Old 07-11-2011, 11:14 AM   #26
schweezly
Member#: 187013
2013 ST
2011 WRX Hatch
Drivers side goes out randomly, usually twice a week.
7,000 miles now, been hapenning since 2,000.
Going in this week for service and will bring it up.
schweezly is offline   Reply With Quote
Old 07-14-2011, 04:14 PM   #27
Soosh2k
Member#: 287158
2011 WRX
Spark Silver
Left mine at the dealer today. Had the same thing as schweezly, with the random on and off but on the passenger side.
Soosh2k is offline   Reply With Quote
Old 07-14-2011, 05:30 PM   #28
badbasser98
Member#: 104801
2011 WRX Limited
1) 2011 WRX Ltd
2) 5k once then stopped until 7k
3) drivers front
4) we'll take care of it
5) dealer fix
badbasser98 is offline   Reply With Quote
Old 07-15-2011, 01:33 AM   #29
ConanOBrien
Member#: 278373
2011 STi
1) 2011 STi
2) 309 Miles and 650 Miles
3) Right at 309, Left at 650
4) I did not bother going to the dealer as I didn't want to waste a trip
5) I simply went through the wheel well, took the turn signal out and reseated the bulb. Neither of them have had the problem since.
ConanOBrien is offline   Reply With Quote
Old 07-16-2011, 09:59 PM   #30
petar7408
Member#: 212820
2009 WRX
white
1. 2009 wrx
2. started at 22k miles
3. driver side
called dealer and they said to bring it in.. they tapped on it and it started working because they saw the issue many times..
they need to change the whole damn headlight since SOA doesn't sell just the harness- which scares me for the other side once its out of warranty!
seems like the mornings are ok, then later in the day it starts to blink fast.
petar7408 is offline   Reply With Quote
Old 07-17-2011, 06:35 PM   #31
Soobiecabra
Member#: 259527
2011 WRX Sedan
Custom Cobra Plasti-Dip
2011 drivers side fast blink. The tech at Subaru who fixed it said the buld had corrosion around the socket, he replaced the bulb, cleaned the socket and put some kind of lube, "di-'letric" or something. He said he could not determine the cause of the corrosion.
Soobiecabra is offline   Reply With Quote
Old 07-18-2011, 10:42 AM   #32
Improbus
Member#: 278439
2011 WRX 306HP/333TQ
Wingless Sedan OBP
Default Fast Turn Signal 2011 OBP Sedan
1. 2011 WRX Base Model
2. Started at 6.5k miles
3. Passenger Side
I took my car in for its 6K oil change on Saturday and on my way home from the dealership my passenger side turn signal starting blinking more rapidly than usual. I left the turn signal on and pulled over and found it was the rear passenger turn signal bulb that was flashing quickly. I called the dealer and they asked me to bring it in but in the 20 or so mile drive back to the dealer the problem ceased. I still went to the dealer and took a drive with the mechanic and he took a look at both passenger bulbs and said that it could have been a loose bulb or loose filament. He reseated the bulbs and its seems like everything is working properly but they said if the problem persists to bring it back in for bulb replacement.
-Improbus
Improbus is offline   Reply With Quote
Old 07-20-2011, 10:47 AM   #33
SuperSpeeder3000
Member#: 288963
Same issue here ... 2011 WRX started on one side and now both are doing it.... I had less than 1000 miles on it....don't want to really let them tear into the car this soon to fix the problem....
Not to mention when I had a turbo shield installed got home and popped the hood the mechs. Left my tranny stick out and was laying up under the hood on the side. With three screws to boot...I just don't trust peoples work anymore...
I'm afraid they'll cause damage just fixing my turn signals......rant over....
SuperSpeeder3000 is offline   Reply With Quote
Old 07-20-2011, 12:55 PM   #34
waness
Member#: 260995
2011 WRX STI Sedan
Car: 2011 WRX STI
Miles: 1000
Signal: Drivers side
Went to the dealer, fixed!
waness is offline   Reply With Quote
Old 07-21-2011, 01:03 AM   #35
The1SloR/T
Member#: 251879
1998 Neon R/T 178whp
2010 Wrx Sedan WRB
Happened again to me yesterday. but drivers side. after leaving it flash for a few seconds it went back to normal... ugh
2010 sedan again
The1SloR/T is offline   Reply With Quote
Old 07-22-2011, 08:56 PM   #36
joshjames
Member#: 233604
2011 WRX P.
2011 WRX
Manic left front blinker started @ 5k miles,
recently fixed by dealer : crosses fingers:
joshjames is offline   Reply With Quote
Old 08-05-2011, 03:37 PM   #37
11WRXinRed
Member#: 277492
2011 Impreza WRX
Lightning
Car: 2011 WRX STI
Miles: 4250 (happened today at lunch)
Signal: Drivers side (Front and Rear blinking 2X too fast)
Edit: Changed route of wire connection and installed new drivers side front bulb. Fixed myself
11WRXinRed is offline   Reply With Quote
Old 08-08-2011, 10:28 PM   #38
Phil_Dunphy
Member#: 273862
2011 WRX STI 4D
Dark Gray Metallic
1) 2011 WRX STI
2) 5350 miles, just started this morning
3) drivers front
4) I'll probably take it to the dealer
Phil_Dunphy is offline   Reply With Quote
Old 08-10-2011, 03:07 PM   #39
iwanbo
Member#: 81951
2011 WRX Hatch
1) 2011 WRX hatch
2) ~5k
3) Left (driver side)
4) Warranty, no cost
5) Replaced both turn signal bulbs myself and it went away for ~1500 miles before it started to do it again. I dealt with it because I didn't have time to go to the dealership for about another 1500 miles. Brought to a dealership and had them fix it when I had about 8500 miles on the car. They also fixed my fuel door for me since I had the problem where it wouldn't open all the time.
iwanbo is offline   Reply With Quote
Old 08-10-2011, 03:16 PM   #40
855T
Member#: 246628
2010 Impreza WRX
1.) 2010 WRX Sedan
2.) 10K
3.) Driver side front
4.) None, didn't take it in
5.) Replaced bulb and reduced the insane tension that was on the wire. I have no idea why they built it that way.
855T is offline   Reply With Quote
Old 08-11-2011, 06:18 PM   #41
jtbenn
Member#: 288453
2011 Impreza STI
WR Blue
I'm glad to have seen this so I can make sure my dealer is aware this is a common problem and there is a TSB.
1) 2011 STI Sedan
2) Started around 600 miles (currently have 2000 miles)
3) Right turn signal
4) No quotes
5) I'll take it in soon.
jtbenn is offline   Reply With Quote
Old 08-11-2011, 07:00 PM   #42
besthaticouldo
Member#: 279660
1.) 2011 WRX Sedan
2.) 2500-3000
3.) passenger side front
4.) South Coast Subaru
5.) Replaced bulb, as well as added some additional wire and added a new connector.
that was 3k miles ago and haven't had the problem since.
besthaticouldo is offline   Reply With Quote
Old 08-11-2011, 08:01 PM   #43
ajdmenthusiast
Member#: 175240
2005 WRX
Replacing the bulb will fix nothing unless the bulb is bad. Along with replacing the bad bulb the routing of the harness is too tight. Slightly re-route the harness to create some slack.
ajdmenthusiast is offline   Reply With Quote
Old 08-11-2011, 08:02 PM   #44
ajdmenthusiast
Member#: 175240
2005 WRX
Also yes there is a TSB out but that is what the TSB tells us to do.
Old 08-14-2011, 11:36 AM   #45
a2cpc
Member#: 10139
WRX 09 Outback 15
Miata 93
Sad...a few days ago at a local Subaru dealership I heard one of the service guys tell someone on the phone...We know it wasn't the bulb, we haven't run into this before, but we can replace the wring and socket for $XXX.XX!?! I am not sure if it was this exact problem, but from what I heard I would bet it was. Really sucks because I kind of like this dealership.
a2cpc is offline   Reply With Quote
Old 08-15-2011, 03:10 PM   #46
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
That's when you give them the TSB number and complain (or the car was out of warranty).
jonklein611 is offline   Reply With Quote
Old 08-19-2011, 04:57 PM   #47
Clutch987
Member#: 291454
2011 BJV STI 4-Door
2011 STI sedan
453 miles total, Owned car only 5 days, problem went away for 1.5 days and then returned.
Passenger front
Dealer very familiar with issue, dealer fixed issue on 8/18/11 and problem came back 8/19/11
I might take matters in my own hands and try to fix it.
Clutch987 is offline   Reply With Quote
Old 08-20-2011, 03:14 AM   #48
StiHum
Member#: 291981
2011 sti base
1500 mile
1 month
Passenger side
Probably take it to dealer
StiHum is offline   Reply With Quote
Old 08-30-2011, 07:27 PM   #49
tornado542
Member#: 280370
2012 Sport Premium
Ice Silver Metallic
2011 Outback Sport
1500 miles - replaced bulb - dealer
6000 miles - replaced headlight assembly and wire harness - dealer
tornado542 is offline   Reply With Quote
Old 09-03-2011, 01:41 PM   #50
moonrider_99
Member#: 258628
2009 WRX stg2-SOLD
2012 MS3
2009 wrx
60k
Started this week on passenger side. Wiggled the turn signal wire and it stopped.... definitely not a bulb issue but harness/connection. I don't have the oem airbox but I still had the cobb air box in the way. Getting to it from the fender looks like a good idea if u have a lift, ton of space down there.
moonrider_99 is offline   Reply With Quote
turn signal problem 08 wrx !kid Electrical & Lighting 21 01-17-2013 02:59 PM
FS : 08-11 STi LED Turn Signal Mirrors WRX Conversion bustedstuff210 Exterior/Styling 9 02-21-2012 01:24 AM
2001 Outback Fast Driver's Side Turn Signal steelheadbum Newbies & FAQs 1 11-03-2010 06:22 AM
Fast Turn Signal Handsdown Electrical & Lighting 15 12-03-2008 12:03 PM
Help: Right turn signal flashing twice as fast... Silver04DE Electrical & Lighting 10 09-09-2004 10:06 AM
