Old 04-24-2011, 08:36 PM   #1
Leadsled124
Member#: 211350
2006 STI
Default Track advice with DCCD setup. Auto=more tire wear
Interested to see what DCCD setting you guys use at the track. Auto or fully open? Id prefer 07 and older guys chiming in since their dccd seem to react differently, but any comments are welcome.
When im in Auto mode the center diff grabs and binds a lot more, and im wondering if thats why i got very uneven chunky tire wear last time. Just pulling into my garage with minimal gas when i turn i feel it bind. ive heard this from a few other 06-07 owners. All the 08+ guys say auto is smooth no chatter. Latley ive been putting the car in full open everytime i drive or carve the canyons. Also us pre 08 guys do not have a auto +/- setting. i never know what your talking about when you say that.
So is full open quicker on the track assuming you can keep the car under control? I have much racing experience in the past but never had any nannies or traction control etc to deal with. Going back to the track in a week just looking for advice thanx
Leadsled124 is offline   Reply With Quote
Old 04-25-2011, 06:26 PM   #2
Leadsled124
Member#: 211350
2006 STI
Nobody has any advice on dccd settings at the track? BTW the title was supposed to have a "?" at the end but i cant edit that.
Old 04-25-2011, 06:30 PM   #3
WhatTurboLag?
Member#: 243992
2006 WRX TR
auto from what i hear
WhatTurboLag? is offline   Reply With Quote
Old 04-25-2011, 07:53 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I have an '06 STI transmission in my Legacy, controlled by a Spiider controller. I typically leave it in Auto for auto-x stuff. Really haven't done much open track time with it.
I've definitely never experienced any sort of binding, low speed or high speed, nor have I ever read about others having issues with it.
Old 04-25-2011, 08:11 PM   #5
04trailsti
Member#: 179170
Yeah Ive never heard of binding in auto. Ill start to get binding at full lock turns while in manual.
Ive messed around with it auto/ man for auto x. to me honeslty two from the rear makes the car feel more planted. but that for auto x which has sharper and much more of a durastic changed in direction and speed.
04trailsti is offline   Reply With Quote
Old 04-25-2011, 08:17 PM   #6
DCCDPro
Member#: 227549
I think he's talking about the stock STi system, and the stock "auto mode" is not adjustable like it is with my systems.
He basically is running what it would be like in auto mode on my controller having the knob turned about 3/4 or higher setting. Pretty aggressive in terms of maintaining lock, and a solid amount of understeer on the road/track.
I think this explains the wear on your front(?) tires.
Is the wear even front to rear? Does the car understeer entering corners?
DCCDPro is offline   Reply With Quote
Old 04-25-2011, 10:58 PM   #7
Leadsled124
Member#: 211350
2006 STI
Yes that is exactly how it feels. A little understeer entering corners and some chunking on mainly the fronts. The only reason i figured the biinding was normal is because the manual says "this may happen it is normal", and a few other sti's claimed the same thing in day to day driving
Old 04-26-2011, 05:09 PM   #8
DCCDPro
Member#: 227549
Yeah, I suspected that as the case.
I personally think that the 07's understeer too much in auto mode...the 08'+ is brilliant though!
Not much you can do with it really. There is no reprogramming them.
Rocket Rally makes a drop in replacement board...for $2k plus $700 per program, lol.
Old 04-26-2011, 08:51 PM   #9
Mind
Member#: 109216
08 STI DGM
76-77 Lancia Scorpion(s)
Why/how? And which setting?
Mind is offline   Reply With Quote
Old 04-28-2011, 01:00 AM   #10
Leadsled124
Member#: 211350
2006 STI
Are you saying thats due to the dccd programming or to something else like the a arm change? Im an 06 but not sure about any dccd changes
Old 04-28-2011, 10:26 AM   #11
Loubaru
Member#: 155489
07 STi
Good questions. As far as I know the only change to the '07 suspension wise is the LCAs that have less caster....
Loubaru is offline   Reply With Quote
Old 04-28-2011, 11:24 AM   #12
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
screw it! time to just hire some computer programming wiz to write a controller for a standalone unit that utilized a 3 axis g-sensor, steering, brake and throttle input...well clutch too actually. I can see some strategic uses of a clutch signal.
Now where did my Fundementals of Vehicle Dynamics book (by Gillespie) go?
Back on topic, didn't 07 get a widened rear track (I know it changed at some point)? It also has the FWD biased center diff gearing (like 06).
Edit: Ok, so only the 04 had a different rear track width.
Last edited by Homemade WRX; 04-28-2011 at 11:39 AM. Reason: Edit: found dimensions
Old 04-28-2011, 11:35 AM   #13
berdugo
Member#: 163108
07 EuroDM STi 2.5L
I have 07 STI, I always set the DCCD at full open all the time. At auto it loves to bind
berdugo is offline   Reply With Quote
Old 04-30-2011, 07:52 PM   #14
DCCDPro
Member#: 227549
^^^Yeah exactly, I think the stock auto mode is too tight on the 07's for track use personally.
I don't think its anything to do with suspension/geometry.
Old 05-01-2011, 12:07 AM   #15
RallyLegacy
Member#: 114353
97 Legacy,
05 BMW M3
Mine binds at auto too on tight low speed turns. I never thought about dd'ing on open to get rid of that. I also have forgot to play with it at the track, hopefully I will remember this weekend. I'll post up my results ( and hopefully times associated with them too so I have some quantitative evidence for at least how I drive).
RallyLegacy is online now   Reply With Quote
Old 05-01-2011, 12:08 AM   #16
Leadsled124
Member#: 211350
2006 STI
^^^ Im glad to hear that because that means my binding is somewhat normal and theres not anything wrong in the drivetrain. Lately i've been doing exactly that. Its almost a habit now to click into manual full open soon as i start my car
Old 05-01-2011, 03:44 PM   #17
RallyLegacy
Member#: 114353
97 Legacy,
05 BMW M3
Same thoughts exactly. I thought it was abnormal but after seeing all these posts I feel a little better. At least that means we have a strong center diff that is too strong on auto at low speeds
Old 05-01-2011, 04:22 PM   #18
silverhks
Member#: 242402
I don't get any binding in daily driving or auto-x. I have been fighting understeer but I believe that is from other sources...
silverhks is offline   Reply With Quote
Old 05-01-2011, 05:16 PM   #19
RallyLegacy
Member#: 114353
97 Legacy,
05 BMW M3
But what year do you have? So far from what I have gathered it seems to be an 07 thing. I don't get it at autox, mainly low speed stuff as I am turning while letting out the clutch. Once the clutch is out all the way I don't really get it at all. I can do steady speeds turns at full lock and not get it either, so it seems to only be in the 0-5mph range for me at least.
Old 05-01-2011, 06:21 PM   #20
DCCDPro
Member#: 227549
The trouble with running on an "open" setting, is that you get benefit coming out of the corners from the awd system.
What you want is to enter the corner nearly open and exit with proportionate lockup as you straighten out "on throttle". This is something I worked very hard to perfect with my controllers. Putting it in open just means you lose traction and time out of every corner. This is only on sharp corners where you need to get moving again...on long sweepers, who cares.
Old 05-01-2011, 07:40 PM   #21
Leadsled124
Member#: 211350
2006 STI
Its an 06 thing as well seeing im 06
Old 05-01-2011, 08:08 PM   #22
Leadsled124
Member#: 211350
2006 STI
I actually just got back from the track today. I tried full open and auto. In full open it was kinda fun because in the tight switchbacks you can actually kinda get the rear end a bit loose and kinda pitch it in the direction you wanna go, but comparing lap times auto mode was a few tenths faster constantly. Your right too exiting the tight turns, especially this uphill turn exit at my track open tended to push out to much
Old 05-01-2011, 08:11 PM   #23
DCCDPro
Member#: 227549
That "open" rwd feeling is super fun...I have to admit.
Having tire wear, then alignment, then more wear? Subydude81 Tire & Wheel 2 09-03-2007 01:03 AM
Need advice with strange tire wear. SLOMatt Brakes, Steering & Suspension 7 02-08-2006 01:50 PM
Tire wear due to suspension setup? Impretzle Brakes, Steering & Suspension 7 07-13-2005 02:30 AM
Abnormal tire wear during track events? Scott Farmer Motorsports 15 05-27-2005 08:53 AM
Advice on outer tire wear triguy Motorsports 8 11-09-2004 10:05 AM
