Old 07-20-2002, 06:25 PM   #1
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Default Road Dyno!
Anyone have the link to the site that someone had posted their road dyno charts for a intake? I just got one and need all the #'s to set it up correctly.
Need for a 2000 RS
drive axle ratio
Test gear ratio (2nd or 3rd)
drag Coefficient
Frontal area
drivetrain loss
Midwayman is offline   Reply With Quote
Old 07-21-2002, 03:35 AM   #2
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
diff ratio is 4.11
gear ratio final
1st 3.55 14.59
2nd 2.11 8.67
3rd 1.45 5.96
4th 1.09 4.48
5th 0.78 3.21
frontal area, cd or drivetrain loss - I though one of those was calc from a coast down test from a certain speed?
est drivetrain loss is 25% (23-27%)(RS dynos at 128hp and makes 165 crank, WRX dynos 167hp and 227 crank)
ImprezaRS dot com is offline   Reply With Quote
Old 07-21-2002, 06:52 PM   #3
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
The Cd is supposedly 0.35 for the 2000 RS (apparently about -1% from that for a 20mm drop as well)
The frontal area is 22 ft^2
Old 07-21-2002, 10:41 PM   #4
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Just in case anyone is interested in my first run.....
Dunno why I have so much more torque than power.
Old 07-21-2002, 11:37 PM   #5
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Here's the link http://www.charm.net/~mchaney/roaddyno
Would you mind sending me software you have.
I'm having issues with mine.......it doesn't want to work properly.....data is messed up......someone told me there was an updated on software.
Thanks
Legacy777 is offline   Reply With Quote
Old 07-22-2002, 11:02 AM   #6
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
So Josh, when and where are we going on a dyno run?
DanzBorin is offline   Reply With Quote
Old 07-22-2002, 11:07 PM   #7
Legacy777
Member#: 4800
anywhere really. There's sorta a road I was using by my place in an industrial park area.
If you want to still try and do it before I leave, you'd have to head out to my place some evening.....I really need to start packing and such.......Just finished puttin on the last coat for the calipers tonight.
Shoot me a call....lemme know if you want to come out.
Road Dyno RiftsWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 51 12-09-2002 08:35 AM
Home Dyno/Road Dyno Thumper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-20-2002 09:23 PM
Road Dyno Opinions Stavros g Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-24-2001 08:56 AM
Road Dyno? Anyone heard of this? Necromancer Bay Area Impreza Club Forum -- BAIC 4 02-15-2001 12:42 AM
Road Dyno measures HP from ECU Jon Bogert Technical Forum Archive 5 10-11-2000 06:48 AM
