![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 21216
Vehicle:1998 Impreza RS Black |
Hi,
I'm replacing my pads, turning the rotors, and flushing the fluid this weekend, but I don't have a service manual (it's on its way). Can anyone tell me what the minimum rotor thickness is for a MY98 Impreza RS? I called a few dealerships, and they say 22 mm, but there's no way my rear rotors are 22 mm--they're not vented. Also, how much brake fluid is required for a complete flush? I've got a liter of Super Blue, but now I'm wondering if I should have bought 2. Thanks, Phil
#2 |
Member#: 5596
TXIC
Vehicle:2010 Honda Fit Sport Black |
The stock WRX rear discs say 8.5mm. Not sure if it's the same for the RS. My guess is that it is.
I replaced my fluids with Super Blue too, and took me just under a liter. If you're careful, and don't need to bleed brakes excessively afterwards, you should be fine with one. -Ray |
#3 |
Gone... But not forgotten
Member#: 92
Vehicle:1999 2.5RS Coupe Blueish Kind of |
I believe the rotors will have the minimum tolerance stamped right on them. Look inside the hub. I know my fronts were like that. The fronts were 22mm. Not the rears. The rears aren't even 22mm to start with!
Fred |
| Thread Tools | |
| Display Modes | |
| brake fluid capacity? | jooboy | Service & Maintenance | 1 | 06-23-2009 03:59 AM |
| Brake fluid capacity | matty2.5 | Brakes, Steering & Suspension | 4 | 10-17-2005 10:47 PM |
| Brake Fluid Capacity | Gunner | Service & Maintenance | 2 | 12-27-2004 05:49 PM |
| sti brake fluid capacity | lukerussell | Factory 2.5L Turbo Powertrain | 2 | 02-10-2004 10:33 PM |
| Minimum rotor thickness - 98 GT | Snowphun | Legacy Forum | 3 | 07-17-2003 12:46 PM |
