Old 05-03-2011, 01:20 AM   #1
SupraScooby
Member#: 52123
05 WRB STi
04 AW STi GT30R [RIP]
Default Help identifying engine/pulley noise?
Sounds like a chattering sound from maybe the ac compressor pulley? Doesn't change when the AC is turned on or off. No squealing/squeaking noises. It usually is present on cold startup and then is intermittent when warmed up. Any suggestions? Thanks.
For others searching: it ended up being the small timing belt idler.
SupraScooby is offline   Reply With Quote
Old 05-04-2011, 11:28 PM   #2
ledzeppelin240
Member#: 227951
2004 Impreza WRX
Start removing belts to isolate the noise or check with a long screw driver/stethascope to so see where the noise is coming from.
ledzeppelin240 is offline   Reply With Quote
Old 05-05-2011, 04:03 PM   #3
me109a
Member#: 199690
2004 STi
Check the A/C idler pulley. I just had the same sort of sound and it went away after the car warmed up. It's the small pulley under the tensioner for the A/C compressor.
That what it sounds like to me.
me109a is offline   Reply With Quote
Need help identifying engine Ginsu Pre-2002 Factory Turbo Powertrain 6 05-18-2008 07:15 PM
Need help identifying engine specs... WRXGuyInUSA Pre-2002 Factory Turbo Powertrain 4 06-12-2006 01:54 AM
Need Help Identifying Engine MrWhite Subaru Conversions 1 06-18-2005 09:43 AM
need help identifying engine please 911renegade Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-25-2004 01:04 AM
Help identify metal ringing noise in front wheel twlai Brakes, Steering & Suspension 5 05-16-2003 02:43 PM
