Old 04-22-2001, 01:48 PM   #1
Im'Pat'za
Member#: 2894
2001 2.5 RS
Talking Stock 4EAT -> Tiptronic AT
Hi, I did a search on changing the stock Automatic transmission system to a sportshift, tiptronic AT one; it seems that the 'levelten' company is making one (or is it finished already?) If it's finished, anyone has the result and price on that?
One more question, I have a MY01 RS 4EAT. I know the transmission will engage in 90/10 split after the 2nd gear, and there is a way to modify it and lock it on 50/50 all the time. Does anyone know how to do that? And since there are comments said about changing to 50/50 will damage the tires and/or AWD system in the long run, would it make our 4EAT cars slower on corners?
Thanks for commenting!
Pat
Im'Pat'za is offline   Reply With Quote
Old 04-22-2001, 02:08 PM   #2
Andrew
Member#: 1170
2005 STi
Post
i think the locking it in 50/50 is by putting in certain resistors and tricking the ECU to thinking the fronts are slipping.
you can get a torque converter though and change the torque split to 50/50 in all gears if you want. i have heard that it even gets you 1sec quicker on the 1/4mile
[This message has been edited by Andrew (edited April 22, 2001).]
Andrew is offline   Reply With Quote
Old 04-22-2001, 02:33 PM   #3
DEVO-2nd GEN
Member#: 3869
Talking
oooooo..
very intersted in both
need more info !!
DEVO-2nd GEN is offline   Reply With Quote
Old 04-22-2001, 05:11 PM   #4
Im'Pat'za
Member#: 2894
2001 2.5 RS
Post
bump
Old 04-22-2001, 06:38 PM   #5
Overtime
Member#: 1346
Post
Um, why would you want to lock the AWD system at 50/50? Isn't the advantage of Subaru's system the fact that it's not static (like BMW's and others'?)
Overtime is offline   Reply With Quote
Old 04-22-2001, 07:09 PM   #6
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Post
50/50 all the time would be full time 4WD.
So you want a truck?
remarcable is offline   Reply With Quote
Old 04-22-2001, 08:19 PM   #7
Im'Pat'za
Member#: 2894
2001 2.5 RS
Post
Although the system will become full time AWD, wouldn't it be better though?
I mean, if it's not good, why is the manual transmission ones in 50/50 split, are they driving a truck? I don't think that would be the case, would it?
Moreover, shouldn't 50/50 allow us to control bad weather such as rain and snow better? Also, if the 90/10 split is better after the 2nd gear, why isn't the manual like that?
All in all, I am not expert in any of these fields; I thought full time AWD is better... Prove to me if that's wrong...
Old 04-22-2001, 08:39 PM   #8
DEVO-2nd GEN
Member#: 3869
Post
i think the keyword being "locked" here..
the 50/50 on manual isn't locked, it's just like that at normal, and torque is transferred to the front when rear slips, thus making it >50/<50
so anything that can make the 4EAT like the 5MT is probably what you(me) are looking for
come to think of it.. it's no easy task.. hmm.. damn!
Old 04-22-2001, 09:38 PM   #9
Jessie James
Member#: 2072
Post
LevelTen has a shifter device which is $1500. 'Nuf said.
They have torque converters and performance rebuild kits also, all three to the tune of about $3500.
I am researching a way to shift manually, athough not really Tiptronic, so give me some time. I've found about three solutions, but the cheapest is $1226. Still too much $$$ for me.
I have a neighbor who is head mechanic at a local Subaru dealer, and I hope to pick his brain a lot. I have two goals:
1. Manually shift the transmisison up/down at will
2. Increase line pressure when shifting for crisper shifts and more performance.
Both can be done, I just need research. I will probably go with a LevelTen TC and rebuild kit, but not their shifter.
Check my web site for occasional updates. (None this month... I've been lazy!)
Jessie James is offline   Reply With Quote
Old 04-22-2001, 11:34 PM   #10
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
Maybe its just my tires getting bald (read: less grip), but when I'm taking a corner at 2nd, it seems that the car is just losing traction, mind you its like a four wheel power 'slip', but a bit disconcerting at times. The rush of power is there though, power through all four wheels is quite nice.
Keiho is offline   Reply With Quote
Old 04-23-2001, 02:35 AM   #11
ivbdn
Member#: 2736
2001 Impreza 2.5RS
Post
Keiho -
I feel ya on that one. Took me off guard the first few times it happened.
ivbdn is offline   Reply With Quote
Old 04-24-2001, 07:00 AM   #12
Im'Pat'za
Member#: 2894
2001 2.5 RS
Post
does the Japanese wrx in old style offer sport shift?
Old 04-24-2001, 10:16 AM   #13
quikE
Member#: 6042
Post
SAE defines any kind of split rather it be 90/10 or what have you, all as 4WD.
quikE is offline   Reply With Quote
4EAT Issue: At stop sign/traffic light, car stays in neutral when I step on the gas. YinUCSD Transmission (AT/MT) & Driveline 9 02-10-2006 10:43 AM
4eat gone at 16k not covered iceinject Warranty Issues & SOA Problems 64 01-10-2005 12:25 AM
Dynoed your stock 4eat??? jerymon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 01-26-2004 03:25 PM
Tiptronic AT on the 2005 Legacy... your opinions? slippers2k Legacy Forum 1 07-05-2003 03:27 PM
Whats the max anyone has boosted on a stock EJ25 and stock 4eat? Andrew Normally Aspirated with bolt-on Forced Induction Powertrain 23 09-03-2001 11:10 PM
