Old 07-19-2002, 06:52 PM   #1
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Default Stock mid pipe exhaust tubing on 2.5l legacy?
Im curious what size tubing is used on the stock 2.5l legacy from the cat to the can.
My intention is that if its the right size I can use it in combination with som other parts I have to create an exhaust. It would be very convinient to grab a used section of pipe and use it for cutting and such.
Old 07-19-2002, 08:57 PM   #2
BG5
Member#: 695
something like ~1.7 or 1.8" ID, just a smidge under 2" OD if I remember correctly, the pipes are all the same length from 90-99, the entry flange is slightly smaller on 95-99 though. I can go take a look if you need a precise measurement.
BG5 is offline   Reply With Quote
Old 07-20-2002, 04:20 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
luckily I still have the gasket from the 2001 rs exhaust I was borrowing so I can measure that. I do know that the headers were the same size pipe diameter.
Not doing to much custom exhaust work myself yet, would any random muffler shop have the right flanges to connect to the subaru exhaust parts?
OH btw, it looks that the best headers available right now are those from http://www.techworkseng.com/
Read the page for more info.
WTB: 00-05 2.5L Legacy Exhaust manifold and front sway bar David Hawkins Private 'Wanted' Classifieds 1 05-06-2008 10:36 PM
Cobb Stage 2.5 w/ stock mid pipe cat PJAWRX03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 02-02-2005 05:58 PM
What other Perfomance Muffler can bolt right on the Stock Mid pipe! SONofSAM Normally Aspirated Powertrain 1 04-15-2002 05:10 PM
Cat-Back Exhaust for 2.5L. Legacy traskw Normally Aspirated Powertrain 6 01-24-2002 11:15 PM
Will the stock MY00 mid-pipe bolt right on to the STi muffler??? tabolau Normally Aspirated Powertrain 4 12-15-2001 04:26 AM
