Welcome to the North American Subaru Impreza Owners Club Wednesday July 1, 2015
Old 04-08-2012, 08:58 PM   #126
2011WRXMT
Member#: 270426
2011 WRX Premium
Satin Pearl White
In my 2011 the right front went out a couple weeks ago and it was fixed under warranty=o)
2011WRXMT is offline   Reply With Quote
Old 04-08-2012, 10:44 PM   #127
TomSTi
Member#: 300431
2012 WRX STi
ISM
1) 2012 STi
2) 4100
3) Left
4)
5) Dealer
Dealer said there's a TSB out, and they adjusted both turn signals up front.
TomSTi is offline   Reply With Quote
Old 04-09-2012, 09:02 PM   #128
Allen Horton
Member#: 315961
2008 WRX
Dark gray metallic
Ok, so I went to my dealer today, told them what was going on, and not only did they replace the light, they found the info on the cause. The 2008+ WRX models have a tendency for the wire to be pulled taut during the initial installation. With some jarring, heating and cooling it loosens the bulb's base from its terminals. While they had my front bumper off they replaced both turn signals AND re routed the tight wires, in theory, preventing the re-ocurance of this same issue.
Hopefully this can help someone else here.
Allen Horton is offline   Reply With Quote
Old 04-09-2012, 09:58 PM   #129
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
Yep. A few people have either had that done at the dealer, or in my case, done it themselves. You can re-route it without taking off the bumper if you take out the air box (passenger side) or battery (driver side).
bicycle_wreck is offline   Reply With Quote
Old 04-10-2012, 01:39 PM   #130
Justafour
Member#: 252066
2012 WRX LTD
DGM Sedan
1) 2012 WRX
2) 3000
3) Right turn signal but for a day my left did it too but stopped
4)
5) Easy fix: took off air box, let the wire down from the clip it was in below the headlight, no more fast blinker. Ill do this to the left side too if it starts up again.
Justafour is offline   Reply With Quote
Old 05-22-2012, 02:28 PM   #131
dcorn
Member#: 107573
2012 WRX hatch
Ice Silver
Happened to mine with less than 500 miles. It's randomly intermittant too, goes away every once in a while then comes right back.
Fixed the issue myself numerous times, but keeps coming back for no reason. One of these days I'll take out the battery or fender liner and actually reroute the wires.
dcorn is offline   Reply With Quote
Old 05-22-2012, 10:35 PM   #132
C4pt Insano
Member#: 290990
2011 WRX Sedan
Didn't realize this was an issue, glad i saw this. Only happened to me once, leaving work on a very cold morning. Put the left directional on to leave the street and it blinked super fast. Checked all the lights/signals 5 minutes later when i got home to see if any bulbs were out or blinking fast on the outside, but everything looked fine except on the dash. Next time i started the car everything was normal and hasn't showed up since.
C4pt Insano is offline   Reply With Quote
Old 05-23-2012, 02:21 AM   #133
ErasmoWRX
Member#: 306623
11 WRX
Had this happen to me at 12,500 miles. Had to take it in two times. The first time they said the connection was loose. The second time they told me the harness was to tight and they had to reroute the wire. It's been good so far.
ErasmoWRX is offline   Reply With Quote
Old 05-23-2012, 09:06 AM   #134
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
This happened a few times on my car over two days and it hasn't happened again. That was 2 months ago, I think. It stopped doing it before I could take it in for service.
bluescoobywagon is offline   Reply With Quote
Old 05-23-2012, 09:49 AM   #135
motown
Member#: 308483
2013 WRX SWP HATCH
RIP 2011 WRX-SANDY VICTIM
I pulled the wire out of the "clips" relieve some tension but that didn't help. I changed the bulb and voila. Back to normal....
motown is offline   Reply With Quote
Old 05-24-2012, 07:47 AM   #136
TimStevens
Member#: 4817
2012 STI, '02 WRX
'91 MR2, '05 Speed Triple
1 - 2012 STI
2 - 1000 miles
3 - Passenger side
4 - Just started happening last night. I'm a little about this as this car has been nothing but problems. Can't believe Subaru wouldn't have fixed this known issue.
TimStevens is offline   Reply With Quote
Old 05-24-2012, 03:06 PM   #137
Thesystem3
Member#: 233014
2008 Impreza Hatch
Satin White Pearl
just replace the bulb. problem solved. bulbs burn out, dont blame subaru
Thesystem3 is offline   Reply With Quote
Old 05-24-2012, 03:28 PM   #138
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
The bulb isn't always the issue. Bulb didn't help me. I had to take out the airbox and re-route the wiring.
Old 05-27-2012, 10:26 AM   #139
TimStevens
Member#: 4817
2012 STI, '02 WRX
Can someone give me a little info on moving the wiring? I popped the intake off and it looks to me like all the wiring goes straight down. I don't see anything that looks like I could easily adjust it:
Guessing I'm looking in the wrong place?
Old 05-27-2012, 11:04 AM   #140
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
Look to the right, closer to the fender. The socket in the center of the photo is for the high beam. The low beam is the one on the right/off camera. The turn signal socket is even further to the right.
Old 05-27-2012, 12:14 PM   #141
orbs45
Member#: 300835
2011 WRX
WRB premium
2011 wrx
5500 miles
driver side turn signal
going to attempt to to fix before bringing it to the dealership
orbs45 is offline   Reply With Quote
Old 05-27-2012, 07:09 PM   #142
TimStevens
Member#: 4817
2012 STI, '02 WRX
Thank you.
Started happening for left turns today too
Old 05-29-2012, 12:21 PM   #143
bigmaninjapan
Member#: 299064
2008 WRX Sedan (OBP)
2005 Forester 2.5XS
2008 WRX
48k miles
Drivers side signal
It's horribly intermittant, but seems to happen more often when I have the headlights on. Looks like there actually is a TSB out for it so I guess I'll talk to the dealer when I bring it in for my next oil change.
When it started happening I thought it was a bulb, but the front bulb is blinking really fast (seems to be about on par with the indicator in the cluster) and the rear one blinks at the normal rate.
Fun stuff.
bigmaninjapan is offline   Reply With Quote
Old 05-29-2012, 03:41 PM   #144
kyletakahero
Member#: 185030
2008 FXT Sport
Aspen white
2012 WRX Currently 62XX miles.
Passenger side blinker went wonky at 2k miles, along with condensation in both lamps.
Oddly enough, when I traded headlights for a short period of time with a 2011 WRX limited, the issue disappeared on mine and appear on his.
kyletakahero is offline   Reply With Quote
Old 06-01-2012, 06:00 PM   #145
waltah
Member#: 317856
2011 STi
9k miles
passenger signal
fixed using the search for the issue on here. took all of 1 minute to relieve the pressure on the wire bundle.
waltah is offline   Reply With Quote
Old 06-04-2012, 02:33 AM   #146
sanguines
Member#: 156128
2011 WRX
da ba dee da ba dye
Originally Posted by sanguines View Post
Happened to my 2011 WRX on the driver's side at ~1900 miles. Dealer replaced the whole headlamp assembly under warranty.
Hey look, here I am again!
~15,000 miles, and today the passenger side signal started doing this.
sanguines is offline   Reply With Quote
Old 06-14-2012, 01:25 PM   #147
carse
Member#: 237993
75 MGB
2011 WRX
~17,000 miles
Drivers side
Happens intermittently.
carse is offline   Reply With Quote
Old 06-14-2012, 02:06 PM   #148
motown
Member#: 308483
2013 WRX SWP HATCH
guys start w/ getting some slack on the cable and follow that up w/ bulb change. That's what I did and it works great. Anything after that bring it to dealer. Sometimes its a pain in the prick to go to the dealer for some little bs like this.
Old 06-14-2012, 07:29 PM   #149
subie_matt
Member#: 178877
2012 Impreza WRX
When I picked up my 2012 from my dealership it did the fast turn signal issue later that day. Its just tight cables from the factory. My dealership fixed it in about 10 minutes. They should be able to fix it real quick for you.
subie_matt is offline   Reply With Quote
Old 06-17-2012, 05:33 PM   #150
CapeCod27
Member#: 207701
2015 STi
Car: 2012 STi Limited Sedan SWP
Miles: 9,800
Signal: Drivers side front
Dealer: I have an appointment tomorrow 6/18/2012
CapeCod27 is offline   Reply With Quote
turn signal problem 08 wrx !kid Electrical & Lighting 21 01-17-2013 01:59 PM
FS : 08-11 STi LED Turn Signal Mirrors WRX Conversion bustedstuff210 Exterior/Styling 9 02-21-2012 12:24 AM
2001 Outback Fast Driver's Side Turn Signal steelheadbum Newbies & FAQs 1 11-03-2010 05:22 AM
Fast Turn Signal Handsdown Electrical & Lighting 15 12-03-2008 11:03 AM
Help: Right turn signal flashing twice as fast... Silver04DE Electrical & Lighting 10 09-09-2004 09:06 AM
