Old 05-06-2011, 10:52 AM   #1
static-psi
Member#: 237649
04 STI
blue
Default JDM taillight mod DIY
This is a fairly easy modification you can do in 5-10 minutes.
The only tool you'll need is a flathead screwdriver (this may not be necessary if you have fingernails).
To access the taillights, you need to remove clips from your trunk.
There is one clip on the driver side:
There are two clips on the passenger side:
I found the following picture of the taillight:
Instructions:
Take out the three harnesses.
Take the one that was closest to you and move it to the furthest one.
Move the middle one closest to you.
Remove the harness from the furthest, and move it to the middle.
Remove the middle bulb
Replace the clips
Pictures (these are not my car - it's still light out)
Before (no brake):
Before (brake):
After (no brake):
After (brake):
Found DIY @
http://www.clubwrx.net/forums/exteri...od-05-sti.html
static-psi is offline   Reply With Quote
Old 05-06-2011, 12:07 PM   #2
Joshz400_03
Member#: 198844
2003 WRX
I have mine as the outside and inside are running lights and the center is the stoplight.
Joshz400_03 is online now   Reply With Quote
Old 05-07-2011, 10:30 AM   #3
static-psi
Member#: 237649
04 STI
blue
Iphone photos suck
Old 05-07-2011, 10:35 AM   #4
02Rexticy
Member#: 223313
02 WRX
thats pretty sick, i like it!!
02Rexticy is offline   Reply With Quote
Old 05-15-2011, 10:59 PM   #5
static-psi
Member#: 237649
04 STI
blue
Thanks
Old 05-22-2011, 05:01 PM   #6
Black_EG
Member#: 239917
2005 STi
The wires on the harnesses became really tight after doing it.
Drivers side middle harness is a pain to take out.
Black_EG is offline   Reply With Quote
Old 05-23-2011, 12:49 AM   #7
sars101
Member#: 280420
2005 2.5 rs
silver ish
i have the same tail lights but i have all the bottoms come on when i pressing on the breaks. now i have to setup to have all 3 of the bottom ones stay on while no breaks being pressed, it will still get brighter. but im waiting for some free pigtails from my job. i also got my rear lights tinted like 20% dark. and got got my turn signals red not the correct bulb but it fits just fine with a little shave or pressure.
sars101 is offline   Reply With Quote
Old 07-30-2011, 12:56 PM   #8
O5 RexWag
Member#: 286503
2005 WRX Wagon
Definitely doin this! SICK
O5 RexWag is offline   Reply With Quote
Old 07-30-2011, 02:49 PM   #9
DSRX2005
Member#: 271681
2013 WRB Subaru WRX
AJW Performance
Ya when I did this I noticed the same thing, I decided that the wires wouldn't enjoy that much tension so I just cut them and extend it with a separate wire. I just soldered and put heat shrink on them. The lights defiantly look a ton better after. Good write-up!
DSRX2005 is offline   Reply With Quote
Old 07-31-2011, 01:23 AM   #10
kamotors
Member#: 261910
2004 WRX
I did this this and like it a lot.
kamotors is offline   Reply With Quote
Old 08-03-2011, 12:42 PM   #11
Tehmap
Member#: 290235
2007 Subaru Impreza
I really wish that look was possible on the 07 impreza. The lights are arranged differently and while I am going to attempt it, I think the end result will not look nearly as good.
Tehmap is offline   Reply With Quote
Old 08-03-2011, 03:10 PM   #12
Big-E
Member#: 123843
2006 SGM WRX S2
Let LED's light your way!
You could do a lot with the 2006-2007 tail lamps.
If however you do this, be aware that the bulb in this position will be the "high" side of the bulb. It will look as if you have the brake lights on all of the time.
None-the-less, if you want to, you can back out the terminals from the connector to rewire the bulb-socket positions to achieve this look. You will however need red LED bulbs to achieve this effect.
Otherwise, you could rewire the lamps so that the inner lower is the brake, outer lower is the back-up, outer upper is both the parking and turn-signal and the inner upper is just the parking or both the parking and fog-lamps.
If you have any other questions, PM me and I'll tell you what you need to do and which LED bulbs you'll need to achieve this.
Old 09-04-2011, 01:53 AM   #13
WrxBogdan
Member#: 281716
2005 Impreza Wrx
Platinum Silver Metallic
So in the end you have no middle bulb?
WrxBogdan is offline   Reply With Quote
Old 09-04-2011, 03:26 AM   #14
djtoone
Member#: 285097
2004 WRX
Java Black Pearl
Correct.
djtoone is offline   Reply With Quote
Old 09-04-2011, 09:16 PM   #15
WrxBogdan
Member#: 281716
2005 Impreza Wrx
Going to do this soon!
Old 09-05-2011, 10:59 AM   #16
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
i don't know about everyone's states, but in PA, this is illegal as you no longer have rear sidemarkers.
indytruckboy is offline   Reply With Quote
Old 09-08-2011, 03:57 PM   #17
ktgt
Member#: 164964
2003 Impreza WRX
wrb
okay I have a question, I bought a set of jdm v8 tailights at a jdm parts shop and i do not want the jdm mod i personally don't like how the circles stay lit, i tried using the old bug eye tail light harness but the bulb are somewhat bigger atleast the signals one. i also tried to switch bulbs places but the harness is not long enough.
what do you guys recommend? i dont wanna trade tails either..
car is a wrx 03 sedan, and yes v8 tails does fit the bug eyes without dremel or cutting..took me 10 minutes..just a small gap hardly noticeable..
ktgt is offline   Reply With Quote
Old 12-03-2011, 10:46 PM   #18
nate02wrx
Member#: 271593
2002 wrx
midnight black pearl
Hey has anyone tried rewiring a little take the outer socket move it to the inner spot. So then the circle is the one lighting up with headlights the wire it so the other two bulbs come on when hitting the brakes and the circle would also get brighter too
nate02wrx is offline   Reply With Quote
Old 02-06-2012, 10:49 PM   #19
ABeastinWRX
Member#: 239469
2004 WRX
PSM for now ;)
thank you sir for this haha
ABeastinWRX is offline   Reply With Quote
Old 02-11-2012, 02:41 PM   #20
08OBS
Member#: 274397
2005 WRX
just did this mod. looks awesome!
08OBS is offline   Reply With Quote
Old 04-15-2012, 06:43 PM   #21
djtoone
Member#: 285097
2004 WRX
Java Black Pearl
Sounds easy enough and would be pretty cool to see.
3xtra brake light power to fend off tailgaters ;-)
Anyone tried it yet?
Old 04-18-2012, 04:08 PM   #22
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
^^^Yup it works well
nosmo is offline   Reply With Quote
Old 04-21-2012, 07:03 PM   #23
WRX_FTW
Member#: 240792
04 AW STi Stage ?
04 AW FXT Stage 3
I couldn't get the outer and inner switched because of the ground wires. Didn't feel like splicing anything today, I'll probably end up doing it later though.
WRX_FTW is offline   Reply With Quote
Old 05-03-2012, 05:30 PM   #24
Black_EG
Member#: 239917
2005 STi
Anyone have only the outer lights turn on when braking?
How do I get the inside (circular) ones to turn on without having my headlights on and braking.
Old 05-17-2012, 04:40 PM   #25
JStrath
Member#: 318198
2004 WRX
JBP
How exactly did you wire it to get that result? I like that look a lot better
JStrath is offline   Reply With Quote
JDM Taillight Mod turboxsubie05 Interior & Exterior Modification 3 04-24-2011 05:11 PM
JDM Taillight mod question yo14jman Interior & Exterior Modification 1 10-08-2009 05:31 PM
JDM taillight mod? ThirdEye Newbies & FAQs 10 03-21-2007 05:43 PM
jdm taillight mod? Jake06wrx Electrical & Lighting 8 04-17-2006 11:31 PM
04-05 jdm taillight mod 00Maddog Alaskan Impreza Club Forum -- AKIC 10 10-18-2005 12:08 AM
Message Board Statistics All times are GMT -4. The time now is 11:02 PM.
