Old 04-28-2011, 09:01 AM   #1
lifwanian
Member#: 232497
02 WRX
Default H&R Coilovers installed - Bouncy as shizzzz!!!!
So I just installed a barely used set of H&R Coilovers on my 02 WRX Sedan. They came with 700f/500r springs which are on the stiff side, however Im getting way too much bounce from them, even for their rates. Its gotten out of hand to where sometimes its hard to even concentrate on the road, even when there are no bumps!
Im set at around 14" front and 13.5" rear as far as ride height, and will also be getting an alignment tomorrow.
As for other suspension/drivetrain mods:
- 18x8 tarmac 3's with 235 hankook evo v12
- 25mm hotchskis sway - front
- adjustable, set at 23mm hotchskis sway - rear
- front and rear kartboy endlinks
- eibach rear camber bolts
- front strut bar
Anyways, had them on for about a day, and I've almost had it with them. Hopefully the alignment will help, but you guys have any ideas why they are so bouncy?
Thanks!
lifwanian is offline   Reply With Quote
Old 04-28-2011, 09:39 AM   #2
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
Those spring rates are almost double the rates of what came on them. Unless they were revalved (sounds like they weren't), they are severely underdamped for the spring rates. In other words, the damper is not able to control the spring oscillations so it's bouncing all over the place. Going back to a reasonable spring rate should make a huge difference. Something along the lines of 400 or 450f and 350r.
boost junkie is offline   Reply With Quote
Old 04-28-2011, 09:44 AM   #3
lifwanian
Member#: 232497
02 WRX
Well they come with 500f/300r stock I believe, so in other terms, the ones I have now are 12/10k...
I know that's quite high, and I'll probably be putting the rear springs onto the fronts and picking up some 300lb springs for the rear, but in the mean time, shouldnt there still not be much bouncing? Just more of a stiff ride?
Thanks for the help!
Old 04-28-2011, 10:58 AM   #4
AspenScoob255
Member#: 217405
2006 WRX
Standard h&r coils 457/f - 286/r (per perrin)
RSS Coils 680/f - 515/r roughly ( per perrin also)
So if you have the standards I would say those rates are seriously overworking your dampers. Essentially your dampers cannot keep up with the springs causing them to "chase" the springs ie. Bouncing.
AspenScoob255 is offline   Reply With Quote
Old 04-28-2011, 11:02 AM   #5
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
If they're valved correctly, then there shouldn't be much bouncing (just harshness).
AndyRoo is offline   Reply With Quote
Old 04-28-2011, 01:46 PM   #6
vader wagon
Member#: 43440
03 WRX Wagon
I think H&R's stock rate is roughly 8K/7K and the standard coilover diameter (2.5"?), so finding replacement springs shouldn't be too tough.
vader wagon is offline   Reply With Quote
Old 04-28-2011, 02:32 PM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
H&R springs are 60mm.
I have a set of springs that came with the kit (no tender's) if you want them cheap....
Jay
Old 04-28-2011, 02:56 PM   #8
lifwanian
Member#: 232497
02 WRX
PM'd!
Old 04-28-2011, 05:49 PM   #9
Storm
Member#: 5218
96L Most Over-
Developed Beater
Will snap some pics..... Though, with my car weighing a mere 20xxlbs these days, I may very well be right back down to those rates anyway. I haven't run the new setup yet.
Jay
Old 04-28-2011, 08:03 PM   #10
lifwanian
Member#: 232497
02 WRX
Sweet, thanks guys. Looks like I'll be dropping the rates down. Here are my two options of going (if anyone here have some springs they're looking to sell):
Swap rear to front, and get new rear springs
- Just need new rear springs - Part# 160-60-060 (342lbs)
Get new front and rear springs
- Front springs - Part# 160-60-080 (457lbs)
- Rear springs - Part# 160-60-050 (285lbs)
Got quoted $125 a part by a few distributors. Will pick them up this weekend or early next week if nobody has any.
Old 04-28-2011, 09:50 PM   #11
vader wagon
Member#: 43440
03 WRX Wagon
$125 for a pair? Or for each spring? Basically, $125 x2 or x4?
Old 04-28-2011, 09:59 PM   #12
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
If it's 125 per spring run like hell - you can get way, way cheaper springs than that.
sniper1rfa is offline   Reply With Quote
Old 04-28-2011, 10:00 PM   #13
lifwanian
Member#: 232497
02 WRX
H&R quoted $75 per corner, and the distributors quoted $125 for 2 springs (2corners).
Forgot what they quoted for the set of 4, but it was less than $250
Old 08-14-2012, 11:36 AM   #14
silverbullet7
Member#: 297348
2004 WRX
Plasti-Blue
Hey i just recently installed H&R Street Performance springs with OEM top mounts and getting this same bounce effect it seems. I am on a flat highway going 70 and bouncing for what seems to be no reason? These are brand new out of the box.
Is there some other issue that could be why they are having the bouncing issue???
silverbullet7 is offline   Reply With Quote
Old 08-14-2012, 11:46 AM   #15
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
^ Bouncing is all about the dampers. If the dampers do not match the springs within a spring rate window, your ride is either gonna be over damped (think no suspension) or under damped (bouncy). I'm assuming you still have stock WRX dampers, so your springs are most definitely under damped.
chazly413 is offline   Reply With Quote
Old 08-14-2012, 11:58 AM   #16
silverbullet7
Member#: 297348
2004 WRX
Plasti-Blue
Sorry I said springs, when I meant CoilOvers Aren't the dampers part of the coil over set up? I am sorry I have no experience in this.. So where are these dampers? and how do I replace?
Old 08-14-2012, 01:26 PM   #17
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
Yes the damper, or strut, is indeed part of the coilover. Other sources of bounciness could be the OEM top mount which is less than ideal given its softness and age on your car, and the tires depending on sidewall stifness and inflation pressures. Another possibility is that you just aren't used to higher rate springs and all that entails on a street car.
A-man07 is offline   Reply With Quote
Old 08-14-2012, 03:08 PM   #18
silverbullet7
Member#: 297348
2004 WRX
Plasti-Blue
thanks for these answers.. well I was thinking about top mounts being an issue. I would see how it being soft would allow for more flexing.. I dont' know if it would cause THIS much of an issue. It sort of like dips every 3-5 seconds on a highway going 70 for no apparent reason that I could see. It could make me sea sick after awhile lol. I wouldn't want to be on highway for very long if this is how its going to be. I know my tires and rims are ok. My car has only 56k miles on it .. I dont' mind the stiffness. I dont' mind hitting bumps harder, its this sort like up and down dipping thing, its hard to explain.
I talked to H&R and they have a recommended height range it should be, outside of this range I could experience an issue.
Sway bars dont' have an impact on this do they?
Old 08-14-2012, 04:12 PM   #19
silverbullet7
Member#: 297348
2004 WRX
Plasti-Blue
i am going to check my height in the rear tonight. maybe I'm just sitting too low? Its not slammed to the bottom but probably outside this recommendation which is a pretty small window.
I hope this is it!
Old 08-14-2012, 04:47 PM   #20
sjs0433
Member#: 86061
Best place for cheap springs is usually Ground Control. They stock tons and tons of Eibach springs at a good price. They are probably better than the H&R springs and will certainly cost less.
sjs0433 is offline   Reply With Quote
Old 08-14-2012, 05:24 PM   #21
sc00by4life
Member#: 97135
Fun fact eibach makes the h&r springs (and many others on the market...there are only a handful of companies that actually wind springs).
But like mentioned, it's mostly the dampers.
Old 08-14-2012, 05:27 PM   #22
A-man07
Member#: 271525
07 STi
[quote=silverbullet7;37819577]thanks for these answers.. well I was thinking about top mounts being an issue. I would see how it being soft would allow for more flexing.. I dont' know if it would cause THIS much of an issue. It sort of like dips every 3-5 seconds on a highway going 70 for no apparent reason that I could see. It could make me sea sick after awhile lol. I wouldn't want to be on highway for very long if this is how its going to be. I know my tires and rims are ok. My car has only 56k miles on it .. I dont' mind the stiffness. I dont' mind hitting bumps harder, its this sort like up and down dipping thing, its hard to explain.
Sway bars dont' have an impact on this do they?[/quote]
Yes, that's good advice from H&R about the height range. Definitely check it. No the sway bars aren't causing this issue.
I hope this is it!
Definitely possible.
Old 08-15-2012, 11:03 AM   #23
silverbullet7
Member#: 297348
2004 WRX
Plasti-Blue
I didn't know how to delete my repeated message so I wrote this here instead.
Last edited by silverbullet7; 08-15-2012 at 05:08 PM. Reason: Tried to delete this, repeated below.
Old 08-15-2012, 11:05 AM   #24
silverbullet7
Member#: 297348
2004 WRX
Plasti-Blue
So the report is.. I was probably 20-25mm lower than spec..only had time to adjust the rear and it has improved..seems like all bounciness is in front besides that the car is now doing a nosedive . Will be doing the front maybe later! So this seems to be the issue ! I will know for sure after front is adjusted. What a shame that theres like 200 mm of thread and you can use 20 mm of it LOL
Thanks everyone for all the advice . I will report back after fronts are done!
Old 08-15-2012, 10:18 PM   #25
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
if you are using the stock front strut tops
THROW THEM AWAY AND GET AT LEAST GROUP N FRONT TOPS
the stock front strut tops are A HUGE source of **** in the suspension and must be disposed of as quickly as possible
H&R Coilover Install and Review LTBlackBird Brakes, Steering & Suspension 31 09-11-2012 05:11 AM
H&R Coilover Install instructions? tasq Brakes, Steering & Suspension 0 05-31-2005 01:17 PM
H&R Coilovers installed LehighWRX Brakes, Steering & Suspension 12 12-02-2002 05:46 PM
Just installed H&R coilovers and Stoptech brakes Mark V Brakes, Steering & Suspension 44 05-01-2002 02:39 PM
Any WRX owner install H&R coilovers yet? 2QUICK4U Brakes, Steering & Suspension 1 04-02-2002 03:35 PM
