Old 07-19-2002, 05:28 PM   #1
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Default High resolution or wide voltage range O2 sensor?
I dont see much mention of this but I have had this mod in my head on my list of todo items. Now its getting close to the time that I actually start installing some of this stuff. Heres my question
Ive been thinking about getting a 5 volt oxygen sensor, subaru oem or aftermarket, and having an exhaust shop add a mounting location for it. I would then power it and buy a meter for it so I could tune the car and monitor the ratio without effecting the ECU or using the somewhat limited low voltage model that is stock on most older subaru.
What would be the best option cost wise for the sensor itself?
Who makes a 5 volt A/F meter? Im not into looks. Smaller the better. Actually if someone could post specs Id rather just use a volt meter!
Thanks
Old 07-19-2002, 06:18 PM   #2
Bob O
Member#: 1502
2000 2.5RS & SV1kS
BRP
This has been kicked around before, but I think the wide band sensors are not simply wider band, at least in terms of 0-5V being larger than 0-1V. At least from the Subaru manual the signal curve from the wideband sensor on the 00's, is all about current vs a/f. I'm not sure on the specifics but almost all wideband meters are super expensive, like 1k (the one from Blitz comes to mind). I can't figure out for the life of me what voodoo they are doing in those boxes to come up with costs like that. Now if you could get a signal to a/f response graph with numbers on it (the Sube manual graph has no #'s) you could easily track the important signal info and correlate it to a/f. IIRC no one has done this cheaply yet.
Bob
Bob O is offline   Reply With Quote
Old 07-19-2002, 09:52 PM   #3
JulianH
Member#: 2035
There are two DIY WB-O2 projects that I know of. Both will cost <$200 total, including the sensor. Check out http://www.diy-efi.org/diy_efi/projects/diy_wb/ and http://www.techedge.com.au/vehicle/wbo2/default.htm. The second one also has a provision for connecing a LCD to show the current A/F ratio. These are just as good as the Blitz or any other meter(same sensor, in fact).
JulianH
JulianH is offline   Reply With Quote
o2 sensor voltage to high and to low? what gives Drexer13 Newbies & FAQs 7 09-26-2008 08:54 AM
Voltage range of the O2 sensor? Tea cups Service & Maintenance 3 07-25-2006 01:19 PM
P.O.S. front o2, voltage range? ejsportcom Engine Management & Tuning 19 11-26-2005 11:11 PM
Link Plus o2 voltage range? Midwayman Engine Management & Tuning 1 04-17-2003 10:40 AM
('93-'01) Wide band O2 sensor voltage range jeffg Impreza Forum 5 06-05-2001 02:26 PM
