Old 04-30-2011, 04:15 PM   #1
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Default 2006 sti 2.5L Dom 1.5xtr 400+WHP E85
I just got my car put back together after 3 long weeks
New stats.
Car: 06 STI 103,xxx miles on car. I purchased it brand new. I have driven all but 34 of the miles on it.
Facility: I do my own stunts
Type of Dyno: AB (Mustang coming shortly)
Boost: peak around 26, taper to 24ish
Fuel: E85
Target AFR: looks to be around 11's
Peak HP at RPM: 402 @ 5610
Peak Torque at RPM: 427 @ 5420
Mods:
full custom vband 3" TBE ceramic coated and heat wrapped. Rerouted ewg back into DP
2 axle back sections 1 with cat instead of a muffler and the other is a muffler for DD
Perrin ELH ceramic coated and heat wrapped
Grimmspeed uppipe ceramic coated and heat wrapped
38mm tial wastegate 21.75 psi spring
DOM 1.5XTR tuned to 26 psi currently E85 420whp/430wtq (will put it on the dyno shortly) but AB logs are rediculous that's for sure.
Turbo heat blanket
ported throttle body
ported intake manifold powder coated lava black
tgv deletes powder coated lava black
Air oil seporator. (catch cans were in the way)
big TMIC ceramic coated lava black
APS 3"inlet
APS 70mm CAI
Perrin BPV
Grimmspeed EBC and MBC
Cusco water spray kit
Aeromotive fuel lines
custom -8AN fuel lines heat wrapped
Aeromotive fuel pressure regulator
walbro fuel pump
1000cc Injector Dynamic injectors (90%) duty cycles
mishimoto oil cooler
ACT heavy duty clutch
gates waterpump
gates timing belt and aux belts
grimmspeed 160* thermostat
Cobb radiator shroud
GFB short throw shifter
STI s204 shift knob
BC coils 8k 6k springs
27mm whiteline front and 22mm rear sways
whiteline end links
RPM subframe brace
stainless brake lines
lava black Powder coated brakes
DBA 2 piece rotors
front and rear strut bars
oswald front and rear bumper beams
front and rear tow hooks anodized red
Grimmspeed brake brace
Seibon front fenders 10mm wider
Seibon trunk
Seibon hood
Big wing on stock trunk
CT front splitter (on track bumper)
Hawk blue brake pads (track)
RPF-1 18x9.5 with NT-01 tires (track) PC gold
PRF-1 17x8 RE019 grids DD PC wet black
custom harness bar
6 point harness
custom aluminum rear divider
4 STRI gauges water temp, oil temp, egt temp, 45psi boost
Innovate wideband and gauge
Pioneer single din stereo
I AM DONE MODDING MY CAR FOR EVER I am so tired of working on it. Only maintain now. That's the only things I will work on is tires oil and the things that break.
medamullet is offline   Reply With Quote
Old 04-30-2011, 04:16 PM   #2
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Old 04-30-2011, 04:16 PM   #3
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
and yes I do all my own work.
Old 04-30-2011, 04:20 PM   #4
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I am not sure where this log came from in my tuning process. The numbers are around this so it's good enough. I will post dyno when it happens.
Old 05-02-2011, 11:47 AM   #5
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Please update your 1st post with the required format found here. Thanks.
http://forums.nasioc.com/forums/show....php?t=1858764
Scooby921 is offline   Reply With Quote
Old 05-02-2011, 03:48 PM   #6
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
the logs are date and time stamped....it shouldnt be that hard to find the final logs....
Old 05-02-2011, 04:08 PM   #7
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
ya, I am not done tuning. I posted a 3rd gear log in my local thread.
Code:
Time	EL	RPM	FBKC	FLKC	ITT	IDC	MAP	WGDS	WOT	MAF V	AF
1483	1.26	2191	0	0	21	11.62	1.6	89.8	100	2.44	17.2
1729	1.29	2313	0	0	20.5	12.7	2.18	89.02	100	2.52	14.92
1993	1.4	2420	0	0	19	13.94	2.76	89.02	100	2.68	14.49
2235	1.55	2592	0	0	16.5	15.94	3.48	89.02	100	2.76	14.3
2485	1.75	2734	0	0	14.5	19.24	4.5	89.02	100	2.9	14.11
2723	1.86	2932	0	0	13.5	22.62	5.95	89.02	100	3.04	13.36
2954	1.97	3090	0	0	15	25.64	7.84	89.02	100	3.18	12.82
3209	2.4	3300	0	0	16	32.59	10.45	89.02	100	3.5	12.69
3438	2.94	3534	0	0	17.5	43.1	14.51	89.02	100	3.78	12.22
3677	3.64	3856	0	0	19	58.94	20.17	89.02	100	4.06	11.29
3931	4.16	4236	0	0	20	73.08	24.38	87.84	100	4.34	11.25
4169	4.22	4612	0	0	21	79.64	24.38	78.04	100	4.5	11.88
4404	4.08	5056	0	0	23	89.2	24.38	68.63	100	4.56	12.97
4638	3.88	5466	0	0	23	89.43	24.38	61.57	100	4.6	12.88
4877	3.61	5754	0	0	23	94.6	24.38	59.22	100	4.56	12.47
5125	3.45	6091	0	0	23.5	94.35	23.94	59.61	100	4.56	12.47
5369	3.36	6380	0	0	25.5	95.84	24.23	59.61	100	4.6	12.25
5595	3.25	6650	0	0	25.5	98.68	24.38	59.61	100	4.58	12.23
5852	3.07	6889	0	0	26.5	99.32	24.38	59.22	100	4.6	11.95
This is yesterday. If you want to check i tout in AB. I know it's lean I was showing some guys that I am sitting at 99% IDC right now. I'm working on it leaning it up and backing the boost down. I am waiting for a 3 bar MAP sensor so I don't have to rely on my damn gauge. I only get 2 pulls on the way to work and 2 pulls on my way home. It's a long process.
Old 05-02-2011, 04:53 PM   #8
Phatron
Member#: 36033
CEO PhatBottiTuning
ur tuning this thing from the wrong direction
turn your boost down to 18-20 psi and get your AFR to 11.5, then turn the boost up.
What are your EGT's like @ 13:1 AFR and 26psi?
If you're running the hybrid boost control....why is your WGDC dropping below 89%?
Old 05-02-2011, 04:57 PM   #9
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
ya I know.
around 1500* or so in CYL 4 header. That was the first log with my 21.75 psi spring in my wastegate. It's no big deal. I will get it dialed in. This mornings log AF is good it's just on my other computer. it's sitting 11's all the way now.
Old 05-02-2011, 05:03 PM   #10
Phatron
Member#: 36033
CEO PhatBottiTuning
that egt seems way too low for 13:1....
you can jack up your low load timing by like 20* too....you're running more timing at 3.0 load at redline than you are at low rpm and half the load.
Old 05-02-2011, 05:08 PM   #11
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
ya, I thought about the EGT after I posted that. I am not exactly what they are I will have to check my peak when I get out to my car after work.
That turbo just keeps going though. It runs out of RPM's way sooner than it stops making power.
That log I posted sits at 419/410 it's all in the ball park. I can't wait to get it out to the track and try not to break it.
Old 05-14-2011, 12:41 AM   #12
Hando567
Member#: 153595
2006 Impreza WRX STI
SGM
I feel like the 1.5 xtr should spool faster, peak TQ at 4500 is what I usually see the 3.0 xtr run, the 2.5 xtr is down around 4000, so for a 1.5 it is wicked late. Unless E85 slows spool and I'm just uninformed (which is possible)
Hando567 is offline   Reply With Quote
Old 05-14-2011, 01:01 PM   #13
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
E85 lowers egt's and slows spool a bit.
OP, Very nice. You sound like me "I'm done working on this thing" Congrats!
2gnt2wrx is offline   Reply With Quote
Old 05-14-2011, 03:17 PM   #14
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
no actually even though egt's go down exhaust volume goes up which should push the turbine side harder.Every car I have tuned on e85 has spooled a tad quicker than on pump gas by about 200 rpm.
john 1badSTI is offline   Reply With Quote
Old 05-14-2011, 06:24 PM   #15
PlanetGranite
Member#: 156635
2005 Sti
CGM
Peak torque may be a little late, but I don't think I've ever seen a DOM3.0xt-r or DOM2.5xt-r make 300tq @ 3000 rpm on an Airboy? So the quicker spool would seem to be there (with E85).
PlanetGranite is offline   Reply With Quote
Old 05-14-2011, 07:02 PM   #16
rexblake
Member#: 178426
2010 S4
Gray
This. Every turbo I have had with E85 it spools faster.
rexblake is offline   Reply With Quote
Old 05-17-2011, 01:31 AM   #17
Strobe Media
Member#: 241600
2004 WRX STi
like a million whp
what wing is that?
Strobe Media is offline   Reply With Quote
Old 05-17-2011, 04:07 PM   #18
Kovs04sti
Member#: 257085
07 Sti SWP
"I do my own stunts" lol I love it
Kovs04sti is offline   Reply With Quote
Old 05-21-2011, 08:01 PM   #19
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I a sure it could spool faster than it is currently. All my intake side is ported and all my exhaust is ceramic coated and heat wrapped. I am just scared to run any more timing down low or more boost since the motor and heads are stock. I am making well over 450 I am assuming with my injectors being maxed. I am going to turn the fuel pressure up to give myself a safety factor. I'm happy were it stands and for 103XXX miles I will run it like it is until I need a new motor.
Old 05-21-2011, 08:20 PM   #20
Phatron
Member#: 36033
CEO PhatBottiTuning
what is your tire size? what are you using for overall weight?
what are your EGT's? in the log up there you're running 13:1 at WOT
and your timing curve has a big hole in it during boost ramp.....you get down to 14* at ~6psi.....but then you're running 20* at 26 psi.....
if you're running 20* at 26psi at peak tq/load....you shouldnt be scared to run more below that....
Old 05-23-2011, 04:06 PM   #21
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Fuel is richer now I got it down to low 11's so I don't know what the EGT's are at 13.1. I didn't change any of the timing just have been playing with the fuel. I can't get my omni 3bar to work right. The car won't start when I put in the 3bar values. Until I can get that working I not going to adjust any of the timing of fuel.
I know you say that Phatron, and I agree, but it doesn't change the fact that I'm scared. The car runs right now and makes good power. I feel like if I change it up I might just break something
Old 05-23-2011, 05:29 PM   #22
Phatron
Member#: 36033
CEO PhatBottiTuning
well it doesnt make sense at all....if you were actually scared you would have the timing at 14* at pk tq going up to 20....not 20 up to 28
the 14* at 1.5 load is inconsequential compared to the 20* at peak tq....
And that log you have up there is at 99% IDC at 12:1 AFR......so how did you lower your AFR down to low 11's? lower the boost?
Old 05-23-2011, 05:48 PM   #23
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
he could go up on IDC but lowest AFR could prob get to is 11.5 unless boost is lowered. I do agree with Ron about timing. should taper down to 20 then up to 28
renosubby is offline   Reply With Quote
Old 05-23-2011, 09:12 PM   #24
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Ya I lowered my boost down to 24ish until I get the 3bar map sensor sorted.
Old 05-24-2011, 01:19 AM   #25
ThePowerOfAWD
Member#: 283649
New stats.
Fuel: E85
Mods:
Turbo heat blanket
APS 3"inlet
APS 70mm CAI
Perrin BPV
walbro fuel pump
gates waterpump
STI s204 shift knob
whiteline end links
RPM subframe brace
DBA 2 piece rotors
Seibon trunk
Seibon hood
custom harness bar
6 point harness
How much money do you have invested?
ThePowerOfAWD is offline   Reply With Quote
Dyno Tune: 2.5L Blouch Dom 2.5XTR, 372whp, EPIC Tuned englishguy3012 Proven Power Bragging 9 06-11-2014 08:31 PM
Dom 1.0 Owners where are you? Robzilla Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-29-2012 11:33 AM
Anyone have a dynojet chart of a Green/SZ49/Dom 1 on an ej205? jason miller Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-05-2009 04:01 PM
Dom 3 or Dom 2.5 or Dom 1 or FP Green? Want ~400 whp with quickest spool? 2.1 stroker NITROS Built Motor Discussion 10 10-26-2009 12:40 PM
FS: 02-05 WRX Grimmspeed top end + DOM 1 turbo + PE800cc Drakar Engine/Power/Exhaust 6 07-22-2009 07:35 PM
