Old 04-28-2011, 07:04 AM   #1
GEE-OTTO
Member#: 201277
2009 Legacy GT
Default Studded Flanges Anyone????
Anyone know where I could source Three hole STUDDED flange ?????????
OR would it be possible to buy a three hole flange and tap it for studs?
I need it for a collector and all I can find are the slotted flanges but they have the potential to shift so I want one studded flange to mate to a non-studded flange to eliminate that issue.
I would go V-band but I already have the mid pipe welded up with a three bolt
GEE-OTTO is offline   Reply With Quote
Old 04-28-2011, 07:06 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
It might be tough to find a flange with holes small enough to be tapped for the bolts. I think I'd bolt the flanges together and weld the heads to make studs. Quick and easy!
Jay
Old 04-28-2011, 08:28 AM   #3
GEE-OTTO
Member#: 201277
2009 Legacy GT
Jay
That is a good idea, if a bolt seizes i will deal with it then (grind down tack welds remove /replace)
Old 04-28-2011, 08:49 AM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
Exactly. Still servicable when you weld it enough to keep it in place only.
Jay
Old 04-28-2011, 09:13 AM   #5
GEE-OTTO
Member#: 201277
2009 Legacy GT
Thanks for the idea I have some spare M8 x 1.25 bolts from a X-pipe laying around that I will use. Lickity Split!
Old 06-20-2011, 01:49 PM   #6
kay95
Member#: 45494
95 impreza L awd
green
You could use a helicoil also. You would have to find out what sizes your working with and might have to ream your mating flange holes alittle bit. Just throwing another option out there.
kay95 is offline   Reply With Quote
Broken wheel stud =( Anyone know how to fix? DaZam Texas Impreza Club Forum -- TXIC 14 10-19-2008 02:15 PM
Anyone in CO have a set of ice/studded 2manycarz Rocky Mountains Impreza Club Forum -- RMIC 0 11-04-2003 10:45 AM
anyone know where to get affordable ej22 head studs STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-24-2002 02:37 AM
anyone know the knurl diameter for our wheel studs? girl Brakes, Steering & Suspension 2 07-13-2002 04:23 AM
Anyone know if studded tires are legal in PA? Tony Mid Atlantic Impreza Club -- MAIC 1 11-20-2000 04:33 PM
