Old 07-20-2002, 05:49 AM   #1
dooolu
Member#: 20576
Default how many lbs u guys put in your stock tires?
I put 30lbs...how many lbs is normal?
dooolu is offline   Reply With Quote
Old 07-20-2002, 10:11 AM   #2
Rev
Member#: 9681
2017 Santa Fe Sport
Inside the drivers door well it recommends 32 in the front tires and 29 in the back, thats what I use.
Rev is offline   Reply With Quote
Old 07-20-2002, 11:30 AM   #3
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
After much research on this board, I went with one person's favorite of 35f/32r. The ride is a little more stiff, but it feels much better.
gjhsu is offline   Reply With Quote
Old 07-20-2002, 02:17 PM   #5
WRX500
Member#: 11708
1971 Ford Torino
I like 38 front, 35 rear.
WRX500 is offline   Reply With Quote
Old 07-20-2002, 03:39 PM   #6
occhy
Member#: 20667
2002 wrx
blue pearl
Default how about 17"
I just got 215/45/17. What do you guys run during the summer and winter?
occhy is offline   Reply With Quote
Old 07-20-2002, 04:35 PM   #7
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
wow...38f/35r???
**** i only have 30f/30r...
KIMUTAKU is offline   Reply With Quote
Old 07-21-2002, 03:28 AM   #8
Sean
Member#: 518
762 PGT Impreza L,
Silverado EXT, Yaris
Default Re: how about 17"
Sean is offline   Reply With Quote
Old 07-21-2002, 03:29 AM   #9
Sean
Member#: 518
762 PGT Impreza L,
Old 07-21-2002, 08:46 AM   #10
4or2wheels
Member#: 14112
2002 wrx wagon
2010 STI DGM
The listed pressure's in your door jamb are WAY TOO LOW. When I had the stock 92's I would run 40lbs. all around give or take 2 lbs. If you do any aggressive cornering with 32lbs. in the front you will notice that the tire is folding over and your running on your sidewall. Thats not good.
4or2wheels is offline   Reply With Quote
Old 07-21-2002, 10:13 AM   #11
saggioWRX
Member#: 18994
08 GTS
10 CTS W
35 Ibs all the way around! And YES the factory door jam Ibs are WAY to low! Door jam level is for the Joe Shmo driver that doesn't do much hard cornering
saggioWRX is offline   Reply With Quote
Old 07-21-2002, 04:35 PM   #12
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
Depends on the tires and the use....
when I'm wearing out the RE-92's that came on some 99 RS wheels, 35 all around.
With the 215-45-16 Azenis:
track: 38F 34R
street: 40 all around
this balances the wear
jack
Old 07-21-2002, 05:31 PM   #13
Rev
Member#: 9681
2017 Santa Fe Sport
Thank you. I gota add some air pressure
Old 07-22-2002, 01:59 AM   #14
Sean
Member#: 518
762 PGT Impreza L,
Changing your driving style is probably better than just blindly adding air pressure. I switched to the higher pressures not because of rollover but because I simply liked a snappier feel. Even with the stock 32f/29r I never roll over during spirited driving. Smooth lines equals zero rollover under most circumstances.
My first autocross season, even when I was running 45f/45r, I still rolled over because I didn't know proper braking and cornering. Now that I've learned proper braking and lines, I can easily autocross on stock pressures and just barely roll over. I'll be slower but being smooth is more important than being fast when you're first starting out.
There is no cone | PGT Impreza L Rally Car | P Neon Rally Car
Trunkmonkey Racing | [email protected] | What is a Trunkmonkey?
Old 07-22-2002, 02:21 AM   #15
SAL-23
Member#: 3474
2013 WRX
Mine came 41f/40r from the dealer and I haven't made any adjustments yet and have never rolled over the sidewall arrows.
SAL-23 is offline   Reply With Quote
Old 07-22-2002, 02:41 AM   #16
Sean
Member#: 518
762 PGT Impreza L,
To find out if you really need more air, mark your tires with chalk or shoe polish. If you rub off the marks past the "safe" line, you need more air. Look at the marks on this tire and you'll see the pressures are absolutely dead on for the conditions of the track because the marks line up exactly with the rollover line (NHIS road course, November, 60 degrees, 38f/35r, Bridgestone RE730 215/45ZR17):
The fronts, however, had some rollover and should have been upped to around 40f:
And warm tires are gooey tires:
Of course, the pressures can be fine tuned further for desired performance handling but the rear marks show how to set pressures initially and then fine tune later.
Old 04-10-2005, 01:28 AM   #17
coolray
Member#: 36618
1984 project justy
wrb
can anyone tell me whats the correct tire pressure for 225/40/18 tires in the summer
thanks
coolray is offline   Reply With Quote
Old 04-10-2005, 01:32 AM   #18
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
Should be the same pressures. There is no "correct," only what is correct for you driving. Experiment with it until you find something you like.
Despite what I said 3 years ago (eek), I have since moved on to 35f/34r
Old 04-10-2005, 11:05 AM   #19
coolray
Member#: 36618
1984 project justy
wrb
thanks gjhsu
ya i understand there is no correct pressure but i m just wondering what tire pressure
will be optimal for my tires in the sense of tire wear
cuz i understand the fact that too much or too little pressure will cause the tires to wear out a lot of quicker
Old 04-10-2005, 08:50 PM   #20
WRXRgr
Member#: 54942
2004 WRX
I ran something like 44/42 in the RE92s...took out some of the wallow, but they just have very soft sidewalls...still, that was much better than the suggested placard pressures.
WRXRgr is offline   Reply With Quote
Old 04-10-2005, 09:18 PM   #21
import111
Member#: 24447
2010 Evo GSR
GG
38psi/37psi F/R on my STI.
Ryan
import111 is offline   Reply With Quote
Old 04-11-2005, 12:57 PM   #22
foxboroxt
Member#: 73104
2003 WRX wagon stg2
2011 Outback
38-40 all around feels much better to me.
foxboroxt is offline   Reply With Quote
Old 04-11-2005, 10:45 PM   #23
Phil Jr.
Member#: 62221
dont forget that all tire pressure guages read different. I have seen them off by 5 or more PSI...
Phil Jr. is offline   Reply With Quote
Old 05-13-2005, 02:17 PM   #24
CapeRex
Member#: 81070
Sorry to bring up an old thread,but I had been running 35-38psi on my stock tires and just changed to 28 front/32 rear at a fellow owner's advice,and the steering actually feels great! Probably the added weight of the lower pressure helps,plus he said this is a good setup for weight transfer in straight-line acceleration.I first thought this was a weird setup,but it feels good.
CapeRex is offline   Reply With Quote
Old 05-13-2005, 02:21 PM   #25
wht052.5
Member#: 79527
2005 2.5RS(I NDTRBO)
Chipped Crystal Gray
36/36 Normal
40/40 Auto-X
You like oversteer, right?
wht052.5 is offline   Reply With Quote
How many miles do you put on your suby per year? Gel Mibson General Community 87 02-18-2010 02:58 PM
How many shingles can I put in teh wagon? styng88 Mid Atlantic Impreza Club -- MAIC 9 09-23-2006 08:59 AM
How many bananas can we put in a thread? Black STi Texas Impreza Club Forum -- TXIC 8 12-11-2004 08:38 AM
WRX durability? how many miles have you put on your wagon or sedan 5M? ufoguy Newbies & FAQs 14 11-10-2003 04:33 PM
Poll- How many nails have YOU had in your tires? fuzzbox General Forum Archive 21 10-20-2000 08:54 AM
