Old 09-03-2011, 10:49 PM   #51
sanguines
Member#: 156128
2011 WRX
da ba dee da ba dye
Happened to my 2011 WRX on the driver's side at ~1900 miles. Dealer replaced the whole headlamp assembly under warranty.
sanguines is offline   Reply With Quote
Old 09-06-2011, 04:32 PM   #52
James STI
Member#: 289631
2011 STI sedan
SSM
1) 2011 STI
2) 2750mi
3) Left
4) Took it to the dealership and they fixed it
James STI is offline   Reply With Quote
Old 09-06-2011, 05:08 PM   #53
f1speeder
Member#: 138854
2011 WRX
1) Wife's 2010 Impeza 2.5i
2) 19600 mi
3) Left
4) Took it to the dealership and they fixed it under warranty. Now they say there is a bulletin for it and rewired it for a short in the wiring harness.
f1speeder is offline   Reply With Quote
Old 09-07-2011, 02:25 AM   #54
CTSSM2011STI
Member#: 279512
2011 STI Limited 4dr
This happened to me today on my 2011 STI Sedan with just over 6k on it. It was an intermittent issue but now that found this thread if it happens again I am going to take it in.
CTSSM2011STI is offline   Reply With Quote
Old 09-07-2011, 04:23 AM   #55
SawksFan562
Member#: 292352
2011 Impreza WRX
2011 wrx wagon
just over 800 miles
Passenger side blinker
I made an appt to have the dealership look at the problem
SawksFan562 is offline   Reply With Quote
Old 09-07-2011, 12:50 PM   #56
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Seems like a 2009+ situation here huh?
ejicon is offline   Reply With Quote
Old 09-07-2011, 03:37 PM   #57
M3Octane
Member#: 263675
2011 WRX Limited 5dr
WR Blue Mica
1) 2011 WRX
2) 6800
3) Right
4) TBD
Mine is also intermittent.
M3Octane is offline   Reply With Quote
Old 09-07-2011, 10:15 PM   #58
robert.lshoc
Member#: 164906
11n7 WRX
Satin pearl white/ wrb
hapns on my l signal sometimes hit a bump n it stops havent fixed yet nearest dealer is 150+ miles from me ill doit tomorrow when I get a chance. 7000 miles 2011 wrx
robert.lshoc is offline   Reply With Quote
Old 09-18-2011, 02:25 PM   #59
rexowner
Member#: 223636
11 2011 WRX5D PRM
SWP in transit
2011 wrx 5door
600
driver side
fixed itself for ten minutes then broke again. fuse isn't blown. TBD at dealership tomorrow.
rexowner is offline   Reply With Quote
Old 09-18-2011, 03:36 PM   #60
jonklein611
Member#: 117776
WR Blue Pearl
Finally took mine to the dealer. They changed the lightbulb and I was on my way.
jonklein611 is offline   Reply With Quote
Old 09-19-2011, 12:06 AM   #61
The1SloR/T
Member#: 251879
1998 Neon R/T 178whp
2010 Wrx Sedan WRB
After looking into it myself it has to do with the harass to the bulb
When you pop the hood and wiggly the wiring it fixes itself.
The1SloR/T is offline   Reply With Quote
Old 09-19-2011, 02:02 AM   #62
krazichinaman
Member#: 292812
2011 WRX - Hatch
Satin White Pearl
2011 wrx hatch limited
9XX miles
Driver side turn signal.
I removed the battery to gain access to the turn signal. Removed the turn signal socket , bulb, re-assembled, and put everything back together. Right now I have around 1500 miles and it hasn't acted back up again. Hopefully, this fixed the issue.
krazichinaman is offline   Reply With Quote
Old 09-19-2011, 01:29 PM   #63
rexowner
Member#: 223636
11 2011 WRX5D PRM
SWP in transit
2011 wrx
620
driver side
the dealer told me it was a burnt bulb. was replaced and on my way.
Old 09-19-2011, 01:46 PM   #64
lovethebugeye
Member#: 116929
2008 :shifty eyes:
2008 STi
55k
both
Recently fixed this on my car. Turned out that the standard fix of loosening the wires on the passenger side worked, and then on my driver side the bulb was just a little loose in the socket. I just had to push it in a little bit and the issue is resolved. Took like 5 min.
lovethebugeye is offline   Reply With Quote
Old 09-19-2011, 10:17 PM   #65
S2baru2
Member#: 292247
2011 STI
Dark Grey
Car: 2011 WRX STI
Miles: 1220
Signal: Drivers side
Went to the dealer, fixed! "Repaired contact in left turn signal socket". 0.2 tech units.
S2baru2 is offline   Reply With Quote
Old 09-20-2011, 06:56 PM   #66
midwestmonster
Member#: 54390
2016 Sti w/nav
CWP
2011 Wrx Sedan
2000 miles
Passenger side
Took it into dealer and they rerouted harness.
We will see if it returns.
midwestmonster is offline   Reply With Quote
Old 09-25-2011, 07:04 PM   #67
Infamous NF Crew
Member#: 293324
'11 Impreza WRX
Satin White Pearl
Originally Posted by Soosh2k View Post
Mine went away today. Lol
i just replaced mine.
Infamous NF Crew is offline   Reply With Quote
Old 09-26-2011, 11:57 AM   #68
fenderwrx
Member#: 143139
2013 VW Golf R 2dr
Carbon Steel Gray
2011 WRX Premium Hatch
550 Miles
Passenger Side
Fixing it myself after talking with a service department. Going to do the driver's side as well.
If you just replace your bulb, chances are the problem will come back. Since it's getting colder during the nights, the wiring is probably expanding and contracting more often. Even if you pull the bulb and replace it, the problem will persist until the wire has less tension...
fenderwrx is offline   Reply With Quote
Old 09-27-2011, 12:05 AM   #69
paliknight
Member#: 285480
2016 F82
MWM
1) 2011 WRX 4 dr limited
2) ~2700 miles
3) Left
4) bring it in
5) Resolved at Dealer
paliknight is offline   Reply With Quote
Old 09-28-2011, 01:59 PM   #70
WRXdriver2011
Member#: 284925
2011 WRX
2011 WRX- hatch.
Passenger side
1500 miles
Dealer fixed - under warranty- no problems since
There was actually another guy who pulled up right next to me at the dealer with the same exact problem. He had a sedan though. They said it's common
WRXdriver2011 is offline   Reply With Quote
Old 09-30-2011, 08:09 PM   #71
iheartmyimpreza207
Member#: 295085
2011 Impreza 2.5i P
Default Fast blinker
2011 Impreza 2.5i Premium
Driver's side blinker started fast-blinking at about 300 miles (bought the car with 250). Finally got it into the dealer today with 2k miles on it now, dealer said it's been known to happen due to the cable being over stretched. Anyways it was re-routed and now both sides blink as they should ftw
iheartmyimpreza207 is offline   Reply With Quote
Old 10-15-2011, 09:20 PM   #72
ndtechie_rx8
Member#: 118011
2011 WRX Limited
World rally blue
2011 WRX Sedan
2200 miles, a month old, bought car for 4 miles on it
Passenger Side
Dealer fixed, wiring harness issue
ndtechie_rx8 is offline   Reply With Quote
Old 10-16-2011, 10:55 AM   #73
Box This
Member#: 50149
15 Legacy
Looking for Baja Turbo
2011 2.5i - both front blinkers too fast
11 miles on the car when it started on the right, then moved to the left by 100 miles.
I see the problem. I took the bulbs out, and the sockets they used are defective. The spring action of the contact plate behind the bulbs isn't long enough to keep the bulbs in tight. I have "reinstalled" my bulbs several times. This time it's lasted a thousand miles, we'll see about the future.
Box This is offline   Reply With Quote
Old 10-31-2011, 03:38 PM   #74
ki4syr
Member#: 247574
2013 PBP GV STI
2008 Impreza 2.5i
1) 2011 WRX 5-door
2) Sept. '11- ~1,500mi.
3) right signal intermittent
4) Oct. 31, '11 - Took to dealer, they had to order harness for right side, have to take back in a couple days.
5) At 1,500 miles, I found this thread and just replaced the bulb and relieved the tension on the wires. Today @ 4,200 miles, it started happening again. Took straight to dealer this time. Told them that I already tried the simple fix. Will update when I take it back.
What's funny is my '11 STI sedan hasn't had this issue yet. I've had it one week longer than the WRX.
ki4syr is offline   Reply With Quote
Old 10-31-2011, 04:14 PM   #75
bildonia
Member#: 296219
2011 WRX Limited
Dark Grey Metallic
2011 WRX Hatch
<500 miles
Passenger side
Fixed it myself buy repositioning wiring harness
bildonia is offline   Reply With Quote
turn signal problem 08 wrx !kid Electrical & Lighting 21 01-17-2013 01:59 PM
FS : 08-11 STi LED Turn Signal Mirrors WRX Conversion bustedstuff210 Exterior/Styling 9 02-21-2012 12:24 AM
2001 Outback Fast Driver's Side Turn Signal steelheadbum Newbies & FAQs 1 11-03-2010 05:22 AM
Fast Turn Signal Handsdown Electrical & Lighting 15 12-03-2008 11:03 AM
Help: Right turn signal flashing twice as fast... Silver04DE Electrical & Lighting 10 09-09-2004 09:06 AM
