Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 07-19-2002, 06:16 PM   #1
Timmay
Member#: 5844
02 WRX
Blaze Yellow
Default Newly Painted Calipers
Painting the calipers took a lot more time than I wanted to spend. Honk next time you see me!
http://66.28.54.67:2345/wrx/calipers/
Tim
Timmay is offline   Reply With Quote
Old 07-19-2002, 07:06 PM   #2
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
How long did it take you?
MAD REX is offline   Reply With Quote
Old 07-19-2002, 07:09 PM   #3
jg8a
Member#: 19665
2002 Subaru WRX
World Rally Blue
im pretty much a noob and wanted to know how you did that? what kind of paint did you use and did you have to complete remove the caliper to get them painted? thanks, and sorry for my noob suckness.
jg8a is offline   Reply With Quote
Old 07-19-2002, 08:14 PM   #4
Timmay
Member#: 5844
02 WRX
Blaze Yellow
It took around 4 hours to do the work including jacking the car up, removing the wheels, partially removing the calipers (I left the brake lines plugged in) , painting 2 coats, and putting everything back together again. I had my dear wife following me around putting on a second coat of paint after I put on the first. It would've taken much longer if I did it alone. Its probably worth noting that I was being pretty anal about getting it right and taking my time. It took 24 hours to dry.
I used an axle jack and four jack stands to get the car off the ground. To remove the wheels I used a torque wrench. To remove the calipers I used regular old tools. Once you get going its pretty intuitive.
I used a brake caliper specific paint kit from Folitec. There's a place in Broomfield off 287 just north of 36 called Autosport Works that sells the kit for $55. The paint is actually an epoxy you have to mix. Its pretty thick so I doubt it will chip. The kit comes with brake cleaner and pretty detailed instructions. It was worth the money.
Tim
Old 07-20-2002, 04:27 AM   #5
mofoporn
Member#: 4766
2001 2.5 RS
BRP
Larry sells paint as well....thats were I got mine from.....$44 aint bad.
http://www.imprezars.com/product2.htm#g2caliperpaint
Kurt
mofoporn is offline   Reply With Quote
Old 07-24-2002, 12:38 PM   #6
Merdock777
Member#: 21256
2002 Impreza 2.5RS
BlindYoAssPlatinumSilver
You can do it for cheaper by just using high temp engine enamal. just go to pep boyz and pick out any color you want from the 1200 deg paints and it will set you back like five dollars. mad the mistake my first time of not takeing the calipers off. had to fix it later on. but just jack up the car take the calipers off ( I took them all the way off so they could get a through cleaning and then I put in new brake fluid and pads at the same time) hose them off with brake cleaner (Becareful if you don't remove all rubber and plastic, the brake cleaner will make those parts very brittle) allow to dry and they paint. You'll need at least two coats depending on how dark and how resistant you want them to be. All in all it shouldn't take that long to do, with drying it took me about 8 hours to do all that. not very hard and it just makes the car look so nice from the side or in motion
Merdock777 is offline   Reply With Quote
Just painted caliper using caliper paint kit txl146 Interior & Exterior Modification 2 08-02-2006 09:28 PM
faded aspen white paint + newly painted parts... what to do?? Orbiter Car Care & Detailing 14 05-20-2004 12:25 PM
Check out my newly painted 93 IMpreza Kranium31 Member's Car Gallery 3 09-30-2002 01:18 AM
Which bunny........for the newly painted grill Legacy777 Legacy Forum 15 06-11-2002 08:32 AM
Protecting a newly painted part brunetmj Interior & Exterior Modification 3 03-05-2002 11:18 AM
