Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 04-28-2011, 02:06 PM   #1
Motion Lab Tuning
Vendor Sales Rating: (7)
Member#: 228856
Default Motion Lab Pro Built Short-block and much more!! Great deals on Invidia!!
Pro Built Short-Blocks
Simply put - we’ve been at this for a very long time! After investing a lot of our time and resources, we have identified several problem prone areas within the factory motor design that limit your fun-factor. You can rest assured, that our horsepower specification that we’ve associated with our in-house built motors still leaves some head room.
We choose our rod and main bearing clearances based on the ultimate RPM range that your new motor will see. We also give you the choice to choose your engine compression ratios. You have two choices of 8.5:1 or 9.8:1 and whichever you choose, please keep in mind of the type of fuel that the motor will see most often. This is an important part when ordering your motor. Typically, we’ll suggest the higher compression to run on race gas or E85. Since Motion Lab is a wholesale distributor for Manley Performance and has established relationships with other major engine parts manufacturers, we are able to provide the most proven and reliable combination of Subaru engines on the market.
Additional build information: Motion Lab typically implements the use of a torque plate for our performance line of motor builds (not used for standard rebuilds). Our build tolerances are redundantly checked throughout the build process, which includes;
  • individual (ring to bore) ring end gaps augmented
  • individual piston-bore clearances checked
  • wrist pin bore checked
  • main, rod, and thrust bearing clearances checked
  • strict rod bearing eccentricity measurements
  • big-end rod bore roundness checked
  • small-end rod bore checked
  • crank straightness checked
  • block decks checked
Subaru EJ255/257 (04-Present)
ML 2.3L Blocks
ML675DS 2.3L
Similar to the ML 2.5L line-up, the ML “DS” blocks receives a shorter stroke for higher revving! We add our exclusive high RPM crankshaft and connecting rod modification to the build and treat the crank with a hardening process. The upgraded ARP Age-625+ rod bolts allow for worry-free high RPM revving.
Recommended Power: 550-700WHP, RPM: 8800
H-Beam Manley Rods
- Custom ARP AGE-625+ Upgraded Rod Bolts
- ML-Spec Rod and Main Bearings
2618 Forged Manley Pistons
- 99.5mm
- Choose 8.5:1 (or) 9.8:1 Compression Ratio
- 9310 Alloy Wrist Pin Upgrade
- Anti-friction skirt coating
- Off-set wrist pin
New Factory Block
New 75mm Factory Crank
-Hardening Treatment
$5663
ML825DS 2.3L
The ML825DS is a beast! It is built around the strongest rotating parts available on the market! It goes to next level above and beyond the ML675DS by adding Manley’s I-Beam rods to handle 9000 RPMs and higher cylinder pressures. We also perform our exclusive crankshaft and rods modification.
Recommended Power: 650-825WHP, RPM:9000
I-Beam Manley Rods
- 99.5mm
-Choose 8.5:1 (or) 9.8:1 Compression Ratio
- Off-set wrist pin
New Factory Block
$6713
ML1300 2.3L
The ML1300 is BOMB PROOF - all the above with the addition of AEBS sleeves, a Manley 4340 billet crank, and 9310 alloy wrist pins. We originally built this this block for racers and hardcore enthusiasts. It’s the best Subaru block on the market - the best that your hard-earned money can buy!
Recommended Power: 1300WHP, RPM: 9500
I-Beam Manley Rods
- 99.5mm
- Off-set wrist pin
75mm Manley Performance Crank
- 4340 Chromoly Billet
- Heat treated
- Stress relieved and shot-peened
- Dual-main oiling for high RPM
- Gun drilled counter weights
- Nitrided
- Magnafluxed
ML-Spec Wet sleeved Factory Block (absolutely the strongest block available)
- LA Sleeve ProCross ProCool Wet sleeve
- Closed deck design
- Superior cooling over dry sleeved blocks
$9428
ML 2.5L Blocks
ML500 2.5L
This is our entry-level block but certainly up for the task of holding big power. Light years better than a standard Subaru short-block but lacks some of the finer details of the ML500+ line. This is a great choice for those looking to have a stout daily driver but with the ability to turn the wick up when needed.
Recommended Power: 400-500WHP, RPM: 7200
New Factory Block
New Factory Nitrided Crank
New Factory Bearings
New Factory I-Beam Rods
Forged Pistons
- 99.5mm Manley Performance 2618 Forged piston set
- Chromoly Wrist Pins
- Off-set wrist pin
$3138
ML500+ 2.5L
The ML500+ block adds refinement in terms of balance and strength over the standard ML500. The H-Beam rods are light and strong and the 2618 pistons are race proven.
Recommended Power: 475-575WHP, RPM: 7200
Manley Performance 4340 Forged H-Beam Rods
- ARP2000 Rod Bolts
Manley Performance 2618 Forged Pistons
- Off-set wrist pin
New Factory Block
$4703
ML600 2.5L
Like the ML500+, the ML600 adds our exclusive high RPM crankshaft and connecting rod modification to the build. The upgraded ARP625+ rod bolts also allow for worry-free high RPM revving.
Recommended Power: 575-650WHP, RPM: 8200
Manley Performance 4340 H-Beam Rods
Manley Performance 2618 Forged Piston set
- Off-set wrist pin
New Factory Block
- ML-Spec High RPM Crank and Connecting Rod modification
$5248
ML700 2.5L
The ML700 steps it up to Manley’s top of the line I-Beam “Turbo-Tuff” rods for a higher horsepower capacity.
Recommended Power: 650-750WHP, RPM: 7800
Manley Performance 4340 I-Beam Rods
- ARP2000 Rod Bolts
- Off-set wrist pin
New Factory Block
$5732
ML800 2.5L
We build the ML800 around the strongest rotating parts available on the market! It goes to next level above and beyond the ML700 by adding ARP’s best connecting rod bolts available to handle 8200 RPMs. We also perform our exclusive crankshaft and rods modification.
Recommended Power: 700-825WHP, RPM: 8200
- Off-set wrist pin
New Factory Block
$5978
ML1200 2.5L
The ML1200 is BOMB PROOF - all the above with the addition of AEBS sleeves, a Manley 4340 billet crank, and 9310 alloy wrist pins. We originally built this this block for racers and hardcore enthusiasts. It’s the best Subaru block on the market - the best that your hard-earned money can buy!
Recommended Power: 1200WHP, RPM: 8500
- Off-set wrist pin
Manley Performance 79mm Billet Crank
- Heat treated
- Nitrided
- Magnafluxed
- LA Sleeve co. ProCross ProCool wet sleeve
$9113
We are able to offer competitive shipping solutions to our customers in the lower 48 states. Shipping outside the continental U.S. as well as international destinations, please inquire for shipping details.
Motion Lab is a stocking distributor for Manley Performance. This allows us to offer quicker turn around times on our built motors. We also carry a full line of supporting engine building components. Gasket kits, timing belts, and a slew of other supporting A few of our current options available for all Motion Lab Pro Built Short-Blocks are as follows:
- Cosworth Oil pumps $Call or PM
- ARP2000 Case bolt kit $394
- ARP2000 Head stud kit $195
- Custom ARP AGE-625+ Head stud kit $497
- Head Gaskets: $Call or PM
  • Subaru OEM
  • Cosworth
  • Cometic (custom available)
__________________
Charlotte, NC Phone: 704-527-0100
Email:
Facebook:
Instagram:
Motion Lab Tuning is online now
Old 04-28-2011, 02:06 PM   #2
Motion Lab Tuning
Member#: 228856
We here at Motion Lab Tuning have all the top brands to make your Subaru go! We have a almost endless parts selection including our own line of Uppipes and Crosspipes! Even if you don't see it listed give me a PM and i'll see if I can get it for you. Call, PM, or contact me via aim or email to order.
Turbos and Housings:
  • Garrett
  • Master Power
  • Forced Performance
  • Blouch
  • Greddy
  • Turbonetics
  • HKS
  • ATP
  • OEM Subaru
BOV and BOV Components:
  • Turbosmart
  • TurboXS
  • HKS
  • Forge
  • Tial
  • Cobb Tuning
  • Blitz
  • Prova
  • Perrin
  • Greddy
  • Turbonetics
  • OEM Subaru
EWG and EWG Components(flanges, seats, and fittings):
  • Tial
  • Turbosmart
  • Synapse
  • Turbonetics
  • Greddy
  • HKS
Boost Controllers:
  • Hallman
  • Turbosmart
  • TurboXS
  • Perrin
  • Turbosmart
  • Apexi
  • HKS
  • Greddy
  • AEM
3-port Boost Control Solenoids:
  • GReddy
  • Motion Lab Tuning
Downpipes:
  • Cobb
  • HKS
  • TurboXS
  • AMR
  • Perrin
  • Invidia
Catbacks:
  • RAYS/ARC Titanium
  • Apex'i
  • Borla
  • Greddy
  • HKS
  • Magnaflow
  • AMR
  • Perrin
  • Invidia
  • TurboXS
__________________
Email:
Facebook:
Instagram:
Old 04-28-2011, 02:07 PM   #3
Motion Lab Tuning
Member#: 228856
Performance Cam Shafts:
  • Brian Crower
  • GSC Power Division
  • Kelford
Up-pipes:
  • Motion Lab Tuning
  • Cobb
  • GReddy
  • HKS
  • AMR
  • Invidia
  • Perrin
Fuel Pumps:
  • Aeromotive
  • Deatchwerks
  • Walbro
We all know the heat is going to start rising which takes a big toll on our cars. Prevent engine failures with purchasing a Koyorad or Mishimoto radiator and check out the other cooling accessories we have to offer! Everything from thermostats to intercoolers!
Radiators:
  • Koyorad
  • Mishimoto
  • OEM Subaru
  • Greddy
  • ARC
Thermostats:
  • Grimmspeed
  • ARC
  • Subaru OEM
  • Mishimoto
Radiator Caps:
  • Greddy
  • Blitz
  • HKS
  • ARC
  • Cusco
  • Subaru OEM
  • Sti
  • Gates
  • Skunk2
Radiator Hoses:
  • Mishimoto
  • Samco
  • Gates
  • Subaru OEM
Radiator Shroud:
  • Mishimoto
  • TurboXS
  • ARC
  • Perrin
Front mount Intercoolers:
  • TurboXS
  • AMS
  • Greddy
  • Blitz
  • Perrin
  • HKS
  • Injen
  • ARC
  • Turbonetics
Top mount Intercoolers:
  • TurboXS
  • Process West
  • Sti
  • Perrin
  • AMR
  • AMS
PM me for my best price on these great product lines!
Alex
__________________
Email:
Facebook:
Instagram:
Old 04-28-2011, 05:47 PM   #4
Motion Lab Tuning
Member#: 228856
Lowest pricing available and we will match competitors price if we get beat! Let me know what you need!
Alex
__________________
Email:
Facebook:
Instagram:
Old 04-29-2011, 10:29 AM   #5
Motion Lab Tuning
Member#: 228856
We can build anything from a 2.0L to a 2.7L. From modest horsepower goals all the way up to our ML1200 we have the right motor for your car.
Alex
__________________
Email:
Facebook:
Instagram:
Old 04-29-2011, 01:47 PM   #6
Motion Lab Tuning
Member#: 228856
Mid-day bump. Here til 6EST to assist you!
Alex
__________________
Email:
Facebook:
Instagram:
Old 04-30-2011, 11:54 AM   #7
Motion Lab Tuning
Member#: 228856
We have the right motor for any application. 2.0L-2.7L let us know what you are looking for and we will build the right motor choice for you!
Alex
__________________
Email:
Facebook:
Instagram:
Old 05-02-2011, 11:29 AM   #8
Motion Lab Tuning
Member#: 228856
Let me know what you need! Motor builds from mild to wild, garrett turbos, invidia, turboXS, cobb, perrin, Kelford, GSC, and more! Let me know what you need!
Alex
__________________
Email:
Facebook:
Instagram:
Old 05-02-2011, 02:57 PM   #9
Motion Lab Tuning
Member#: 228856
About to start a fresh ML600 build for a 2006 STi! Everything looks so nice when its new.
Alex
__________________
Email:
Facebook:
Instagram:
Old 05-05-2011, 11:57 AM   #10
Motion Lab Tuning
Member#: 228856
Added our 2.3L motor build options! Stout daily driver to high revving monster we have the right motor for you!
Alex
__________________
Email:
Facebook:
Instagram:
Old 05-05-2011, 01:58 PM   #11
Motion Lab Tuning
Member#: 228856
Mid-day bump to the top! We are here until 6EST to assist you.
Alex
__________________
Email:
Facebook:
Instagram:
Old 05-06-2011, 11:48 AM   #12
Motion Lab Tuning
Member#: 228856
Alex
__________________
Email:
Facebook:
Instagram:
Old 05-06-2011, 02:56 PM   #13
Motion Lab Tuning
Member#: 228856
Alex
__________________
Email:
Facebook:
Instagram:
Old 05-07-2011, 11:38 AM   #14
Motion Lab Tuning
Member#: 228856
Alex
__________________
Email:
Facebook:
Instagram:
Old 05-09-2011, 11:35 AM   #15
Motion Lab Tuning
Member#: 228856
Alex
__________________
Email:
Facebook:
Instagram:
Old 05-09-2011, 03:47 PM   #16
Motion Lab Tuning
Member#: 228856
Alex
__________________
Email:
Facebook:
Instagram:
Old 05-09-2011, 03:48 PM   #17
Motion Lab Tuning
Member#: 228856
Alex
__________________
Email:
Facebook:
Instagram:
Old 05-10-2011, 10:07 AM   #18
Motion Lab Tuning
Member#: 228856
Alex
__________________
Email:
Facebook:
Instagram:
Old 05-11-2011, 01:19 PM   #19
Motion Lab Tuning
Member#: 228856
Alex
__________________
Email:
Facebook:
Instagram:
Old 05-12-2011, 10:37 AM   #20
Motion Lab Tuning
Member#: 228856
Alex
__________________
Email:
Facebook:
Instagram:
Old 05-16-2011, 10:08 AM   #21
Motion Lab Tuning
Member#: 228856
Alex
__________________
Email:
Facebook:
Instagram:
Old 05-16-2011, 10:09 AM   #22
Motion Lab Tuning
Member#: 228856
Alex
__________________
Email:
Facebook:
Instagram:
Old 05-17-2011, 11:23 AM   #23
Motion Lab Tuning
Member#: 228856
Alex
__________________
Email:
Facebook:
Instagram:
Old 05-17-2011, 04:21 PM   #24
Motion Lab Tuning
Member#: 228856
Mid-day bump to the top! Here until 6EST to assist you.
Alex
__________________
Email:
Facebook:
Instagram:
Old 05-18-2011, 11:10 AM   #25
Motion Lab Tuning
Member#: 228856
Alex
__________________
Email:
Facebook:
Instagram:
Closed Thread
Race Built Short Blocks - $2099 + - MANLEY, CP, Wiseco, Brian Crower & More S&R Performance Engine/Power/Exhaust 171 06-01-2012 11:22 AM
STi Wrx Motor Swap Kits, Built Short blocks and more!! Millennium Auto Engine/Power/Exhaust 27 04-19-2011 10:31 PM
Sargent Power Built Short Blocks, Borg Warner Turbo deals and more! ZenMotors Engine/Power/Exhaust 8 04-13-2010 05:43 PM
Wtb:new Ej257 Built Short Block Or Blown Short Block Misery9 Private 'Wanted' Classifieds 0 08-05-2009 05:29 PM
02 WRX Short block LOW PRICE 45K on it, and more.. monstergremlin16 Private 'For Sale' Classifieds 10 02-26-2006 09:22 PM
