Old 07-19-2002, 11:53 AM   #1
AMR MOD
Member#: 2879
2002 Acura RSX "S"
Default Boost Control for AMR LINK2
Skywalker and I went out to test and trouble shoot the boost control last night and found that it does indeed work. I believe it was a matter of having the Vacuum hoses connected right and maybe the polarity of the wires(Not sure about this). Most importantly was the settings for the WG base and Wg Sens settings to get it working. We are using a Internal Wastegate type of solenoid and hooking up the External wastegate as an internal wastegate(Top port of Wastegate is not used). We got it working last night with slight boost spiking and probably need a little more tuning to stabilize the settings. For better control LINK does sell a External wastegate type of solenoid for better control of the wastegate for $260. Please call or email us if anyone has any questions.
AMR
510-870-6361
[email protected]
AMR MOD is offline   Reply With Quote
Old 07-19-2002, 11:19 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
AMR - Thanks for the info. Please be careful about walking the thin line between information and non-approved vendor sales. The reason? The post was reported....
kastle is offline   Reply With Quote
Old 07-20-2002, 12:37 AM   #3
AMR MOD
Member#: 2879
2002 Acura RSX "S"
Sorry, it was not meant for sales. I just wanted to clarify that The link2 does control boost and I know there were a few people that was curious on a update about it.
AMR
Old 07-20-2002, 01:35 AM   #4
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Dually (or however that's spelled) noted. Thank you for clearing that up for me (and us for that matter).
Old 07-20-2002, 05:50 AM   #5
N/A
Member#: 133
TBA TBA
TBA
I was wondering what happened to your plans on using the cheaper boost solenoid that you had. So by minor boost spike what kind of amounts and duration are you talking about?
N/A is offline   Reply With Quote
Old 07-20-2002, 11:14 AM   #6
AMR MOD
Member#: 2879
2002 Acura RSX "S"
Lightbulb
Well actually that solenoid works well with internal wastegates. We are currently trying to see how well it will work with the TIAL external wastegates. Every turbo charger with wastegate has different spool characteristics, so some time may be needed to fine tune WG base and WG Sens settings to have desirable results. I do not see any reason why this solenoid wouldn't work. Currently we are hooking up the Tial external wastegates to bleed off similar to a internal wastegate. If people want to run constant higher boost levels ie. 15+ psi, I recommend using the more expensive stainless steel LINK external wastegate boost control solenoid. Otherwise the internal wastegate solenoid we sourced out should be good for people runing upto 10-12psi when using an external wastegate. I imagine 10-12 psi should be good enough for most guys that do not have a built motor.
FOR SALE: Intake, EM, Boost Controler for WRX/STi JASWRX Engine/Power/Exhaust 0 10-10-2006 07:42 PM
Whats the best electronic boost controller for a WRX? MCCSpear231 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-11-2001 12:13 AM
What kind of boost controller for WRX's? dannyboy7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-19-2001 07:06 PM
Got a new Greddy Boost Controller for $90, now what? Help. SubyPrez20 Tri-State Area Forum 0 04-20-2001 07:41 AM
