06 WRX with a VF39, EWG, AP and protune and supporting mods. Recently I have noticed that when I am on a highway doing 70 - 80mph and need to slow down to pass through a toll both the car stalls out when I push the clutch in or put the car in neutral. I usually push the clutch in and put the car in neutral for maybe a 1/4 mile before the toll both. When the car is in neutral I can watch the rpms drop down to idle speed (approximately 600rpm) and then they start bouncing around and going below 600rpm and maybe up to 1000rpm. While this is occurring I have been watching oil pressure and it usually bounces around from a minimum of 20psig to 40psig. Eventually if I do not blip the throttle the car stalls out.
Sorry for the long story. If any one has some insight I would greatly appreciate it.
Dan
dan1587wrx is offline   Reply With Quote
Old 04-24-2011, 07:38 PM   #2
abrumlev
Member#: 197920
2005 Legacy GT
ABP
Check your vacuum connections...that's the most common cause of crappy idle.
abrumlev is offline   Reply With Quote
Old 04-24-2011, 07:57 PM   #3
dan1587wrx
Member#: 132107
2006 WRX Stage 3
340WHP 340WTQ WRB
The thing is the car does not idle rough when just sitting there. This only happens as the car is moving.
Old 04-24-2011, 10:30 PM   #4
NemesisSi
Member#: 79805
2011 Acura TSX 2.4
This may or may not be related......I have noticed since going stage 2 AP platform that when I am rolling/cruising at speed and put the clutch in and then blip the throttle I have no to very small rpm change. I actually have to hit the gas pedal pretty good to get a rev. When I am parked and do the same thing I have almost instant rev response at the level of input force. There still is a tiny bit of delay but that is just because of the TBW system.
Reminds me of a car that is flooded and hard to start.
NemesisSi is offline   Reply With Quote
Old 04-25-2011, 03:07 AM   #5
GDBF
Member#: 108473
2006 WRX Blouch
340whp/363wtq
Do you have an after market intake? Your maf is reading too much air when theres no load.
GDBF is offline   Reply With Quote
Old 04-25-2011, 12:36 PM   #6
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
Yep. 3 solutions, get the tune fixed, get rid of the intake, or stay in gear when you're coming to a stop(obviously clutch in at some point, but not at 80mph).
elevenpoint7five is offline   Reply With Quote
Old 04-25-2011, 01:18 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
if you decel in gear, clutch pedal out....your injectors are OFF as in not injecting fuel and you will save gas
and see above for the 'fix' many times this is a vac leak issue
Old 04-25-2011, 06:55 PM   #8
NemesisSi
Member#: 79805
2011 Acura TSX 2.4
I could see reduced in cycle but not off. If they were off then my motor would shut off totally due to fuel starvation.
Old 04-25-2011, 09:31 PM   #9
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
:shakes head: No, they are definitely off. 95% of modern cars are set up that way.
Old 04-25-2011, 09:59 PM   #10
NemesisSi
Member#: 79805
2011 Acura TSX 2.4
My bad... I misread the initial quote from Uncle Scotty. I just realized he said clutch pedal out meaning you are coasting while in gear. The injectors are cutoff and the gears are forcing the motor to push air out. Spark is turned off to I think preventing lean explosions.
What I have noticed on my car is when my clutch pedal is put in and I rev at speed it seems my car will not rev unless I give it a good blip vs just sitting at a light and give it a light tap. My thoughts are possibly issue is because of my light flywheel, my tune or the inj cycle is reduced to save gas. From my understanding the inj do have to be on if the clutch is detached from the tranny, I.e. pedal pushed in.
If its a vacuum leak would I have other noticible issues. This has been going on since day one of the new tune.
And another thought....it maybe my dumb*** just not giving it enough gas because I rev match (heal and toe) without issues.
Old 04-26-2011, 12:17 AM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
no...yer STILL wrong
if you are in gear.....no throttle pedal....slowing down.....the injectors are OFF as in no gas....no pedal at all of any kind....feet in the back seat...no injectors firing
and if this only started with the new tune, the tune is bad
trust me on this
Old 04-26-2011, 12:25 AM   #12
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
trust me on this
Explain deceleration backfire if there's no fuel (which happens on completely stock cars).
NitroTrike is offline   Reply With Quote
Old 04-26-2011, 01:14 AM   #13
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
If every last bit of fuel was burnt there would be no "need" for catalytic converters. There's still fuel vapors in the exhaust system. Also, just because you snap the throttle shut, doesn't mean the injectors can stop quite as quickly.
Scotty is right, if it started with the tune, then it's the tune.
Old 04-26-2011, 01:17 AM   #14
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
Just to elaborate a bit, the injectors come back on at ~1100rpm. This varies per ecu and car, but they're all in the same general area. So even coasting in neutral, from redline until ~1100rpm, your injectors are still off.
If you have to hit the throttle pretty hard, then ask your tuner to adjust your DBW mapping to proper settings.
Old 04-26-2011, 08:42 AM   #15
NemesisSi
Member#: 79805
2011 Acura TSX 2.4
trust me on this
Ummm.....I think that was what I just said in my second post. You might want to read it again. I'm saying that the inj are on when you are out of gear, no attachment to tranny. Motor needs fuel then to keep running....very little.....but still needs fuel. I agree with you on the other part when in gear, pedal out that they are turned off.
Old 04-26-2011, 08:45 AM   #16
NemesisSi
Member#: 79805
2011 Acura TSX 2.4
Ya will probably ask Cobb since they are the ones who tuned the car originally. I have always wondered about the sensitivity of the DBW. Friend of mine does a lot with the new Mustangs and he is always fixing the factory calibrations!
Old 04-27-2011, 07:58 PM   #17
Operanal
Member#: 127249
2006 WRX Limited
I have been having this same exact problem for the past few weeks on my bone-stock '06 WRX. I drive about 40 miles on the highway to and from work. Driving to work in the morning is no problem, but as I approach the end of my highway commute home, if I go into neutral and/or hold in the clutch, the revs bounce around (as does the negative boost levels from -4 to -7 PSI), followed by a stall. To start the thing back up, I have to press in the gas pedal as I turn over the engine. The following morning, the car runs fine again. This happens just about daily.
The car had thrown two CEL codes relating to the throttle position sensor, so I bought a ported-and-polished throttle assembly (with TPS) replacement from Grimmspeed. Prior to that, I tried fuel cleaner, as well as cleaning the throttle plate itself with the appropriate cleaner with no luck. Now, even with the changed throttle assembly I am consistently seeing the behavior described above.
I am stumped, but I think the mods and tuning probably aren't your problem, either.
Operanal is offline   Reply With Quote
Old 04-27-2011, 08:30 PM   #18
Uncle Scotty
Member#: 16200
OK buy Nates beans
my 06 wrx dont do that....
I dont have any vac leaks, either
Old 04-27-2011, 11:11 PM   #19
dan1587wrx
Member#: 132107
2006 WRX Stage 3
340WHP 340WTQ WRB
The car was tuned about 3 years ago and has not changed. It was tuned with an SPT intake which has not been removed. I dont think the tune is an issue because this has only started happening with in the last 6 months. And i dont believe there are any vac leaks. I have pressure tested the system and could not find anything. Also i am still making and holding boost exactly like it did when the car was tuned.
Could this have something to do with the gas available currently having 10% ethanol. I have heard that the increase in ethanol creates more water vapor in the fuel tank and fuel system but I dont know how to check for this.
Could something be wrong with the EGR valve?
Old 04-28-2011, 01:10 AM   #20
Uncle Scotty
Member#: 16200
OK buy Nates beans
you dont have an egr vlve...you DO have a pcv valve and that may cause some of this if it is sticking a bit
Old 04-28-2011, 07:07 PM   #21
dan1587wrx
Member#: 132107
2006 WRX Stage 3
340WHP 340WTQ WRB
I will have to check that. But if it was sticking wouldnt the car stall all the time when in neutral.
Old 04-30-2011, 11:12 AM   #22
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Our cars run 10-11:1 AFRs at WOT. The stoichiometric ratio for gas is 14.7. This means that a good 30-40% of the fuel you're spraying into the engine at WOT does not get burned. Most leaves the combustion chamber as vapor, some leaves as liquid. There's no fresh air in the exhaust though, so this fuel can't ignite, it just blows straight through the exhaust. When you let off the gas and the injectors shut off, combustion stops and the engine pumps fresh air into the exhaust system, which allows the little bit of fuel that's left floating around in there to ignite. This is what causes afterfire or afterlighting.
Get a wideband, when you let off the gas the readings change to straight air until you get to ~1200 RPM and the injectors turn back on.
Old 05-05-2011, 05:23 AM   #23
dan1587wrx
Member#: 132107
2006 WRX Stage 3
340WHP 340WTQ WRB
Does this mean that the car will stall out due to the backfire or because the injectors turn off.
Old 05-05-2011, 06:03 AM   #24
143subaru
Member#: 157982
2002 Impreza WRX
World Rally Blue
I have an 02 wrx and what caused my car to do this was it was flooding itself like mad... It got so bad for me that I had to engine brake, or leave it in gear until revs hit about 1k before pushing the clutch in... So next time you push the clutch in watch your air to fuel...
143subaru is offline   Reply With Quote
Old 05-05-2011, 11:49 AM   #25
Clark Turner
Member#: 178047
02 WRX STI Spec C
Pressure test the intake to make sure you have no leaks. If its tight. Then this can be fixed in the tune. I put an anti stall system in my maps I have developed for years. But even my maps with a car that has intake leaks, will stall.
The real question here is why would you go 70mph and then push in the clutch to coast. Never coast a manual car down like that. You should down shift(rev match) all the way down to 2nd, Then you can push the clutch in and coast or brake to a stop. Half the people I ride with dont know how to Drive a stick.
When you go from high rpm to idle like that or if the engine stalls like in your case, You take the oil flow away from the motor and turbo... ITs hard on the engine. Not to mention if something happens and you need power, Your in neutral and you would be able to accelerate
If you want, Take a log of idle and I send it to me. I would be happy to look at it for you. I am pretty good at spotting leaks.
C
Clark Turner is offline   Reply With Quote
06 WRX Squeal On Cold Starts When Clutch Is Engaged dan1587wrx Transmission (AT/MT) & Driveline 35 06-19-2009 02:36 PM
Weird jingling noise when clutch is depressed... DoodieHead Transmission (AT/MT) & Driveline 9 01-14-2008 02:23 PM
Bad noise when clutch is depressed, dealer says tranny going out... AnthonyA182 Transmission (AT/MT) & Driveline 5 06-04-2007 01:45 PM
Car tries to stall when clutch is depressed. PolarisSnT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 12-05-2006 11:59 PM
Metallic Clicking sound when clutch pedal depressed Craig W Transmission (AT/MT) & Driveline 4 07-31-2005 10:14 PM
