Old 07-19-2002, 09:40 PM   #1
RuCKuS
Member#: 7260
bann ning teh
jamaican bobsled team...
Default good or bad idea?...
so i finally decided to remove the all that air restricting plastic...tell me what you guys think...is this alright for the time being or not?...thanks...
jeremy...
p.s.-this is only temporary until i manage to save enough money for an actual CAI...
a shot of the engine...
a shot of the "mod"...
a close up shot...note the electrical tape for added style points
RuCKuS is offline   Reply With Quote
Old 07-19-2002, 10:38 PM   #2
minix42@
Member#: 548
'98 Impreza RS
dinged up faded black
Uhhh.... I hope you have a filter in there somewhere!! That's the biggest concern I see from what little information you gave us.... I'm gonna go ahead and assume that it's simply hidden in the fender for now though. You have a 2001, that uses a MAP sensor doesn't it?... that's good, otherwise you would need to worry about securing a MAF sensor in the intake somewhere.
Other than the above warnings, it should all work for now. The 'dryer vent hose' is metalic so it will reflect some radiant heat from the engine. I think the thickness (or lack of thickness) would be a future concern so you don't allow too much heat to get to your air. Not bad though....
minix42@ is offline   Reply With Quote
Old 07-19-2002, 10:53 PM   #3
RawCode
Member#: 3115
2002 Impreza 2.5RS
He has the stock filter in the BIG airbox on the TB..
Did you notice any difference with your setup? Looks like for a temp solution...
RawCode
RawCode is offline   Reply With Quote
Old 07-19-2002, 10:57 PM   #4
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
That is pretty much the exact same thing I did for my first intake. Can't hurt!
NC
Reciprocity is online now   Reply With Quote
Old 07-19-2002, 11:27 PM   #5
Fred Zaplitny
Gone... But not forgotten
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
Kind of a Home Depot Ganzflow!
Fred Zaplitny is offline   Reply With Quote
Old 07-20-2002, 12:13 AM   #6
jerome02rs
Member#: 6347
2002 Impreza 2.5RS
Platinum Silver
I did the exact same thing except I used some high temp fiber reinforced ducting that Pegasus Racing sells- it's similar the flexible orange brake ducting that's used on race cars except it has a lower temp rating. I've had it on for over six months with absolutely no problems- it's cheap and works great!
Jerome
jerome02rs is offline   Reply With Quote
Old 07-20-2002, 12:44 AM   #7
traskw
Member#: 9604
2005 LGT '94SS MR2
AtlanticBlue, Red, Silver
See how you like it and then replace it with piping. Does it dry clothes?
traskw is offline   Reply With Quote
Old 07-20-2002, 01:41 AM   #8
pillaka
Member#: 16659
2005 WRX Wagon
Cool! I almost did the same thing!
pillaka is offline   Reply With Quote
Old 07-20-2002, 02:17 AM   #9
Fred Zaplitny
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
Ooooh, the clear look! How dirty is that hose now? The function is there though! I like it.
Good or bad idea with Cobb? GregUnd Texas Impreza Club Forum -- TXIC 17 05-09-2002 11:16 AM
Boost controller with nothing else but a boost guage, good or bad idea? Corn-Picker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-08-2002 09:07 AM
New clutch? Good or bad idea? GregUnd Texas Impreza Club Forum -- TXIC 13 12-19-2001 10:48 AM
Planning to change lotsa fluids, good or bad idea? Cjchaps Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-27-2001 01:51 PM
FMIC: Good or Bad Idea Byrner13 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-29-2001 07:51 AM
