Old 07-19-2002, 02:11 PM   #1
statman
Member#: 20860
Question I'd like a definitive answer on resonator mod...
Does pulling out the stock resonator actually free-up airflow and help the car to breathe (thereby potentially increasing HP) or is it a "sound only" mod? I've heard both explanations given. I'd like to know the general consensus before I pull the thing out...
Thnx..
Statman
statman is offline   Reply With Quote
Old 07-19-2002, 02:20 PM   #2
BeavisNuke
Member#: 14981
2002 WRX Sedan WRB
TurboXS Stage 2.5
Whatever air it does free up is supposed to be negligible I believe.
Most consider it a "sound-only" mod.
BeavisNuke is offline   Reply With Quote
Old 07-19-2002, 02:25 PM   #3
WagonRX
Member#: 7480
WRB WRX 5 Door
VS2 12.9 @105 MPH-4EAT
According to Shiv, it's just a sound mod.
WagonRX is offline   Reply With Quote
Old 07-19-2002, 02:36 PM   #4
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
More air is always better
MAD REX is offline   Reply With Quote
Old 07-19-2002, 02:49 PM   #5
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
According to MRT, who have much more experience than Shiv, its not just a "sound" mod, it has actual measured performance benefit. The benefit is rather slight, but it does exist.
Cosworth is offline   Reply With Quote
Old 07-19-2002, 03:02 PM   #6
02WRX_BLUE
Member#: 13704
2006 EVO MR
Apex Silver
When the TURBO is sucking all the air to compress... I would say that it would not show any difference.
However, think about the initial air flow that is happening before turbo is spooiling to the max boost... More air is available for engine to suck in than if you didn't remove the resonator so that the initial response would be better and should give more power... It would also help TURBO to spooil as well.....
This is the reason why you feel better response from the "GAS padal" when you do the intake mod in general....
I wouldn't completely remove it... I would cut the resonator in half so that you can still suck in the air from the fender wall...
Dan from PA.
02WRX_BLUE is offline   Reply With Quote
Old 07-19-2002, 05:18 PM   #7
kenchan
Member#: 15106
yah, hacking it does seem to free up more initial air and provide a more reponsive acceleration. im letting it breath from the fender area with a hacked resonator. some have capped the bottom of the Y piping of the resonator so that it would breath directly from the front intake. i wouldnt do it. 1st off theres more unnecessary piping that the air needs to be sucked from and, i bet there's more turbulence if you cap the bottom portion of the Y causing less air to smoothly flow into the air box.
kenchan is offline   Reply With Quote
Old 07-19-2002, 09:39 PM   #8
JohnGalt00
Member#: 17035
02 WRX
I did the mod, I didn't seem to get much power, if any, but the throttle was definitely more responsive according to the butt dyno.
JohnGalt00 is offline   Reply With Quote
Old 07-19-2002, 10:57 PM   #9
Vegumkoho
Member#: 12059
2002 WRX Blue
Wish all roads were dirt
I will be doing it this week-end. I got a velocity thingy from a friend (FREE) so I won't have to hack. I don't expect noticable power gains, maybe better throttle response and better noise.
Vegumkoho is offline   Reply With Quote
Old 07-19-2002, 11:01 PM   #10
jaxscuby
n00b Moderator
Member#: 10613
2002 USDM WRX
Have a Nice Day? anything to help it breathe
oops..i took mine out along with snorkel..
replaces with velocity stack...filled up the gas tank and got 320 miles when i would usually get 300 miles out of a tank.
mixed mileage city & highway. going a sunday drive to see if this holds true..other trip i would get around 300 to warning light..so will have some new data as far as mileage after sunday's trip..
but the swoosh is definitely noticable...
Old 07-19-2002, 11:25 PM   #11
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
Default Re: I'd like a definitive answer on resonator mod...
Thnx..
Statman
I tried it. I noticed nothing but noise. I was thinking of trying the new Prova ducts from Japan. Vividracing.com has them instock. I got a chance to see them in person yesterday. The Prova duct replaced the resonator and pipes the front duct into the air box with a nice smooth Fiber/plastic duct. The only drawback is the cost.. Its from a high end Japanese tuner and it was imported.
CT
AZScoobie is offline   Reply With Quote
Old 07-20-2002, 02:35 AM   #12
cohlineman
Member#: 20982
2002 Impreza WRX
Platinum Silver
Default just finished snorkusectomy
I just got in from the garage after an hour battle with the snorkus (its lower bolt causing very bad language).Aquick trip around the block did show me a bit of added throttle response but maybe I'm just convincing myself!I did notice a very nice augmentation in sound for sure.The cutting of the snorkus sounds like a good way to isolate the intake , I might just buy a spare for that but I will try the weather stripping first.For looks I re-mounted the intake scoop and am thinking of wrapping it in heat cloth adhesive...it's always more air, I think.Got news that my new exhaust is now on the pacific in a ship from the land of the rising sun...that will definitely help in the sound dept. too!
cohlineman is offline   Reply With Quote
Old 07-20-2002, 08:16 AM   #13
jaxscuby
n00b Moderator
Member#: 10613
2002 USDM WRX
Talking velocity stack
heres a picture of air box with stack..
Old 07-20-2002, 08:17 AM   #14
jaxscuby
n00b Moderator
Member#: 10613
2002 USDM WRX
Talking heres looking into fender..
fender view..
Old 07-20-2002, 08:41 AM   #15
MackDaddy
Member#: 15451
2013 XV Crosstrek
Desert Khaki - CVT
Talking Hey, that's my car!
No problem, glad to see someone remembered me for reference.
This mod helps big time. Add in a nice panel filter (Blitz, K&N) and it makes for better fuel milage, and increased throttle response. For reference, I've got the following to compliment it as well:
ATR catless up
Stromung catless down
Stromung 3rd cat eliminator (on the way)
Prodrive muffler
Samco IC hoses
Samco inlet hose (not installed yet)
Zerosports intake pipe (on the way)
3/16" FEBC solenoid connector with 1/16" bleed hole
4 point grounding mod
Mobil1 10w30
All these in combination make for a very peppy daily driver. Even with the AC on, it's still quick as all get out. The biggest help in the "AC on" department is the connector mod. You really need to be carefull of this one though (read the huge thread.) EGT's can rise quickly at part throttle, if not judicious with the right foot. I've got some insight on that on the last few pages of connector mod thread.
Do the velocity stack / panel filter. It's cheap, and it works.
Jim
MackDaddy is online now   Reply With Quote
Old 07-20-2002, 02:04 PM   #16
WizardBlackWRX
Member#: 14979
Air in any flow system will resonate. That is why the exhaust and headers must be a particular size. They will hurt performance in one area and help it in another according to rpms or exhaust pulses, etc. The same thing holds for intake airbox volume. Sportbikes have tuned with this for many years. Formula racing as well. Even though the turbo is sucking the air, it still has to fight the restrictions. That is what an air intake does, reduce the restriction. The resonator will let the intake volume match what the engineers wanted to create a beneficial resonation in the air to feed the turbo a little better at a certain speed, rpm, whatever. By removing it, you eliminate that effect, but with modified intake and exhaust, etc. you are changing where the improved effect is anyways. All of this is very slight, though.
WizardBlackWRX is offline   Reply With Quote
Old 07-23-2002, 10:45 AM   #17
saggioWRX
Member#: 18994
08 GTS
05 AW STi
Where do you buy the Velocity Stack???
saggioWRX is offline   Reply With Quote
Old 07-23-2002, 11:23 AM   #18
sherifx
Member#: 10780
---- I'm on campus
I'm not on Nasioc anymore
ditto
sherifx
sherifx is offline   Reply With Quote
Old 07-23-2002, 11:51 AM   #19
MackDaddy
Member#: 15451
2013 XV Crosstrek
Desert Khaki - CVT
www.summitracing.com
PN (I think, I'm at work) AVC-19002 $21.95
Jim
Edit: Just checked, that's the one! Direct link http://store.summitracing.com/defaul...rchType%3DBoth
Old 07-26-2002, 08:19 AM   #20
is2scooby
Member#: 19851
02 WRX
Aspen White/12.75@105.67
Awesome!
How is it secured (to the airbox, and to the fender?)
Any cutting?
is2scooby is offline   Reply With Quote
Old 07-26-2002, 10:35 AM   #21
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Be careful.
I am 99% positive the velocity stack shown in pics above is the WRXfx / Psi-Fi Motorsports one, and not the Summit Racing one.
I don't know of anyone who has purchased, installed, and reported on the Summit Racing part above. Perhaps MackDaddy can elaborate more, since the SR site has no pictures or details on the product whatsoever that I can find.
jblaine is offline   Reply With Quote
Old 07-26-2002, 12:09 PM   #22
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Err, ignore me. That apparently IS the Summit Racing one. Odd.
Old 07-26-2002, 12:40 PM   #23
Sparks
Member#: 16495
2013 BRZ
Sterling Silver Metallic
The seal in the bottom of the air box holds it in place and yes that is the Summit stack.
Sparks is offline   Reply With Quote
Old 07-26-2002, 01:27 PM   #24
MackDaddy
Member#: 15451
2013 XV Crosstrek
Desert Khaki - CVT
Talking That's my setup in the pics
And yes, it's the VS from summitracing.com
Jim
Old 07-27-2002, 07:43 AM   #25
jaxscuby
n00b Moderator
Member#: 10613
2002 USDM WRX
Have a Nice Day? a small piece of hose..
Originally posted by is2scooby
Awesome!
Any cutting?
after i got the velocity stack into airbox. I slide a piece of 3" diameter hose onto the end, it needed some coaxing, very tight fit, which is good, so it won't slip back from any vibration..
was thinking about a hose clamp, but the polished aluminum
was to pretty to put a hose clamp on it...
Is there a definitive answer on difference between 2.5 sti and non sti engine? BEEZSTI Newbies & FAQs 11 07-14-2006 02:57 PM
Definitive answer on GC8 fogs in WRX (or vice versa) Wolfen42 Electrical & Lighting 2 08-06-2004 01:45 PM
"subiegal" ? Anyone? Any definitive answers on STi mods voiding the warranty? SportyBry STi Forum Archive 4 08-09-2003 10:09 AM
Definitive answer on brake lines...plz?? subywan-kenobi Brakes, Steering & Suspension 6 08-06-2001 08:00 PM
Message Board Statistics All times are GMT -4. The time now is 09:25 AM.
