Old 04-30-2011, 09:23 PM   #1
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
Default Power steering fluid
What does 06 wrx power steering fluid do we use? ATF or brake fluid?
talvai is offline   Reply With Quote
Old 04-30-2011, 10:54 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Dexron III or IV
I'd suggest using M1 synthetic ATF or Motul syn ATF
Old 05-01-2011, 12:32 PM   #3
68Cadillac
Member#: 95901
I use Mobil1 synthetic ATF. It's rated Dexron IV. Inexpensive too.
68Cadillac is offline   Reply With Quote
Old 06-01-2011, 04:56 PM   #4
Nick-subiefan
Member#: 164500
2004 WRX
Do all these mix well one with another? (in case we don't know what we have in our cars) !?
Nick-subiefan is offline   Reply With Quote
Old 06-01-2011, 05:21 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
well...you can remove and drain the reservoir and re-fill it and let the system cycle and repeat a couple times to flush the old fluid which does help.....but it does mix
Old 06-01-2011, 11:29 PM   #6
Nick-subiefan
Member#: 164500
2004 WRX
I checked and checked and I see that Motul has many different ATF fluids.
When people say "I use Motul synthetic ATF" what are they referring to:
Motul Multi ATF?
Motul Dexron III?
Motul Gear Comp?
Motul Motylgear?
- and a few of these come in different viscosities. Does viscosity mater in PS or not?
Thanks
Old 06-02-2011, 03:30 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
you want the dexron III is what you want
or just buy the Mobil1 atf
both are good choices
Old 11-23-2011, 07:29 PM   #8
kh15
Member#: 132400
Just went to autozone and couldn't find the mobile 1 atf dexron III, they have some new advanced formula stuff...will it work?
"Mobil 1 Synthetic ATF has the following builder approvals:
Allison C4
It meets or exceeds the requirements of:
JASO 1-A
Ford Mercon V
Mobil 1 Synthetic ATF is recommended by ExxonMobil for use in applications requiring:
GM Dexron IIIH
GM Dexron IIIG
GM Dexron IIE
GM Dexron IID
GM Dexron II
GM Dexron
Ford Mercon
Voith H55.6335.3X
MAN 339 V1
Volvo 97340
Volvo 97341"
kh15 is offline   Reply With Quote
Old 11-23-2011, 09:19 PM   #9
skimobile
Member#: 92114
03 WRX (NAVY Camo)
in"Special Ed." Run Group
Also, REDLINE makes synthetic PS fluid that works well with Subarus....
http://www.redlineoil.com/product.aspx?pid=79&pcid=27
RED LINE POWER STEERING FLUID satisfies the service fill requirements of most auto manufacturers and can be used where the manufacturer calls for any automatic transmission fluid such as DexronŽ, Dexron II-DŽ, II-EŽ, or Dexron IIIŽ, Ford Type-F, Mercon, or M2C138-CJ such as required by Ford, AMC, Toyota, Nissan, Lexus, Infiniti, Jaguar, VW, Mercedes-Benz, BMW, SAAB, Subaru, Volvo, Porsche, Mitsubishi, Mazda, and many others.
skimobile is offline   Reply With Quote
Old 11-24-2011, 02:19 AM   #10
kh15
Member#: 132400
bump for my question...
Old 11-24-2011, 09:07 AM   #11
skimobile
Member#: 92114
03 WRX (NAVY Camo)
ATF,..... is that clear enough?
Old 11-24-2011, 10:02 AM   #12
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Use Dexron VI (or equivalent) ATF: it replaces any former designations (e.g. Dexron III; IIE; II; etc.)
Old 11-24-2011, 03:20 PM   #13
kh15
Member#: 132400
That was not my question.................................
Old 11-24-2011, 05:39 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
d000000000000000000d
there is only ONE as in a single kind of Mobil1 ATF
buy it...use it...love it
Old 11-24-2011, 07:10 PM   #15
lotarg
Member#: 90940
or Valvoline synthetic ATF. Or any brand non-synthetic ATF. It doesn't matter.
lotarg is offline   Reply With Quote
Old 11-24-2011, 08:32 PM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
no....no you dont wanna do THAT...no
Old 11-25-2011, 07:33 AM   #17
skimobile
Member#: 92114
03 WRX (NAVY Camo)
OP question answered..
Old 11-26-2011, 08:59 AM   #18
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
my question was answer 7 months ago when the thread was made.
Old 11-26-2011, 09:25 AM   #19
Big-E
Member#: 123843
2016 STI LTD CWP
True, but it was bumped by another due to relevance and the forum rules of 'recycling' posts instead of creating another same/similar post.
Power steering fluid, manual tranny fluid, and rear diff fluid ex_boyometric Vancouver Impreza Club Forum -- VIC 17 03-09-2008 05:54 AM
Power Steering Fluid / Steering Shimmy + Noise Altaic Brakes, Steering & Suspension 4 04-24-2006 12:59 AM
Power steering fluid or ATF? SubieFL Normally Aspirated Powertrain 4 03-30-2001 06:25 AM
Synthetic Power Steering fluid FYI Joe Hogan Technical Forum Archive 1 07-31-2000 06:17 PM
