04-28-2011, 11:50 PM | #1 |
Member#: 253560
South East
Vehicle:'83 Subaru GL Wagon |
Code P0607?
So I was driving my girlfriend home tonight in my car, running a Rallitek 93 Octane TM2 Injen map on my Accessport. I made a turn in 2nd gear, accelerated and i got to ~3000 RPMs and the check engine light came on and cruise control started flashing. Once this happened I couldnt rev it above ~1500 and the car wouldnt go any faster then 5mph even with my foot to the floor.
Pulled out my Accessport and got the code P0607. Cleared it and it was okay for the rest of the night. I googled it and searched several websites but I can find a straight answer. It seems as though no one really knows what causes it? If anyone has some insight thatd be great, hopefully it doesnt pop up again.
04-29-2011, 12:22 AM | #2 |
Member#: 236927
NESIC
Vehicle:2015 BRZ 86 GL Hatch 1984 BRAT |
From what I have read, it has to do something with a bad ECU. The ECU programming has failed.
I'd check your grounds first to see if anything is shorting out or if there is a loose ground. But from what I've read, the fix usually means replacing the ECU with one that isn't defective. |
04-29-2011, 12:48 AM | #3 |
Member#: 157764
TXIC
Vehicle:2002 '02 SZ55 hyb 2002 v9 EJ207 VF22 wagon |
04-29-2011, 03:12 PM | #4 |
Member#: 253560
South East
^Perfect, Thank you!
07-19-2011, 08:37 PM | #5 |
Member#: 285861
This just happened to me tonight on my way home from work. Although I have a 2011 with 2500 miles on it. Zero mods. I got both P2109 and P0607. I let it sit for 10 minutes and it seemed to be fine but I had it towed to the dealer.
Fried ECU? P0607 Control Module Performance on a 2006 WRX! HELP? | 99ways2die | General Community | 9 | 09-07-2012 05:45 AM |
p0607 code car running fine? | def3022 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 11-03-2011 11:26 PM |
Coupon code for Subaru | djinn | Interior & Exterior Modification | 9 | 05-22-2011 02:16 AM |
Limp Mode and P0607 help | fourseasonsandles | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 98 | 05-13-2011 09:44 PM |
P0607...what is it? | Mechie3 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 2 | 04-11-2009 07:44 PM |
